Battery question? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Battery question? (/showthread.php?tid=2152) |
Battery question? - davidkerryedwards - 03-10-2006 15:04 Does it seem odd to anyone else besides me, that BB uses 6 volt deep cycle batteries to start the engine? I like a separate engine starting battery myself. Kerry 82 FC 35 Denver Battery question? - Tom Warner - 03-10-2006 15:24 Deep cycle batteries work fine for starting the Cat 3208. The thing you have to worry about is how much energy you pull out of them overnight if you have a lot of power hungry appliances such as a satellite TV, lights etc since those same batteries have to start the Cat the next morning. I am not sure you would want to use them for the Detroit series engines however. If there is room you might considewr going to the Trojan T125 or T145 6VDC deep cycle batteries which are a little taller. http://www.trojan-battery.com/ Tom Warner 1982 Bluebird Vernon Center,NY At 10:04 PM 3/10/2006, you wrote: >Does it seem odd to anyone else besides me, that BB uses 6 volt deep >cycle batteries to start the engine? I like a separate engine >starting battery myself. > >Kerry >82 FC 35 >Denver > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreationa\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreational\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- Battery question? - Jeff Miller - 03-10-2006 16:20 You can add them, it's only money. BB decided to only use the one compartment for batteries, which limited them to four, not enough to use only two for house batteries, so they are dual-purpose. The four 6v GC-6 batteries have plenty of cranking amps, and the GC-6 being designed for deep-cycle use gives the coach the most dry- camping amp-hours and most discharge-charge cycles available (compared to starting or combination batteries). Given the choice of a split bank, four GC-6 batteries, or four 12v starting or marine batteries, I take the additional amp-hours of the GC-6 also. Four of the GC-6 from Sams or wherever will fit your original tray perfectly. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > Does it seem odd to anyone else besides me, that BB uses 6 volt deep > cycle batteries to start the engine? I like a separate engine > starting battery myself. > > Kerry > 82 FC 35 > Denver > Battery question? - fwernlein - 03-10-2006 22:59 I wrestled with the same concern over not having a split battery system, mainly due to a boating perspective, as jump starts are harder to get. But after consideration i just went to the 6vt. deep cycle types as Jeff recommends, and i am lucky as my coach has the two "extra" batteries next to the Readi-line, all tied together in one big bank. Two factors tipped the scales for me: First: my 3208 starts when you just look at it...no need for long cranking. Second: if i run batteries down, the generator battery will start the gen, then i can charge the big bank. The gen set is my reserve. In my mind it would be a waste of battery capacity to dedicate a pair of batts to soley engine start. frank 85FC33 Woodbridge, va. --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > You can add them, it's only money. > > BB decided to only use the one compartment for batteries, which > limited them to four, not enough to use only two for house batteries, > so they are dual-purpose. > > The four 6v GC-6 batteries have plenty of cranking amps, and the GC-6 > being designed for deep-cycle use gives the coach the most dry- > camping amp-hours and most discharge-charge cycles available > (compared to starting or combination batteries). > > Given the choice of a split bank, four GC-6 batteries, or four 12v > starting or marine batteries, I take the additional amp-hours of the > GC-6 also. > > Four of the GC-6 from Sams or wherever will fit your original tray > perfectly. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > Does it seem odd to anyone else besides me, that BB uses 6 volt deep > > cycle batteries to start the engine? I like a separate engine > > starting battery myself. > > > > Kerry > > 82 FC 35 > > Denver > > > |
