power steering pump - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: power steering pump (/showthread.php?tid=2499) |
power steering pump - emc2jb6 - 04-29-2006 09:52 ANDY- THAT PS PUMP IS BUILT LIKE A DUMP TRUCK AND IS VERY EASY TO REBUILD,TWO BEARINGS AND ONE SEAL. I DO NOT HAVE NUMBERS FOR THE BEARINGS OR OIL SEAL BUT THEY ARE COMMON AND I PICKED THEM UP AT THE LOCAL BEARING HOUSE. JUST WALKED OUT TO THE BUS TO SEE IF I HAD THE NUMBERS BUT DO NOT. ABOUT THE ONLY WAY TO TEAR UP THAT PUMP IS TO RUN IT DRY FOR A GOOD WHILE,YOU CANT HARDLEY DO THAT BECAUSE WITH IT DRY YOU CANT STEER THE BUS. ONE OTHER PROBLEM I HAVE IS A LEAK IN THE STEERING BOX. I HAVE NOT GOTTEN TO IT YET BUT IT IS SOMETHING YOU MAY WANT TO LOOK AT ON YOUR RIG.WHILE YOU HAVE IT ALL OPEN WASH IT ALL GOOD WITH A DEGREASER SO YOU CAN TELL IF YOU HAVE OTHER DRIPS. I USE SIMPLE GREEN ON SMALL JOBS AND IT SMELLS GOOD. GO FOR IT. ED MCSTAY "LONESOME DOVE' 83 fc rear bath lake charles,la. power steering pump - randydupree2000 - 04-29-2006 23:47 --- In WanderlodgeForum@yahoogroups.com, "emc2jb6" wrote: >Ed,read my post about the return line on your PS system,if you need more info on getting to the steering box i can help.i just did that job last week. randy dupree > ANDY- THAT PS PUMP IS BUILT LIKE A DUMP TRUCK AND IS VERY EASY TO > REBUILD,TWO BEARINGS AND ONE SEAL. I DO NOT HAVE NUMBERS FOR THE > BEARINGS OR OIL SEAL BUT THEY ARE COMMON AND I PICKED THEM UP AT THE > LOCAL BEARING HOUSE. JUST WALKED OUT TO THE BUS TO SEE IF I HAD THE > NUMBERS BUT DO NOT. ABOUT THE ONLY WAY TO TEAR UP THAT PUMP IS TO RUN > IT DRY FOR A GOOD WHILE,YOU CANT HARDLEY DO THAT BECAUSE WITH IT DRY > YOU CANT STEER THE BUS. > ONE OTHER PROBLEM I HAVE IS A LEAK IN THE STEERING BOX. I HAVE NOT > GOTTEN TO IT YET BUT IT IS SOMETHING YOU MAY WANT TO LOOK AT ON YOUR > RIG.WHILE YOU HAVE IT ALL OPEN WASH IT ALL GOOD WITH A DEGREASER SO YOU > CAN TELL IF YOU HAVE OTHER DRIPS. I USE SIMPLE GREEN ON SMALL JOBS AND > IT SMELLS GOOD. GO FOR IT. > > ED MCSTAY > "LONESOME DOVE' > 83 fc rear bath > lake charles,la. > power steering pump - Juergen - 09-16-2008 06:18
power steering pump - mbulriss - 09-16-2008 06:45 Juergen, Go into the Parts Database and search on "Power Steering Pump". There are 6 references posted by members. Mike H. recommended Power Steering Specialists in Columbus OH area at 800-235-3076, so I might start with them. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, Juergen wrote: > > Does any body know where one could find a new or re-built power steering pump? > It would be for a 1991 WLSP 36. > Are parts then really impossible to find if you have an older coach? > How do you guys keep theese older 1991 and back running? > Juergen in PA > 1991 WLSP36 > power steering pump - Juergen - 09-18-2008 12:36
