Tires?? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Tires?? (/showthread.php?tid=2296) |
Tires?? - birdshill123 - 03-27-2006 09:04 I am considering the purchase of a unit that is going to need tires. The rears for sure. But would probably replace all 6. I havent checked very many dealers but I am getting prices of $435 to $500 plus mounting and taxes. Seems high. Has anyone used other brands with success? The Michelin is designed for motorhomes and 2 dealers recommended the XZE. Many of the others either have a very aggressive tread or are very hard. Ride could suffer. If you have used another brand and are pleased could you give me the model and amke of the tire and approxiamte price. If the others are only a few dollars less I would not consider anything but Michelin. Thanks: Bruce Tires?? - George Lowry - 03-27-2006 09:29 Bruce, FWIW, I won't have Michelins on any of my coaches. I have had many failures with the Michelin tires, in fact one on the BBWL. On our '95 WL, we replaced the Michelins with Toyos. Ride was about the same and cost was much less. Bought them at Les Schwab Tires. IIRC it ran about $270 each, installed and balanced. I use Equal for balancing. best way we have found. George Lowry '06 Alpine Apex - Formerly '95 WBDA 4203 Spearfish, SD NOw at TTN Las Vegas birdshill123 wrote: > I am considering the purchase of a unit that is going to need tires. > The rears for sure. But would probably replace all 6. I havent checked > very many dealers but I am getting prices of $435 to $500 plus mounting > and taxes. Seems high. Has anyone used other brands with success? The > Michelin is designed for motorhomes and 2 dealers recommended the XZE. > Many of the others either have a very aggressive tread or are very > hard. Ride could suffer. If you have used another brand and are pleased > could you give me the model and amke of the tire and approxiamte price. > If the others are only a few dollars less I would not consider anything > but Michelin. Thanks: Bruce > > > > > > > > Yahoo! Groups Links > > > > > > > > > Tires?? - John Suter - 03-27-2006 09:58 Hi Bruce, The first step in selecting tires is the determination of the Load Rating (LR), which is based upon the weight the tire must bear, and requires either weighing the tire position of the coach, or estimating the heaviest tire position weight. The second step should be, given the LR, select a tread design for a LR (by tire model and manufacturer); as some models will not come in the required LR. Only then can you begin to assess the relative pricing among manufacturers, tire models, and dealer/distributor price quotes. You will want to compare prices after trade-in allowances, if any, mounted, and with new valve stems. Insist on tires with manufacture dates stamped on the tire casing, less than 1 year from purchase date. Department of Transportation (DOT) rules may limit the value of trade-ins for your tires with manufacture dates older than 5 years, and trade-in tires that have been repaired. Attempting to compare tires of unequal LR is an exercise in wasting time. John Suter -- birdshill123 > I am considering the purchase of a unit that is > going to need tires. > The rears for sure. But would probably replace all > 6. I havent checked > very many dealers but I am getting prices of $435 to > $500 plus mounting > and taxes. Seems high. Has anyone used other brands > with success? The > Michelin is designed for motorhomes and 2 dealers > recommended the XZE. > Many of the others either have a very aggressive > tread or are very > hard. Ride could suffer. If you have used another > brand and are pleased > could you give me the model and amke of the tire and > approxiamte price. > If the others are only a few dollars less I would > not consider anything > but Michelin. Thanks: Bruce > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com Tires?? - Jeff Miller - 03-27-2006 13:01 I'm with you on Michelins. The best tire IMO from Michelin for your coach is not the XZE, it seems to have increased tread squirm over the XZA series possibly due to its deeper tread. I have tried many brands, find the XZA2 (XZ2 in 12R size) tires to be the best riding and excellent directional stability. I don't know the year of your FC, but if later than about 1981 it requires a 16PR tire / LRH. If '78 through mid-'83, it has 7.50" wide rims and requires 11Rx22.5 tires, if mid-'83 or later the 8.25" rims will fit 12" wide tires. If you can install the 12" tires I recommend doing it at least on the steer axle for the lower pressure/nicer ride. I installed BFG's premium steer 11R/LRH tires on one of our coaches a couple of years ago, made in a Michelin plant in old Michelin X molds, and was very happy with them. I've used Bridgestone's premium steer on drive axle, not the ride of the Michelin nor the resale value, but pretty good tires. Opinions vary widely on brands, this is my experience/opinion. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > I am considering the purchase of a unit that is going to need tires. > The rears for sure. But would probably replace all 6. I havent checked > very many dealers but I am getting prices of $435 to $500 plus mounting > and taxes. Seems high. Has anyone used other brands with success? The > Michelin is designed for motorhomes and 2 dealers recommended the XZE. > Many of the others either have a very aggressive tread or are very > hard. Ride could suffer. If you have used another brand and are pleased > could you give me the model and amke of the tire and approxiamte price. > If the others are only a few dollars less I would not consider anything > but Michelin. Thanks: Bruce > Tires?? - birdshill123 - 03-27-2006 13:10 John: Than you for that info. I own a small fllet of both on road and off road trucks, forklifts and tractors. I am fully aware of the problems with vehicle weights and load ranges. If this were a truck the decision would be a no brainer. But a MH is a whole other story. Especially in a 12R22.5. These would of course be LRH which will easily handle the weight of an FC35. Besides increasing LR without making sure the other factors ( wheels, suspension axles, etc.) can take the weight is a waste of time. There are not many 12R tires that are recommended for motorhome use. Using tires designes for an 18 wheeler or a 53 ft. trailer will cause lots of problems. The Michelins are designed for RV use. This usually means they have additives to prevent UV damge, are quiet and handle well These items are not important to a tractor trailer owner. Maybe I should have worded my question better: Which other mfrs. have tires suitable for our applications and does anyone have experience with thee tires; good or bad. As for the Toyos: Toyo is not making motorhome tires and are now recommending that you NOT use their tires on a motorhome. Bruce wanabe Tires?? - scoggins_jim - 03-27-2006 21:24 Bruce; I have had good service out of both Toyos and Michelin. For cost issues I thoughabout Toyos on e drives and Michelin on the steers. Tires?? - birdshill123 - 03-28-2006 06:19 Les Schwab also suggested some less expensive tires on the drive and Michelins on the front. Bruce Tires?? - Jon - 03-28-2006 12:52 --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > Les Schwab also suggested some less expensive tires on the drive and > Michelins on the front. > > Bruce > My new set of rear end tires cost around 1200 dollars installed at Les Schwab. I like the tires but also the idea that I can take it in and get the tires check anytime I want! Jon Rebel Bird |
