Leveling Jack Fluid - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Leveling Jack Fluid (/showthread.php?tid=2551) |
Leveling Jack Fluid - olson_phil - 05-08-2006 05:21 Can someone verify for me that I should use Auto Transmission Fluid for the HWH leveling jacks? Any special type? Thanks. Phil Olson 83FC35SB Appleton, WI Leveling Jack Fluid - Rob Robinson - 05-08-2006 05:50 Phil I have a 94 and the manual says to use quote "universal, multipurpose or Dexron transmission fluid. DO NOT USE brake fluid or hydraulic jack fluid. Use of these fluids can damage seal." unquote On 5/8/06, olson_phil > > Can someone verify for me that I should use Auto Transmission Fluid > for the HWH leveling jacks? Any special type? > Thanks. > Phil Olson > 83FC35SB > Appleton, WI > > > > > > > > Yahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed] Leveling Jack Fluid - pattypape - 05-08-2006 05:53 The red stuff, Dextron II or Dextron III Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "olson_phil" > > Can someone verify for me that I should use Auto Transmission Fluid > for the HWH leveling jacks? Any special type? > Thanks. > Phil Olson > 83FC35SB > Appleton, WI > |
