Kohler genset tripping - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Kohler genset tripping (/showthread.php?tid=2222) |
Kohler genset tripping - Rose Mary - 03-19-2006 12:04 Hi, finally time to get back to the genset trip problem. I noticed the fan isn't turning and after a short time the red reset button trips. The fan seems to turn easily by hand. Any suggestions on what would cause the fan not to turn? thanks Rose Mary 82 FC 33 Hoping to go for a jaunt in the 'White Bird' toward the end of next week..... Kohler genset tripping - erniecarpet@... - 03-19-2006 12:27 Rose Mary, if your circuit breakers on the control box are tripped- you will have no power to make your fan turn. Ernie-83pt40 in Texas -----Original Message----- From: Rose Mary To: WanderlodgeForum@yahoogroups.com Sent: Mon, 20 Mar 2006 00:04:33 -0000 Subject: [WanderlodgeForum] Kohler genset tripping Hi, finally time to get back to the genset trip problem. I noticed the fan isn't turning and after a short time the red reset button trips. The fan seems to turn easily by hand. Any suggestions on what would cause the fan not to turn? thanks Rose Mary 82 FC 33 Hoping to go for a jaunt in the 'White Bird' toward the end of next week..... Yahoo! Groups Links [Non-text portions of this message have been removed] Kohler genset tripping - putneyflash@... - 03-19-2006 13:49 Awhile back my fan stopped turning. i removed the cover on the back of the motor and one of the screw terminals had cbroken loose probility from corrosion. the 208 volts comes directly off the out terminals in the control box on mine re brake 1983 fc-35 sb -------------- Original message from erniecarpet@...: -------------- Rose Mary, if your circuit breakers on the control box are tripped- you will have no power to make your fan turn. Ernie-83pt40 in Texas -----Original Message----- From: Rose Mary To: WanderlodgeForum@yahoogroups.com Sent: Mon, 20 Mar 2006 00:04:33 -0000 Subject: [WanderlodgeForum] Kohler genset tripping Hi, finally time to get back to the genset trip problem. I noticed the fan isn't turning and after a short time the red reset button trips. The fan seems to turn easily by hand. Any suggestions on what would cause the fan not to turn? thanks Rose Mary 82 FC 33 Hoping to go for a jaunt in the 'White Bird' toward the end of next week..... Yahoo! Groups Links [Non-text portions of this message have been removed] SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] Kohler genset tripping - Rose Mary - 03-19-2006 15:51 Hi, I assume that circuit breaker is the one on the wall inside the generator compartment. It did not seem to be tripped tho I did switch it on and off to be sure...no change. I think it is just something simple like that as most everything I have found wrong (in my learning curve with the 'White Bird' has been as easy as operator error most of the time. It's hard to see and get back to that breaker box and I cannot seem to get it completely open, are there just the 2 connected breakers? Thanks so much for the help. I will check the wires on back of the motor tomorrow and look for corrosion and try to reset those breakers again just to be certain. Rose Mary 82 FC 33 Oregon -warm & sunny today! --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Rose Mary, if your circuit breakers on the control box are tripped- you will have no power to make your fan turn. Ernie-83pt40 in Texas > > -----Original Message----- > From: Rose Mary > To: WanderlodgeForum@yahoogroups.com > Sent: Mon, 20 Mar 2006 00:04:33 -0000 > Subject: [WanderlodgeForum] Kohler genset tripping > > > Hi, finally time to get back to the genset trip problem. > I noticed the fan isn't turning and after a short time the red reset > button trips. > The fan seems to turn easily by hand. Any suggestions on what would > cause the fan not to turn? > thanks > > Rose Mary > 82 FC 33 > > Hoping to go for a jaunt in the 'White Bird' toward the end of next > week..... > > > > > > > Yahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed] > Kohler genset tripping - erniecarpet@... - 03-20-2006 00:37 Rose Mary- the control box behind the generator engine is the unit I was talking about. You might have to air the coach up to extend the generator tray. My box use to trip those breakers every once in a while. Ernie 83pt40 in Texas -----Original Message----- From: Rose Mary To: WanderlodgeForum@yahoogroups.com Sent: Mon, 20 Mar 2006 03:51:41 -0000 Subject: [WanderlodgeForum] Re: Kohler genset tripping Hi, I assume that circuit breaker is the one on the wall inside the generator compartment. It did not seem to be tripped tho I did switch it on and off to be sure...no change. I think it is just something simple like that as most everything I have found wrong (in my learning curve with the 'White Bird' has been as easy as operator error most of the time. It's hard to see and get back to that breaker box and I cannot seem to get it completely open, are there just the 2 connected breakers? Thanks so much for the help. I will check the wires on back of the motor tomorrow and look for corrosion and try to reset those breakers again just to be certain. Rose Mary 82 FC 33 Oregon -warm & sunny today! --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Rose Mary, if your circuit breakers on the control box are tripped- you will have no power to make your fan turn. Ernie-83pt40 in Texas > > -----Original Message----- > From: Rose Mary > To: WanderlodgeForum@yahoogroups.com > Sent: Mon, 20 Mar 2006 00:04:33 -0000 > Subject: [WanderlodgeForum] Kohler genset tripping > > > Hi, finally time to get back to the genset trip problem. > I noticed the fan isn't turning and after a short time the red reset > button trips. > The fan seems to turn easily by hand. Any suggestions on what would > cause the fan not to turn? > thanks > > Rose Mary > 82 FC 33 > > Hoping to go for a jaunt in the 'White Bird' toward the end of next > week..... > > > > > > > Yahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed] > Yahoo! Groups Links [Non-text portions of this message have been removed] Kohler genset tripping - Curt Sprenger - 03-20-2006 01:58 Rose Mary, On our 1987, in order for the generator system fan motor to run (turn), it needs voltage, which the alternator (the Kohler unit) should provide. The fan will not turn if the voltage is not present. On ours, it turned out the Kohler unit was bad, not putting out the voltage due to corroded windings, etc. I replaced the Kohler with the Newage unit. I suggest having a reliable generator shop test your system. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Rose Mary wrote: > Hi, finally time to get back to the genset trip problem. > I noticed the fan isn't turning and after a short time the red reset > button trips. > The fan seems to turn easily by hand. Any suggestions on what would > cause the fan not to turn? > thanks > > Rose Mary > 82 FC 33 > > Hoping to go for a jaunt in the 'White Bird' toward the end of next > week..... > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreational\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreational+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+vehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
