antifreeze/ forgot to tell - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: antifreeze/ forgot to tell (/showthread.php?tid=2506) |
antifreeze/ forgot to tell - mjzakowski - 04-30-2006 03:11 New motor put in 2000 by ARMS Inc.in Anna OH. We brought it in 2002 and it has never been in winter months. Greg you said to do the cheapest gasket repair. What's that? Also I notice that it stayes near normal operating temperatures on the HWY. On idle the water temp starts to go up. Their is only 13,700 miles on the rebuilt motor. Thanks for your input Joe 1984 1/2 PT 40 antifreeze/ forgot to tell - Gregory OConnor - 04-30-2006 04:35 Joe, cheapest is relative. In the Detroit 6V you can do an inframe and repair just that which is broken. On the Cat 3208 if you have a prob. with one cyl the block has no replaceable sleeves and must be removed and sent out to a shop (Detroit 8.2 is the same). They call the DD 8.2 and Cat 3208 throwaway engines but the Cat proves to be a Rock (many feel Cat built the 3208 stronger because it had no inframe buildability). Tom W, Randy, Mike, and the others can best give you advice, but there is more testing and review that cant be done via a keyboard. I would call on the shop that did the rebuild in 2002. They may have a Mobil Tech in your area or know of one. These engines get one million miles but that is with inframes and many repairs along the way. RV people tend to over fix things. If a good tech can find a leaking sleeve (??p test each cyl ) I would replace just that cylinder sleeve. Your effort would be best spent finding a good tec/ problem solver than a good certified rebuild/replace shop. Last week I bought 4 tires for my Vega at Pepboys and the service clerk asked if I wanted road hazzard tire replacement protection at 6.99 per tire. I bought it on only one tire (as he protested). What are the chances of having 4 flats?? Gregory O'Connor 94pt40 Romoland Ca relatively the cheapest forum member --- In WanderlodgeForum@yahoogroups.com, "mjzakowski" <mjzakowski@...> wrote: > > New motor put in 2000 by ARMS Inc.in Anna OH. We brought it in 2002 and > it has never been in winter months. > Greg you said to do the cheapest gasket repair. What's that? > Also I notice that it stayes near normal operating temperatures on the > HWY. On idle the water temp starts to go up. > Their is only 13,700 miles on the rebuilt motor. > Thanks for your input > Joe 1984 1/2 PT 40 > |
