ZF tranny and a 3208 - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: ZF tranny and a 3208 (/showthread.php?tid=2240) |
ZF tranny and a 3208 - birdshill123 - 03-21-2006 17:27 How relaible is the ZF with the 300 HP Cat? I did read about a $6000 electronic board and that sure scared me? Is the retarder any good? I seem to remember something about engine overheating. Thanks: Bruce No BB yet but soon! ZF tranny and a 3208 - Jack Bentley - 03-22-2006 00:09 Hi again Bruce, Hopefully you will get additional opinions on the ZF but here is my experience with it. The ZF is a pretty much bullet proof transmission and I hear of very few problems with it. When there is a problem reported to this forum it is normally some loose wire or such. Although I'm sure there must have been other problems with the ZF, as with any transmission, there seem to be few discussed on this forum. Maybe someone else is familiar with the $6000 circuit board but I don't remember seeing that discussed. In the late eighties there was a modification to the electronics module that controls the shift points and provided a more desirable shift range. ZF provided this at no cost. The retarder works well and in conjunction with downshifting, provides good retarding. In fact, I use the retarder for most braking and very seldom use the chassis brakes except for the final stop. The heat generated by the ZF retarder is handled by the transmission fluid, which has a cooler. I have never seen the engine overheated by the transmission retarder. In times when the retarder is used more than normal I manually turn on the engine fan override to add some additional cooling to the transmission fluid. The transmission temperature gauge should always be monitored when using the retarder. As I know nothing about other retarder systems maybe someone else can give you a comparison report. Good luck. Jack '87 FC35 "Traveller" (for sale until mid April, then she leaves on a three month trip through the west) Franklin, NC [Non-text portions of this message have been removed] ZF tranny and a 3208 - Jeff Miller - 03-22-2006 13:28 The 300hp 3208ATAAC and ZF 5HP500 transmission are very well matched. The difference between driving this powertrain and its predecessor the 250hp 3208Ta / 4-speed allison is like a BMW to a cushman scooter. Problems are rare, but expensive if you have them. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > How relaible is the ZF with the 300 HP Cat? I did read about a $6000 > electronic board and that sure scared me? Is the retarder any good? I > seem to remember something about engine overheating. > > Thanks: Bruce > > No BB yet but soon! > |
