Loose wheel SP36? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Loose wheel SP36? (/showthread.php?tid=2351) |
Loose wheel SP36? - williamcharrison - 04-06-2006 03:20 I took the bird out for a test drive after replacing the thermostat and ran over a rather large pothole at which time I heard (and felt) a rattling from the right front wheel which felt similar to an episode I experienced with an old truck I had which turned out to be worn kingpins. Questions are: does this coach have kingpins and if so how big a job is it to replace them? Chuck Harrison 90 SP36 Akron, Ohio Loose wheel SP36? - agitator19 - 04-06-2006 12:42 --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > I took the bird out for a test drive after replacing the thermostat > and ran over a rather large pothole at which time I heard (and felt) > a rattling from the right front wheel which felt similar to an episode > I experienced with an old truck I had which turned out to be worn > kingpins. Questions are: does this coach have kingpins and if so > how big a job is it to replace them? > > Chuck Harrison > 90 SP36 > Akron, Ohio > Chuck, Yes, your SP has king pins. I have not done a replacement of them on my SP, but if it is anything like the other work I have done, (brakes tires, valve adjust, fan clutch, radiator) it is not any different than on a car, tractor, etc. Just much bigger, heavier, etc. You will of course need the proper size reamer, etc. I am sure the parts are available from Blue Bird, however, they are probably available from bus - heavy truck parts suppliers also. Jim Brookshire 89 SP-36 Saluda, NC Loose wheel SP36? - agitator19 - 04-06-2006 12:42 --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > I took the bird out for a test drive after replacing the thermostat > and ran over a rather large pothole at which time I heard (and felt) > a rattling from the right front wheel which felt similar to an episode > I experienced with an old truck I had which turned out to be worn > kingpins. Questions are: does this coach have kingpins and if so > how big a job is it to replace them? > > Chuck Harrison > 90 SP36 > Akron, Ohio > Chuck, Yes, your SP has king pins. I have not done a replacement of them on my SP, but if it is anything like the other work I have done, (brakes tires, valve adjust, fan clutch, radiator) it is not any different than on a car, tractor, etc. Just much bigger, heavier, etc. You will of course need the proper size reamer, etc. I am sure the parts are available from Blue Bird, however, they are probably available from bus - heavy truck parts suppliers also. Jim Brookshire 89 SP-36 Saluda, NC |
