run away engine - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: run away engine (/showthread.php?tid=2481) |
run away engine - emc2jb6 - 04-26-2006 01:07 lets not get all worked up about a run-away engine. think -fuel this engine will not run without fuel. go to your fuel filter where the shut off valve is. the valve iam talking about is the valve you turn off when you are changing your fuel filter. close this valve and the engine will die- end of trouble. ed mcstay "lonesome dove" 83fcrb lake charles la. run away engine - Mike Hohnstein - 04-26-2006 01:55 Not bad advice but it will take a while to use up the fuel in the system up stream of the valve. Considering the OEM air filter would take a bit of time to remove, Ed's suggestion is very good. If one is concerned about such a happening, make sure there is a fuel line shut off valve close to the injector pump. Mike Hohnstein ----- Original Message ----- From: emc2jb6 To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, April 26, 2006 8:07 AM Subject: [WanderlodgeForum] run away engine lets not get all worked up about a run-away engine. think -fuel this engine will not run without fuel. go to your fuel filter where the shut off valve is. the valve iam talking about is the valve you turn off when you are changing your fuel filter. close this valve and the engine will die- end of trouble. ed mcstay "lonesome dove" 83fcrb lake charles la. ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
