transmission oil cooler - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: transmission oil cooler (/showthread.php?tid=2204) |
transmission oil cooler - emc2jb6 - 03-17-2006 11:08 does anyone have or has anyone ever installed a oil cooler on a 83fcrb model bird. if so where did you install it and did you get the benefit from it that you expected. i have a few leaks in the heat exchangers under the couch and under the bed so i turned off the valves that feed this system and now i have a heat problem. what are my options if i leave this system isolated. transmission temp is running about 200 and above. have not run it for long at this temp. transmission oil cooler - Mike Hohnstein - 03-17-2006 13:54 The oil filters are attached to the oil cooler, the coolant hoses that feed it are to be changed annually. You should get those under seat heater cores fixed up as leaving the coolant system dysfunctional is a real bad thing. Sounds like you would do well to flush the whole thing out and refresh the system. 50/50 distilled water/antifreeze. I personally don't pay extra for the "extended life" product. Do check the pH of the system with sample sticks available at Napa. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: emc2jb6 To: WanderlodgeForum@yahoogroups.com Sent: Friday, March 17, 2006 5:08 PM Subject: [WanderlodgeForum] transmission oil cooler does anyone have or has anyone ever installed a oil cooler on a 83fcrb model bird. if so where did you install it and did you get the benefit from it that you expected. i have a few leaks in the heat exchangers under the couch and under the bed so i turned off the valves that feed this system and now i have a heat problem. what are my options if i leave this system isolated. transmission temp is running about 200 and above. have not run it for long at this temp. SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
