power inverter installation - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: power inverter installation (/showthread.php?tid=2448) |
power inverter installation - william sampson - 04-20-2006 18:58 Hi everyone, I have just purchased a Cobra 2500/5000 watt power inverter for my 82 FC 35SB and would like to know if anyone has any suggestions on the installation process such as best placement, whether to run extention cords from the inverter to appliances or if it is possible to hard wire into exiting house system?,and any other advice,safety issues, etc. I prefer not to "RIG" something up and would like to have CLEAN INSTALLATION. ANY ADVICE will be greatly appreciated! also, my coach was formerly known as GYPSY and is custom painted silver with green and blue accents on sides......does anyone recognize this BIRD? If so ,any history will be appreciated! I really do appreciate having this forum and the fine people who make it what it is ,on MY TEAM! THANK YOU ALL FOR ALLOWING ME TO BE A PART OF IT !!!! Dr. Bill Sampson 1982 FC35 SB knoxville,tn. __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] power inverter installation - erniecarpet@... - 04-20-2006 22:57 on the FC's did you have to add extra batteries for the inverter installation? ernie-83pt40 [Non-text portions of this message have been removed] power inverter installation - Tom Warner - 04-21-2006 01:43 Bill this is the time to install the inverter charger right. In my opinion the only place to install the inverter/charger and get the performance that you deserve from the unit is to install it in the front passenger side storage bay. This is the only place that it can be installed and still keep the cables to the batteries short enough to significantly reduce the voltage drop. I would strongly suggest you run 2 plastic water tight electrical tubings (buy it at Homedepot) from the passenger side bin across the front of the frame and then to the Positive battery stud on the inside of the frame and the other one for the negative connection to the shunt supplied with the unit. All of the bluebirds that I have seen have the inverter/chargers installed in the mid bay on the drivers side which is absolutely the incorrect place. If you install the unit there the cable runs to the batteries will be at least 25 feet long and when called to furnish power for the microwave for instance will drop to much voltage even with 4/0 cables. In addition install at least a 10/2 gauge electrical cable between the inverter/charger and a separate sub panel with 4 circuit breakers, one for the rear bedroom receptacles, one for the kitchen receptacles, one for the front receptacles and one for the microwave. Again Homedepot has the Square D panels which are about 4" X 6" long and work nicely. You can see how it is installed if you look at my pictures of the 1982 FC35 I just sold. http://tinyurl.com/lotbd Tom warner Vernon Center,NY 1982 FC35 (sold the first day) 1985 PT 40 At 02:58 AM 4/21/2006, you wrote: >Hi everyone, > I have just purchased a Cobra 2500/5000 watt power inverter for > my 82 FC 35SB and would like to know if anyone has any suggestions > on the installation process such as best placement, whether to run > extention cords from the inverter to appliances or if it is > possible to hard wire into exiting house system?,and any other > advice,safety issues, etc. I prefer not to "RIG" something up and > would like to have CLEAN INSTALLATION. > > ANY ADVICE will be greatly appreciated! > > also, my coach was formerly known as GYPSY and is custom painted > silver with green and blue accents on sides......does anyone > recognize this BIRD? If so ,any history will be appreciated! > > I really do appreciate having this forum and the fine people who > make it what it is ,on MY TEAM! > > THANK YOU ALL FOR ALLOWING ME TO BE A PART OF IT !!!! > > Dr. Bill Sampson > 1982 FC35 SB knoxville,tn. > >__________________________________________________ >Do You Yahoo!? >Tired of spam? Yahoo! Mail has the best spam protection around ><http://mail.yahoo.com>http://mail.yahoo.com > >[Non-text portions of this message have been removed] > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- power inverter installation - Jeff Miller - 04-21-2006 02:24 Although I can appreciate the right-bay installation to keep the cable length down around 10-12', I have had very good service from mid-bay installation and about 20' of 4/0 cable. Mine was wired to run not only the microwave which it did with no problem, but also the rear A/C unit, and did so with minimal voltage drop. As far as installation on the 110v/220v side, there are several methods other than adding a sub-panel, I prefer to run one side of the existing panel through the inverter's internal 50a transfer switch for simplicity, and re-balance the breaker panel to only power inverter-intended circuits. Many ways to install these things, each better for an individual's taste, needs, and skills, plenty of "right ways" to do it if you follow basic electrical design guidelines. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > Bill this is the time to install the inverter charger right. In my > opinion the only place to install the inverter/charger and get the > performance that you deserve from the unit is to install it in the > front passenger side storage bay. This is the only place that it can > be installed and still keep the cables to the batteries short enough > to significantly reduce the voltage drop. I would strongly suggest > you run 2 plastic water tight electrical tubings (buy it at > Homedepot) from the passenger side bin across the front of the frame > and then to the Positive battery stud on the inside of the frame and > the other one for the negative connection to the shunt supplied with > the unit. All of the bluebirds that I have seen have the > inverter/chargers installed in the mid bay on the drivers side which > is absolutely the incorrect place. If you install the unit there the > cable runs to the batteries will be at least 25 feet long and when > called to furnish power for the microwave for instance will drop to > much voltage even with 4/0 cables. > > In addition install at least a 10/2 gauge electrical cable between > the inverter/charger and a separate sub panel with 4 circuit > breakers, one for the rear bedroom receptacles, one for the kitchen > receptacles, one for the front receptacles and one for the microwave. > Again Homedepot has the Square D panels which are about 4" X 6" long > and work nicely. You can see how it is installed if you look at my > pictures of the 1982 FC35 I just sold. http://tinyurl.com/lotbd > > > > > Tom warner > Vernon Center,NY > 1982 FC35 (sold the first day) > 1985 PT 40 > > > At 02:58 AM 4/21/2006, you wrote: > >Hi everyone, > > I have just purchased a Cobra 2500/5000 watt power inverter for > > my 82 FC 35SB and would like to know if anyone has any suggestions > > on the installation process such as best placement, whether to run > > extention cords from the inverter to appliances or if it is > > possible to hard wire into exiting house system?,and any other > > advice,safety issues, etc. I prefer not to "RIG" something up and > > would like to have CLEAN INSTALLATION. > > > > ANY ADVICE will be greatly appreciated! > > > > also, my coach was formerly known as GYPSY and is custom painted > > silver with green and blue accents on sides......does anyone > > recognize this BIRD? If so ,any history will be appreciated! > > > > I really do appreciate having this forum and the fine people who > > make it what it is ,on MY TEAM! > > > > THANK YOU ALL FOR ALLOWING ME TO BE A PART OF IT !!!! > > > > Dr. Bill Sampson > > 1982 FC35 SB knoxville,tn. > > > >__________________________________________________ > >Do You Yahoo!? > >Tired of spam? Yahoo! Mail has the best spam protection around > ><http://mail.yahoo.com>http://mail.yahoo.com > > > >[Non-text portions of this message have been removed] > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- > power inverter installation - Jeff Miller - 04-21-2006 03:21 Never did. However, my '88 did have the optional six. I didn't dry-camp much, and when I did I used the genset every morning to heat water and charge batteries for an hour, so no real need for more batts. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > on the FC's did you have to add extra batteries for the inverter > installation? ernie-83pt40 > > > [Non-text portions of this message have been removed] > power inverter installation - Dan Darst - 04-21-2006 04:13 >From: "Jeff Miller" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Re: power inverter installation >Date: Fri, 21 Apr 2006 14:24:15 -0000 > >Although I can appreciate the right-bay installation to keep the >cable length down around 10-12', I have had very good service from >mid-bay installation and about 20' of 4/0 cable. Mine was wired to >run not only the microwave which it did with no problem, but also the >rear A/C unit, and did so with minimal voltage drop. > >As far as installation on the 110v/220v side, there are several >methods other than adding a sub-panel, I prefer to run one side of >the existing panel through the inverter's internal 50a transfer >switch for simplicity, and re-balance the breaker panel to only power >inverter-intended circuits. Many ways to install these things, each >better for an individual's taste, needs, and skills, plenty of "right >ways" to do it if you follow basic electrical design guidelines. > > - Jeff Miller >in Holland, MI > > >--- In WanderlodgeForum@yahoogroups.com, Tom Warner >wrote: > > > > Bill this is the time to install the inverter charger right. In my > > opinion the only place to install the inverter/charger and get the > > performance that you deserve from the unit is to install it in the > > front passenger side storage bay. This is the only place that it >can > > be installed and still keep the cables to the batteries short >enough > > to significantly reduce the voltage drop. I would strongly suggest > > you run 2 plastic water tight electrical tubings (buy it at > > Homedepot) from the passenger side bin across the front of the >frame > > and then to the Positive battery stud on the inside of the frame >and > > the other one for the negative connection to the shunt supplied >with > > the unit. All of the bluebirds that I have seen have the > > inverter/chargers installed in the mid bay on the drivers side >which > > is absolutely the incorrect place. If you install the unit there >the > > cable runs to the batteries will be at least 25 feet long and when > > called to furnish power for the microwave for instance will drop to > > much voltage even with 4/0 cables. > > > > In addition install at least a 10/2 gauge electrical cable between > > the inverter/charger and a separate sub panel with 4 circuit > > breakers, one for the rear bedroom receptacles, one for the kitchen > > receptacles, one for the front receptacles and one for the >microwave. > > Again Homedepot has the Square D panels which are about 4" X 6" >long > > and work nicely. You can see how it is installed if you look at my > > pictures of the 1982 FC35 I just sold. http://tinyurl.com/lotbd > > > > > > > > > > Tom warner > > Vernon Center,NY > > 1982 FC35 (sold the first day) > > 1985 PT 40 > > > > > > At 02:58 AM 4/21/2006, you wrote: > > >Hi everyone, > > > I have just purchased a Cobra 2500/5000 watt power inverter for > > > my 82 FC 35SB and would like to know if anyone has any >suggestions > > > on the installation process such as best placement, whether to >run > > > extention cords from the inverter to appliances or if it is > > > possible to hard wire into exiting house system?,and any other > > > advice,safety issues, etc. I prefer not to "RIG" something up and > > > would like to have CLEAN INSTALLATION. > > > > > > ANY ADVICE will be greatly appreciated! > > > > > > also, my coach was formerly known as GYPSY and is custom >painted > > > silver with green and blue accents on sides......does anyone > > > recognize this BIRD? If so ,any history will be appreciated! > > > > > > I really do appreciate having this forum and the fine people >who > > > make it what it is ,on MY TEAM! > > > > > > THANK YOU ALL FOR ALLOWING ME TO BE A PART OF IT !!!! > > > > > > Dr. Bill Sampson > > > 1982 FC35 SB knoxville,tn. > > > > > >__________________________________________________ > > >Do You Yahoo!? > > >Tired of spam? Yahoo! Mail has the best spam protection around > > ><http://mail.yahoo.com>http://mail.yahoo.com > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > > > >---------- > > >YAHOO! GROUPS LINKS > > > > > > * Visit your group > > > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" >on the web. > > > * > > > * To unsubscribe from this group, send an email to: > > > * > > > > > > > > > * > > > * Your use of Yahoo! Groups is subject to the > > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > > > > >---------- > > > > > > > power inverter installation - Jay Darst - 04-21-2006 14:55 Jeff, I agree with the 20' of 4/0 cable. Looking at the Ancor Marine Wire size chart... If you had a round trip of 40' of 4/0 wire pulling an Inverter that is supporting a 12.5amp load(1 roof A/C unit)you would experience a 1.8% voltage drop. So if your batteries with no load read 12.7 volts, the new load would cause a voltage drop down to 12.5 volts due to wire resistance. By comparison, if the round trip of 4/0 were to be only say 12', the 12.7 volts would be reduced to 12.6 volts. Both of these examples will work just fine. Put your inverter where its best for it and for you, keep the 4/0 down to 50'. if your inverter is 92% efficient and is rated high enough to pull a 25amp/110volt load, the resistance in the wire will cause a 4.8% reduction in voltage, or 12.7volts will be down to 12.1volts. Of course how long the batterys can susatin this big load depends on the battery bank. If you wanna run the microwave, and it takes 15amps of 110volts, your resistance in the 4/0 will cause a 2.9% reduction in voltage. Or 12.7 volts would be reduced to 12.3volts. This is all based on having a sufficient supply of amps at 12.7volts and that where ever the power is coming from, it can maintain 12.7volts. Check out the wire chart I sent to the files called "Wire Size Chart", it will help you figure out what size wire you need for your projects. Keep in mind, the chart is for the bigger AWG wire sizes instead of the SAE wire sizes. Brother Dan has 40 or 50 feet of 4/0 powering his inverter, mounted in the mid compartment on the pass side. He runs front a/c while cruising. Werks grate with a 320 amp alternator supplying the juice ;~} Jay Darst 85PT40 Springfield, IL where I use 4/0 for all battery connections except from the alt to battery's which is 1/0. All werks grate! --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: I have had very good service from > mid-bay installation and about 20' of 4/0 cable. Mine was wired to > run the rear A/C unit, and did so with minimal voltage drop. > - Jeff Miller > in Holland, MI > |
