Doghouse Insulation - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Doghouse Insulation (/showthread.php?tid=2522) |
Doghouse Insulation - Stephen H - 05-03-2006 13:44 Hi Group- I know there is always discussion in this topic, I have reviewed the threads. I just reviewed the link to John Finn's 1982 doghouse insulation. I cannot seem to find a common method of application. Do you use the spray glue? Or just apply directly. I received the insulation from Stephen Birtles. It seems very sticky. Do most cut a template out of paper or cardboard, and then cut out the insulation? Or is it wise to cut the insulation to fit? The top part of the house seems to be the most challenging, around the curved top areas, where the 2 pieces split. Is it wise to add some fender washers after the insulation is on to keep it there? Thank you Stephen 81 FC-33SB Plant City,FL Doghouse Insulation - davidkerryedwards - 05-03-2006 14:42 I made paper patterns. You're too late. I offered them to the group a few weeks ago but now I've thrown them away. I used the spray glue that came with insulation I bought from JC Whitney. Took a couple of hours once the lid was off the doghouse. I just used sheets of paper and taped them together. Didn't need any washers. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@...> wrote: > > Hi Group- I know there is always discussion in this topic, I have > reviewed the threads. I just reviewed the link to John Finn's 1982 > doghouse insulation. I cannot seem to find a common method of > application. Do you use the spray glue? Or just apply directly. I > received the insulation from Stephen Birtles. It seems very sticky. Do > most cut a template out of paper or cardboard, and then cut out the > insulation? Or is it wise to cut the insulation to fit? The top part > of the house seems to be the most challenging, around the curved top > areas, where the 2 pieces split. Is it wise to add some fender washers > after the insulation is on to keep it there? > Thank you > Stephen > 81 FC-33SB > Plant City,FL > Doghouse Insulation - erniecarpet@... - 05-04-2006 05:34 I know we have used the mylar faced insulation to keep the heat out of the coach. But is there an insulation out that will do that and also absorb the sound? It seems that the Mylar faced will keep bouncing noise around and that it makes its way out the radiator and any other opening in that compartment. Ernie-83pt40 in Texas, trying to dry out from all the rain [Non-text portions of this message have been removed] Doghouse Insulation - Jeff Miller - 05-04-2006 09:16 I've used 3M-77 spray contact adheasive, held for the 6years I had the coach, a couple of years since. Cleaned it with a putty-knife, very little remaining, made the doghouse cover (top part) in one piece so that it holds itself pretty well. The contact adheasive has to be applied properly, and the foam soaks it up so the foam side has to be applied liberally, if you do it wrong I'm sure it will fail. Others have used 3M-90, a stronger version, probably a good idea. I also applied one to a doghouse which was the pressure-sensitive backing, stuck very well. Clean the surface first for best results. Another FC I had I applied a lead quilted product, very expensive and very heavy, it needed to be mechanically fastened which worked well as the lead inner layer keeps its shape between fasteners. I drilled the fasteners through from the carpet side before carpeting, the flat sheet-metal plates hide well under there. I feel that all methods work if properly prepared/used, I've had no failures. Just like painting, prep is the most important step. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@...> wrote: > > Hi Group- I know there is always discussion in this topic, I have > reviewed the threads. I just reviewed the link to John Finn's 1982 > doghouse insulation. I cannot seem to find a common method of > application. Do you use the spray glue? Or just apply directly. I > received the insulation from Stephen Birtles. It seems very sticky. Do > most cut a template out of paper or cardboard, and then cut out the > insulation? Or is it wise to cut the insulation to fit? The top part > of the house seems to be the most challenging, around the curved top > areas, where the 2 pieces split. Is it wise to add some fender washers > after the insulation is on to keep it there? > Thank you > Stephen > 81 FC-33SB > Plant City,FL > Doghouse Insulation - Stephen - 05-04-2006 13:49 Thank all who replied in this matter. I will give it a go this weekend, and see how it sticks! I will post pics in the wanderlodge forum, under photos section- wanderlodge3208 1981 restoration pics. Thanks again all Stephen 81 FC-33SB Plant City, Fl _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Jeff Miller Sent: Thursday, May 04, 2006 5:17 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Doghouse Insulation I've used 3M-77 spray contact adheasive, held for the 6years I had the coach, a couple of years since. Cleaned it with a putty-knife, very little remaining, made the doghouse cover (top part) in one piece so that it holds itself pretty well. The contact adheasive has to be applied properly, and the foam soaks it up so the foam side has to be applied liberally, if you do it wrong I'm sure it will fail. Others have used 3M-90, a stronger version, probably a good idea. I also applied one to a doghouse which was the pressure-sensitive backing, stuck very well. Clean the surface first for best results. Another FC I had I applied a lead quilted product, very expensive and very heavy, it needed to be mechanically fastened which worked well as the lead inner layer keeps its shape between fasteners. I drilled the fasteners through from the carpet side before carpeting, the flat sheet-metal plates hide well under there. I feel that all methods work if properly prepared/used, I've had no failures. Just like painting, prep is the most important step. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Stephen H" <share@...> wrote: > > Hi Group- I know there is always discussion in this topic, I have > reviewed the threads. I just reviewed the link to John Finn's 1982 > doghouse insulation. I cannot seem to find a common method of > application. Do you use the spray glue? Or just apply directly. I > received the insulation from Stephen Birtles. It seems very sticky. Do > most cut a template out of paper or cardboard, and then cut out the > insulation? Or is it wise to cut the insulation to fit? The top part > of the house seems to be the most challenging, around the curved top > areas, where the 2 pieces split. Is it wise to add some fender washers > after the insulation is on to keep it there? > Thank you > Stephen > 81 FC-33SB > Plant City,FL > SPONSORED LINKS Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> vehicles Wanderlodge <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> maintenance Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer Used <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> radiators _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed] Doghouse Insulation - erniecarpet@... - 05-04-2006 20:30 Stephen- don't forget to get the foil tape to cover your seams. Makes the job look great. Ernie-83pt40 in Texas [Non-text portions of this message have been removed] |
