Pyrometer troubleshooting - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Pyrometer troubleshooting (/showthread.php?tid=2386) |
Pyrometer troubleshooting - erniecarpet@... - 04-11-2006 23:52 Troy, I wonder if you have a bad wire connecting to your sender? Ernie-83pt40 in Louisiana [Non-text portions of this message have been removed] Pyrometer troubleshooting - ttikalsky - 04-12-2006 02:59 Any suggestions on where to start troubleshooting a non-working pyrometer? The guage needle does not move. The guage is a ISSPRO model with both turbo boost and pyrometer in a single 3" guage. The turbo boost works. The motor is a DD8V92 1984 vintage with easy access to the sender. The sender is clean and looks good. Thanks Troy Tikalsky Waconia, MN 1986 Newell 40' Pyrometer troubleshooting - Mike Hohnstein - 04-12-2006 12:36 Change the probe. MH ----- Original Message ----- From: ttikalsky To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, April 12, 2006 9:59 AM Subject: [WanderlodgeForum] Pyrometer troubleshooting Any suggestions on where to start troubleshooting a non-working pyrometer? The guage needle does not move. The guage is a ISSPRO model with both turbo boost and pyrometer in a single 3" guage. The turbo boost works. The motor is a DD8V92 1984 vintage with easy access to the sender. The sender is clean and looks good. Thanks Troy Tikalsky Waconia, MN 1986 Newell 40' SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] Pyrometer troubleshooting - ttikalsky - 06-06-2006 07:11 Before ordering the part I checked the sender for voltage, two wires 1 yellow no voltage and 1 red no voltage. Shouldn't there be 12 volts to the sender when the ignition is on (motor not running)? Troy --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Change the probe. > MH > ----- Original Message ----- > From: ttikalsky > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, April 12, 2006 9:59 AM > Subject: [WanderlodgeForum] Pyrometer troubleshooting > > > Any suggestions on where to start troubleshooting a non-working > pyrometer? The guage needle does not move. The guage is a ISSPRO > model with both turbo boost and pyrometer in a single 3" guage. The > turbo boost works. The motor is a DD8V92 1984 vintage with easy access > to the sender. The sender is clean and looks good. > > Thanks > Troy Tikalsky > Waconia, MN > 1986 Newell 40' > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > ------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------------------ > > > > [Non-text portions of this message have been removed] > |
