commode maint. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: commode maint. (/showthread.php?tid=2462) |
commode maint. - Ralph L. Fullenwider - 04-22-2006 04:30 Spring up time is here! Yea. Ever had a thetford commode not hold water? Here is an easy fix for that problem. 1.Turn off all water sources 2. Hold down the foot pedal to open the flap. 3. You will need a 3/16 " allen wrench or something compairable. CAUTION, do not use a sharp pointed pick, it will damage the rubber seal. 4. There is a groove that the flaper slides into to seal water tight. 5. Run the allen wrench in the groove to clean out tissue that will get stuck there from time to time. 6. Turn on the water and flush, your done. Mama thinks your a hero and it is 6 pack time Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm commode maint. - Stephen Birtles - 04-22-2006 05:25 Sometimes I have trouble holding my water in time it passes Have a great weekend everyone Stephen 77fc35 insulation and ballasts and more --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Spring up time is here! Yea. > > Ever had a thetford commode not hold water? Here is an easy fix for that > problem. > > 1.Turn off all water sources > 2. Hold down the foot pedal to open the flap. > 3. You will need a 3/16 " allen wrench or something compairable. CAUTION, > do not use a sharp pointed pick, it will damage the rubber seal. > 4. There is a groove that the flaper slides into to seal water tight. > 5. Run the allen wrench in the groove to clean out tissue that will get > stuck there from time to time. > 6. Turn on the water and flush, your done. Mama thinks your a hero and it > is 6 pack time > > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > commode maint. - Anthony Louis Pawley - 04-23-2006 07:10 Ralph, thanks for trhe great idea. My Thetford is partially stuck open, and since its finally warm here in Western Washington this weekend, the smell made it all the way to the front, ewwwww! I've been scratching my head as to what to do, and now will get that spare 3/16 allen and weld an extension onto it so I aint cleaning the bowl with my hand as I clean the seal..... Sincerely, Tony Pawley 1979 FC33SB Full Timin it! Ballard, Wash. --------------------------------- Blab-away for as little as 1¢/min. Make PC-to-Phone Calls using Yahoo! Messenger with Voice. [Non-text portions of this message have been removed] |
