Anybody Try Installing an Onan Quiet Diesel? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Anybody Try Installing an Onan Quiet Diesel? (/showthread.php?tid=2465) |
Anybody Try Installing an Onan Quiet Diesel? - erniecarpet@... - 04-22-2006 08:29 Andy- will that Onan produce as much wattage as the Perkins? Erniie-83pt40 [Non-text portions of this message have been removed] Anybody Try Installing an Onan Quiet Diesel? - Andy Coleman - 04-22-2006 12:25 Fellow Wanderlodgers, Has anybody with a pre 87' FC tried installing an Onan Quiet Diesel Generator in place of the Perkins? The dimensions of the 12,500 watt onan seem to allow it to fit into the slide out on a pre- 87' FC. Click on http://www.onan.com/pdf/rv/a-1483.pdf As I have posted earlier, the main thing I don't like about my 83' is the location of that loud Perkins - it forces you to yell to your friend when you are sitting under the main awning. John Finn modified his FC so that the Perkins radiator exhaust blew down to the ground, instead of directly out to were you are sitting. He was also able to close up and sound insulate the entire generator door. According to John, this reduced the noise alot. The Onan Quiet Diesel is designed to blow to the ground. Its sound rating is 68 decibals at 10 feet. It also seems to be very fuel efficient. At idle, it uses .1 gallons/hour. At half load .48 gal/hour. At full load 1.2 gal/hour. The Perkins seems to have just two speeds. Full throttle or off. I can't afford a new onan quiet diesel, but I am looking for a used one. Is it worth installing? Anybody have any experience with this? Andy Coleman 83' FC35 Spring Lake Hts., NJ Anybody Try Installing an Onan Quiet Diesel? - dan - 04-23-2006 01:20 Andy, Your are right it will fit. I have a Onan 12.5 Quiet Diesel installed in my 1981 Wanderlodge. The main problem I have had is I forget to turn it off because it is so quiet. Dan Williams 1981 FCRB Jackson, MS ----- Original Message ----- From: Andy Coleman To: WanderlodgeForum@yahoogroups.com Sent: Saturday, April 22, 2006 7:25 PM Subject: [WanderlodgeForum] Anybody Try Installing an Onan Quiet Diesel? Fellow Wanderlodgers, Has anybody with a pre 87' FC tried installing an Onan Quiet Diesel Generator in place of the Perkins? The dimensions of the 12,500 watt onan seem to allow it to fit into the slide out on a pre- 87' FC. Click on http://www.onan.com/pdf/rv/a-1483.pdf As I have posted earlier, the main thing I don't like about my 83' is the location of that loud Perkins - it forces you to yell to your friend when you are sitting under the main awning. John Finn modified his FC so that the Perkins radiator exhaust blew down to the ground, instead of directly out to were you are sitting. He was also able to close up and sound insulate the entire generator door. According to John, this reduced the noise alot. The Onan Quiet Diesel is designed to blow to the ground. Its sound rating is 68 decibals at 10 feet. It also seems to be very fuel efficient. At idle, it uses .1 gallons/hour. At half load .48 gal/hour. At full load 1.2 gal/hour. The Perkins seems to have just two speeds. Full throttle or off. I can't afford a new onan quiet diesel, but I am looking for a used one. Is it worth installing? Anybody have any experience with this? Andy Coleman 83' FC35 Spring Lake Hts., NJ SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] Anybody Try Installing an Onan Quiet Diesel? - Andy Coleman - 04-23-2006 02:18 Hello Dan, I'm so glad that you responded! Can you tell me how difficult it was to install? How about hooking up - were many of the Wanderlodge guages able to work on the onan? Did you seal off the vent on the generator door? Most importantly, what is the noise like under the main awning? Thanks Dan! Andy --- In WanderlodgeForum@yahoogroups.com, "dan" > > Andy, Your are right it will fit. I have a Onan 12.5 Quiet Diesel installed in my 1981 Wanderlodge. The main problem I have had is I forget to turn it off because it is so quiet. > > Dan Williams > 1981 FCRB > Jackson, MS > ----- Original Message ----- > From: Andy Coleman > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, April 22, 2006 7:25 PM > Subject: [WanderlodgeForum] Anybody Try Installing an Onan Quiet Diesel? > > > Fellow Wanderlodgers, > > Has anybody with a pre 87' FC tried installing an Onan Quiet Diesel > Generator in place of the Perkins? > > The dimensions of the 12,500 watt onan seem to allow it to fit into > the slide out on a pre- 87' FC. Click on > http://www.onan.com/pdf/rv/a-1483.pdf > > As I have posted earlier, the main thing I don't like about my 83' is > the location of that loud Perkins - it forces you to yell to your > friend when you are sitting under the main awning. > > John Finn modified his FC so that the Perkins radiator exhaust blew > down to the ground, instead of directly out to were you are sitting. > He was also able to close up and sound insulate the entire generator > door. According to John, this reduced the noise alot. > > The Onan Quiet Diesel is designed to blow to the ground. Its sound > rating is 68 decibals at 10 feet. > > It also seems to be very fuel efficient. At idle, it uses .1 > gallons/hour. At half load .48 gal/hour. At full load 1.2 gal/hour. > > The Perkins seems to have just two speeds. Full throttle or off. > > I can't afford a new onan quiet diesel, but I am looking for a used one. > > Is it worth installing? Anybody have any experience with this? > > Andy Coleman > 83' FC35 > Spring Lake Hts., NJ > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > ------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------------------ > > > > [Non-text portions of this message have been removed] > Anybody Try Installing an Onan Quiet Diesel? - dan - 04-23-2006 03:28 Andy, It was easy to install. Extremely dirty getting the old one out but the diesel fuel lines were all there and I just ran 10ga to the switch at the door. Exhausted straight out to the street side. As you can see by the photo I don't have a cover for it yet. Used the Onan supplied guages which came with a new hour meter. It is kind of a white noise under the awning. You can hear it running but it is not an offensive noise. I am thinking about selling the coach because I bought an 88 pusher. I may sell the generator separately because most people don't appreciate the value added. They just want a low priced coach. Regards, Dan Jackson 81 33 FC RB ----- Original Message ----- From: Andy Coleman To: WanderlodgeForum@yahoogroups.com Sent: Sunday, April 23, 2006 9:18 AM Subject: [WanderlodgeForum] Re: Anybody Try Installing an Onan Quiet Diesel? Hello Dan, I'm so glad that you responded! Can you tell me how difficult it was to install? How about hooking up - were many of the Wanderlodge guages able to work on the onan? Did you seal off the vent on the generator door? Most importantly, what is the noise like under the main awning? Thanks Dan! Andy --- In WanderlodgeForum@yahoogroups.com, "dan" > > Andy, Your are right it will fit. I have a Onan 12.5 Quiet Diesel installed in my 1981 Wanderlodge. The main problem I have had is I forget to turn it off because it is so quiet. > > Dan Williams > 1981 FCRB > Jackson, MS > ----- Original Message ----- > From: Andy Coleman > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, April 22, 2006 7:25 PM > Subject: [WanderlodgeForum] Anybody Try Installing an Onan Quiet Diesel? > > > Fellow Wanderlodgers, > > Has anybody with a pre 87' FC tried installing an Onan Quiet Diesel > Generator in place of the Perkins? > > The dimensions of the 12,500 watt onan seem to allow it to fit into > the slide out on a pre- 87' FC. Click on > http://www.onan.com/pdf/rv/a-1483.pdf > > As I have posted earlier, the main thing I don't like about my 83' is > the location of that loud Perkins - it forces you to yell to your > friend when you are sitting under the main awning. > > John Finn modified his FC so that the Perkins radiator exhaust blew > down to the ground, instead of directly out to were you are sitting. > He was also able to close up and sound insulate the entire generator > door. According to John, this reduced the noise alot. > > The Onan Quiet Diesel is designed to blow to the ground. Its sound > rating is 68 decibals at 10 feet. > > It also seems to be very fuel efficient. At idle, it uses .1 > gallons/hour. At half load .48 gal/hour. At full load 1.2 gal/hour. > > The Perkins seems to have just two speeds. Full throttle or off. > > I can't afford a new onan quiet diesel, but I am looking for a used one. > > Is it worth installing? Anybody have any experience with this? > > Andy Coleman > 83' FC35 > Spring Lake Hts., NJ > > > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > ------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------------------ > > > > [Non-text portions of this message have been removed] > ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] Anybody Try Installing an Onan Quiet Diesel? - Gary Miller - 04-24-2006 00:45 Andy, If quiet is what you're after, don't forget that you can always downsize the generator. The 31 and 33 came with a 7.5 Kohler (12.5 optional), and the '88-'89 FC's and SP's came with an 8.0Kw Onan. The main (only?) difference being one less air conditioner than the older 35 FC's. I have installed a PowerTech quiet diesel 7.0Kw in place of my Kohler 7.5 and am very satisfied with the performance. A shipping dock and a fork lift are handy, hookups are pretty straightforward for a creative minded vintage BB owner. I guess what I'm saying is that the 12.5 will simply run 'everything' and I would say that a Wanderlodge was built with the impressive overkill to do just that. Is it really necessary? I think not. Run the numbers for yourself based upon your usage requirements and see. Gary Miller 83 FC 33 Milwaukee area --- In WanderlodgeForum@yahoogroups.com, "Andy Coleman" > > Fellow Wanderlodgers, > > Has anybody with a pre 87' FC tried installing an Onan Quiet Diesel > Generator in place of the Perkins? > > The dimensions of the 12,500 watt onan seem to allow it to fit into > the slide out on a pre- 87' FC. Click on > http://www.onan.com/pdf/rv/a-1483.pdf > > As I have posted earlier, the main thing I don't like about my 83' is > the location of that loud Perkins - it forces you to yell to your > friend when you are sitting under the main awning. > > John Finn modified his FC so that the Perkins radiator exhaust blew > down to the ground, instead of directly out to were you are sitting. > He was also able to close up and sound insulate the entire generator > door. According to John, this reduced the noise alot. > > The Onan Quiet Diesel is designed to blow to the ground. Its sound > rating is 68 decibals at 10 feet. > > It also seems to be very fuel efficient. At idle, it uses .1 > gallons/hour. At half load .48 gal/hour. At full load 1.2 gal/hour. > > The Perkins seems to have just two speeds. Full throttle or off. > > I can't afford a new onan quiet diesel, but I am looking for a used one. > > Is it worth installing? Anybody have any experience with this? > > Andy Coleman > 83' FC35 > Spring Lake Hts., NJ > |
