Voltage Gauge Readings...Help! - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Voltage Gauge Readings...Help! (/showthread.php?tid=2354) |
Voltage Gauge Readings...Help! - Scott Forman - 04-06-2006 11:14 Is the reading on the engine voltage gauge of any use when the engine isn't running? I have four 2-month old T-105's and an IntelliPower converter/charger with the Charge Wizard option that makes it a three-stage charger. My engine voltage gauge seems to work accurately. The dash amps gauge does not work at all, I cannot find why. The amps gauge in the step well seems to work accurately. Enough background...does the voltage gauge reading matter when parked? When on shore power or gen, it shows accurately the voltage being delivered to the bat's whichever stage the charger is in. Likewise, the step well amp gauge will show charging as appropriate. When in "dry" mode, though, the voltage gauge will fall down to 12 or even slightly below within a matter of a few minutes of the power being disconnected without any 12v items on. The step well amps gage does NOT show discharge at this point, and when power is reconnected, the indicator lights on the charger will still reflect fully charged batteries. So...is this voltage gauge reading showing me something that matters or not? And if it is irrelevant when parked, is there a way I can determine how far down the bat's are without pulling out the multimeter? Thanks Scott Forman 82 FC25RB Memphis Voltage Gauge Readings...Help! - Tom Warner - 04-06-2006 12:06 Scott the Bluebirds have a problem with low voltages in the dash. One of the best things you can do is to get all of that current OUT of the dash. I have added Bosch relays to control the Chassis A/C blowers. Now the A/C dash switches only "trigger" the Bosch relays that now give full voltage to the blower motors. They now blow like a hurricane. Same with the headlight switch, now the "dimmer" switch triggers the Bosch relays for hi and lo beam. Full battery voltage to the headlights and they are really BRIGHT! Same with the heater switches. Then run a larger 12VDC line to the dash and everything will work fine. The odometers on the speedometer are notorious for not keeping accurate mileage because of this low voltage. TAke a reading on the dash voltmeter and then take a good voltmeter and read the voltage across the battery terminals. The battery terminals will be the correct reading. If its alright at the battery terminals dont worry about it. Tom Warner Vernon Center,NY 1982 FC35 (for sale soon) 1985 PT 40 (not for sale ) At 07:14 PM 4/6/2006, you wrote: >Is the reading on the engine voltage gauge of any use when the engine >isn't running? > >I have four 2-month old T-105's and an IntelliPower converter/charger >with the Charge Wizard option that makes it a three-stage charger. >My engine voltage gauge seems to work accurately. The dash amps >gauge does not work at all, I cannot find why. The amps gauge in the >step well seems to work accurately. > >Enough background...does the voltage gauge reading matter when >parked? When on shore power or gen, it shows accurately the voltage >being delivered to the bat's whichever stage the charger is in. >Likewise, the step well amp gauge will show charging as appropriate. >When in "dry" mode, though, the voltage gauge will fall down to 12 or >even slightly below within a matter of a few minutes of the power >being disconnected without any 12v items on. The step well amps gage >does NOT show discharge at this point, and when power is reconnected, >the indicator lights on the charger will still reflect fully charged >batteries. > >So...is this voltage gauge reading showing me something that matters >or not? And if it is irrelevant when parked, is there a way I can >determine how far down the bat's are without pulling out the >multimeter? > >Thanks >Scott Forman >82 FC25RB >Memphis Voltage Gauge Readings...Help! - Scott Forman - 04-06-2006 12:51 I added the headlight relays...unbelievable difference. --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > Scott the Bluebirds have a problem with low voltages in the dash. One > of the best things you can do is to get all of that current OUT of > the dash. I have added Bosch relays to control the Chassis A/C > blowers. Now the A/C dash switches only "trigger" the Bosch relays > that now give full voltage to the blower motors. They now blow like a > hurricane. Same with the headlight switch, now the "dimmer" switch > triggers the Bosch relays for hi and lo beam. Full battery voltage to > the headlights and they are really BRIGHT! Same with the heater > switches. Then run a larger 12VDC line to the dash and everything > will work fine. The odometers on the speedometer are notorious for > not keeping accurate mileage because of this low voltage. > TAke a reading on the dash voltmeter and then take a good voltmeter > and read the voltage across the battery terminals. The battery > terminals will be the correct reading. If its alright at the battery > terminals dont worry about it. > > Tom Warner > Vernon Center,NY > 1982 FC35 (for sale soon) > 1985 PT 40 (not for sale ) > > > > At 07:14 PM 4/6/2006, you wrote: > >Is the reading on the engine voltage gauge of any use when the engine > >isn't running? > > > >I have four 2-month old T-105's and an IntelliPower converter/charger > >with the Charge Wizard option that makes it a three-stage charger. > >My engine voltage gauge seems to work accurately. The dash amps > >gauge does not work at all, I cannot find why. The amps gauge in the > >step well seems to work accurately. > > > >Enough background...does the voltage gauge reading matter when > >parked? When on shore power or gen, it shows accurately the voltage > >being delivered to the bat's whichever stage the charger is in. > >Likewise, the step well amp gauge will show charging as appropriate. > >When in "dry" mode, though, the voltage gauge will fall down to 12 or > >even slightly below within a matter of a few minutes of the power > >being disconnected without any 12v items on. The step well amps gage > >does NOT show discharge at this point, and when power is reconnected, > >the indicator lights on the charger will still reflect fully charged > >batteries. > > > >So...is this voltage gauge reading showing me something that matters > >or not? And if it is irrelevant when parked, is there a way I can > >determine how far down the bat's are without pulling out the > >multimeter? > > > >Thanks > >Scott Forman > >82 FC25RB > >Memphis > Voltage Gauge Readings...Help! - Tom Warner - 04-06-2006 13:58 Add the relays to trigger the fan motors on the heater and chassis A/C if you really want to see a difference. Tom Warner Vernon Center,NY 1982 FC35 (for sale soon) 1985 PT 40 At 08:51 PM 4/6/2006, you wrote: >I added the headlight relays...unbelievable difference. > > > >--- In WanderlodgeForum@yahoogroups.com, Tom Warner >wrote: > > > > Scott the Bluebirds have a problem with low voltages in the dash. >One > > of the best things you can do is to get all of that current OUT of > > the dash. I have added Bosch relays to control the Chassis A/C > > blowers. Now the A/C dash switches only "trigger" the Bosch relays > > that now give full voltage to the blower motors. They now blow like >a > > hurricane. Same with the headlight switch, now the "dimmer" switch > > triggers the Bosch relays for hi and lo beam. Full battery voltage >to > > the headlights and they are really BRIGHT! Same with the heater > > switches. Then run a larger 12VDC line to the dash and everything > > will work fine. The odometers on the speedometer are notorious for > > not keeping accurate mileage because of this low voltage. > > TAke a reading on the dash voltmeter and then take a good voltmeter > > and read the voltage across the battery terminals. The battery > > terminals will be the correct reading. If its alright at the >battery > > terminals dont worry about it. > > > > Tom Warner > > Vernon Center,NY > > 1982 FC35 (for sale soon) > > 1985 PT 40 (not for sale ) > > > > > > > > At 07:14 PM 4/6/2006, you wrote: > > >Is the reading on the engine voltage gauge of any use when the >engine > > >isn't running? > > > > > >I have four 2-month old T-105's and an IntelliPower >converter/charger > > >with the Charge Wizard option that makes it a three-stage charger. > > >My engine voltage gauge seems to work accurately. The dash amps > > >gauge does not work at all, I cannot find why. The amps gauge in >the > > >step well seems to work accurately. > > > > > >Enough background...does the voltage gauge reading matter when > > >parked? When on shore power or gen, it shows accurately the >voltage > > >being delivered to the bat's whichever stage the charger is in. > > >Likewise, the step well amp gauge will show charging as >appropriate. > > >When in "dry" mode, though, the voltage gauge will fall down to 12 >or > > >even slightly below within a matter of a few minutes of the power > > >being disconnected without any 12v items on. The step well amps >gage > > >does NOT show discharge at this point, and when power is >reconnected, > > >the indicator lights on the charger will still reflect fully >charged > > >batteries. > > > > > >So...is this voltage gauge reading showing me something that >matters > > >or not? And if it is irrelevant when parked, is there a way I can > > >determine how far down the bat's are without pulling out the > > >multimeter? > > > > > >Thanks > > >Scott Forman > > >82 FC25RB > > >Memphis > > > > > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
