LXi chassis design - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: LXi chassis design (/showthread.php?tid=2149) |
LXi chassis design - David Brady - 03-09-2006 16:04 Folks, I've suddenly taken an interest in how the chassis is designed in my LXi. Does anyone on the list have any detailed pics of the chassis. I've been under mine to piece it together, but given all the insulation sprayed about, its a bit hard to see. What I've been able to see are the two 10"x3"x5/16" C channel rails forming the main load bearing frame ladder. These seem to be capped with a bulk head behind the front wheels and ahead of the rear wheels, and then there are two longitudinal frame members, 8"x2" square cross-section tubes, that run underneath the C channels connecting the bottoms of the front and rear bulk heads. Attached to the C-channels are vertical outriggers that form the insides of the basement box. These boxes are triangulated and have angle iron that runs the length of the coach on the bottom outside edge and have cross members that span the entire distance on the bottom from side to side. The house is built on top of this platform. It would have been fascinating to see the assembly process back in 2003 as the last of the LXi's came off the line. Any pics anyone? Thanks, David Brady '02 LXi, Smokey, Va -- No virus found in this outgoing message. Checked by AVG Free Edition. Version: 7.1.375 / Virus Database: 268.2.1/277 - Release Date: 3/8/2006 |
