Microphor compressor needed - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Microphor compressor needed (/showthread.php?tid=2566) Pages: 1 2 |
Microphor compressor needed - p_a_lazar - 05-09-2006 10:53 Anyone have suggestion for best price on Microphor toilet compressor. Seems my teflon seals are gone and I understand there isn't a repair kit. So gonna bite the bullet and actually buy another. I have a call into Microphor, but so far their customer service folks haven't called me back. Other suggestions welcomed. Paul 97wb43 Microphor compressor needed - Rob Robinson - 05-09-2006 12:13 Paul I may be wrong here but I think Randy might have what you want. On 09/05/06, p_a_lazar > > Anyone have suggestion for best price on Microphor toilet compressor. > > Seems my teflon seals are gone and I understand there isn't a repair > kit. So gonna bite the bullet and actually buy another. > > I have a call into Microphor, but so far their customer service folks > haven't called me back. Other suggestions welcomed. > > Paul > 97wb43 > > > > > > > > > Yahoo! Groups Links > > > > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] Microphor compressor needed - John Suter - 05-09-2006 23:17 Hi Paul, Can't tell you where to find a replacement. However, I'd suggest you consider having the air "plumbing" re-done to permit all air compressors to perform all air functions to avoid the repeat failure trap. Many of us have done it and are happy with the results. In the meantime, keep your old 12V compressor(s) in the event someone bites the bullet and decides to purchase the minimum order for replacement teflon seal/piston cup(s). I looked into it a year or two ago and found the minimum was 1M of the items for about $1,000. Sounded like a reasonable investment for some firm to make to refurbish the little devils, but I'm still waiting with a box of the otherwise perfect 12V compressors. John Suter 2000LXi --- p_a_lazar > Anyone have suggestion for best price on Microphor > toilet compressor. > > Seems my teflon seals are gone and I understand > there isn't a repair > kit. So gonna bite the bullet and actually buy > another. > > I have a call into Microphor, but so far their > customer service folks > haven't called me back. Other suggestions welcomed. > > Paul > 97wb43 > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com Microphor compressor needed - Curt Sprenger - 05-10-2006 02:25 John, "plumbing" re-done to permit all air compressors to perform all air functions to avoid the repeat failure trap... Great idea. I've put that on my Bird work-item list. Our coach axillary and toilet compressors are stacked one above the other in a bay. Should make the modification easier. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. John Suter wrote: > Hi Paul, > > Can't tell you where to find a replacement. > However, I'd suggest you consider having the air > "plumbing" re-done to permit all air compressors to > perform all air functions to avoid the repeat failure > trap. Many of us have done it and are happy with the > results. > > In the meantime, keep your old 12V compressor(s) in > the event someone bites the bullet and decides to > purchase the minimum order for replacement teflon > seal/piston cup(s). I looked into it a year or two > ago and found the minimum was 1M of the items for > about $1,000. Sounded like a reasonable investment > for some firm to make to refurbish the little devils, > but I'm still waiting with a box of the otherwise > perfect 12V compressors. > Microphor compressor needed - John Suter - 05-10-2006 03:44 Hi Curt, The mod requires a couple of check valves, "T's," and combination regulator/meters, a bit of planning/thinking and you'll be in business. A common modification diagram floating around, only adds engine and 110V compressor air to toilet, and keeps the existing 12V air as is, rather than create an "all for all" system; therefore, I recommend first drawing your layout on paper. Note the "plumbing location" of the current microphor pressure regulator(s) as many have been moved, some have two, etc. Last, don't overlook air driven sewer-dump valves in the planning. Doubt you'll have to physically move anything, but if you do, consider re-locating the reserve air tank moisture drain-line for more convenient access than original. Add a master "on/off" switch close to the 12V compressor, if the original did not come with one, and plumb/set the 12V compressor to be the compressor of last resort (to preserve it). You already have the ability to shut off the 110V compressor from the dash. John Suter --- Curt Sprenger > John, > "plumbing" re-done to permit all air compressors to > perform all air functions to avoid the repeat > failure > trap... > > Great idea. I've put that on my Bird work-item list. > Our coach axillary > and toilet compressors are stacked one above the > other in a bay. Should > make the modification easier. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > John Suter wrote: > > > Hi Paul, > > > > Can't tell you where to find a replacement. > > However, I'd suggest you consider having the air > > "plumbing" re-done to permit all air compressors > to > > perform all air functions to avoid the repeat > failure > > trap. Many of us have done it and are happy with > the > > results. > > > > In the meantime, keep your old 12V compressor(s) > in > > the event someone bites the bullet and decides to > > purchase the minimum order for replacement teflon > > seal/piston cup(s). I looked into it a year or > two > > ago and found the minimum was 1M of the items for > > about $1,000. Sounded like a reasonable > investment > > for some firm to make to refurbish the little > devils, > > but I'm still waiting with a box of the otherwise > > perfect 12V compressors. > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com Microphor compressor needed - erniecarpet@... - 05-10-2006 03:49 John, you can add a piicture in our photo section, if that would help. ernie-83pt40 in Texas [Non-text portions of this message have been removed] Microphor compressor needed - Curt Sprenger - 05-10-2006 03:50 Paul, I got these prices from *San Diego Marine Exchange, *2636 Shelter Island Drive, San Diego CA 92106...(619) 223-7159 ...complete unit $655.00, pump/motor $310.00. Plus shipping. This is the Model 5000 that is in our Bird. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. John Suter wrote: > Hi Paul, > > Can't tell you where to find a replacement. > However, I'd suggest you consider having the air > "plumbing" re-done to permit all air compressors to > perform all air functions to avoid the repeat failure > trap. Many of us have done it and are happy with the > results. > > In the meantime, keep your old 12V compressor(s) in > the event someone bites the bullet and decides to > purchase the minimum order for replacement teflon > seal/piston cup(s). I looked into it a year or two > ago and found the minimum was 1M of the items for > about $1,000. Sounded like a reasonable investment > for some firm to make to refurbish the little devils, > but I'm still waiting with a box of the otherwise > perfect 12V compressors. > > > John Suter > 2000LXi > > > > --- p_a_lazar > > > Anyone have suggestion for best price on Microphor > > toilet compressor. > > > > Seems my teflon seals are gone and I understand > > there isn't a repair > > kit. So gonna bite the bullet and actually buy > > another. > > > > I have a call into Microphor, but so far their > > customer service folks > > haven't called me back. Other suggestions welcomed. > > > > Paul > > 97wb43 > > > > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehic\ les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\ onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\ c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> > Recreational vehicle financing > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+financing&w1=Recreatio\ nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\ =Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\ cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> > Recreational vehicle repair > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+repair&w1=Recreational\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> > > Recreational vehicle rental > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rental&w1=Recreational\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> > Recreational vehicle camper > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+camper&w1=Recreational\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> > Recreational vehicle rate > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rate&w1=Recreational+v\ ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\ eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\ ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > Microphor compressor needed - Curt Sprenger - 05-10-2006 04:01 Hi John, Thank you for the information. I'll save it for when I get to that project. I added the on/off switch for the 12v compressor. Actually I believe I have two switches now. One is in the bay by the compressor and the other one that I added is inside of the coach for easy access. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. John Suter wrote: > Hi Curt, > > The mod requires a couple of check valves, "T's," > and combination regulator/meters, a bit of > planning/thinking and you'll be in business. A common > modification diagram floating around, only adds engine > and 110V compressor air to toilet, and keeps the > existing 12V air as is, rather than create an "all for > all" system; therefore, I recommend first drawing your > layout on paper. Note the "plumbing location" of the > current microphor pressure regulator(s) as many have > been moved, some have two, etc. Last, don't overlook > air driven sewer-dump valves in the planning. > > Doubt you'll have to physically move anything, but > if you do, consider re-locating the reserve air tank > moisture drain-line for more convenient access than > original. Add a master "on/off" switch close to the > 12V compressor, if the original did not come with one, > and plumb/set the 12V compressor to be the compressor > of last resort (to preserve it). You already have the > ability to shut off the 110V compressor from the dash. > > John Suter > Microphor compressor needed - John Suter - 05-10-2006 07:10 Hi Curt, As Yahoo doesn't permit attachments, I've send a picture of the Thomas Compressor unit manufactured in Sheboygan WI direct (to Curt). For other Forum members, the unit BB installed on the 2000LXi, and many others I've seen around that model year, is Model No 405ADC38/12F. I believe BB sold them for about $200 in 2005 so I'm confused by the pricing and Model shown below. John Suter --- Curt Sprenger > Paul, > I got these prices from *San Diego Marine Exchange, > *2636 Shelter Island > Drive, San Diego CA 92106...(619) 223-7159 > ...complete unit $655.00, > pump/motor $310.00. Plus shipping. This is the Model > 5000 that is in our > Bird. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > John Suter wrote: > > > Hi Paul, > > > > Can't tell you where to find a replacement. > > However, I'd suggest you consider having the air > > "plumbing" re-done to permit all air compressors > to > > perform all air functions to avoid the repeat > failure > > trap. Many of us have done it and are happy with > the > > results. > > > > In the meantime, keep your old 12V compressor(s) > in > > the event someone bites the bullet and decides to > > purchase the minimum order for replacement teflon > > seal/piston cup(s). I looked into it a year or > two > > ago and found the minimum was 1M of the items for > > about $1,000. Sounded like a reasonable > investment > > for some firm to make to refurbish the little > devils, > > but I'm still waiting with a box of the otherwise > > perfect 12V compressors. > > > > > > John Suter > > 2000LXi > > > > > > > > --- p_a_lazar > > > > > Anyone have suggestion for best price on > Microphor > > > toilet compressor. > > > > > > Seems my teflon seals are gone and I understand > > > there isn't a repair > > > kit. So gonna bite the bullet and actually buy > > > another. > > > > > > I have a call into Microphor, but so far their > > > customer service folks > > > haven't called me back. Other suggestions > welcomed. > > > > > > Paul > > > 97wb43 > > > > > > > > > > > > > > > > > > > > > __________________________________________________ > > Do You Yahoo!? > > Tired of spam? Yahoo! Mail has the best spam > protection around > > http://mail.yahoo.com > > > > > > SPONSORED LINKS > > Recreational vehicles > > > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehic\ les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\ onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\ c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> > > > Recreational vehicle financing > > > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+financing&w1=Recreatio\ nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\ =Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\ cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> > > > Recreational vehicle repair > > > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+repair&w1=Recreational\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> > > > > > Recreational vehicle rental > > > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rental&w1=Recreational\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> > > > Recreational vehicle camper > > > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+camper&w1=Recreational\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> > > > Recreational vehicle rate > > > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rate&w1=Recreational+v\ ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\ eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\ ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> > > > > > > > > > > ------------------------------------------------------------------------ > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > > > <http://groups.yahoo.com/group/WanderlodgeForum>" on > the web. > > > > * To unsubscribe from this group, send an > email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > * Your use of Yahoo! Groups is subject to the > Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > > ------------------------------------------------------------------------ > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com Microphor compressor needed - Curt Sprenger - 05-10-2006 08:37 Hi John, The compressor in our Bird looks completely different than in your picture. The unit we have is labeled a Microphor Model 5000. It looks just like a 120V pancake compressor, only it's 12V. A new unit costs $655. Looks like the unit you have would be the way to go as long as it supplies enough air. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. John Suter wrote: > Hi Curt, > > As Yahoo doesn't permit attachments, I've send a > picture of the Thomas Compressor unit manufactured in > Sheboygan WI direct (to Curt). For other Forum > members, the unit BB installed on the 2000LXi, and > many others I've seen around that model year, is Model > No 405ADC38/12F. I believe BB sold them for about > $200 in 2005 so I'm confused by the pricing and Model > shown below. > > John Suter > > > --- Curt Sprenger > > > Paul, > > I got these prices from *San Diego Marine Exchange, > > *2636 Shelter Island > > Drive, San Diego CA 92106...(619) 223-7159 > > ...complete unit $655.00, > > pump/motor $310.00. Plus shipping. This is the Model > > 5000 that is in our > > Bird. > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > John Suter wrote: > > > > > Hi Paul, > > > > > > Can't tell you where to find a replacement. > > > However, I'd suggest you consider having the air > > > "plumbing" re-done to permit all air compressors > > to > > > perform all air functions to avoid the repeat > > failure > > > trap. Many of us have done it and are happy with > > the > > > results. > > > > > > In the meantime, keep your old 12V compressor(s) > > in > > > the event someone bites the bullet and decides to > > > purchase the minimum order for replacement teflon > > > seal/piston cup(s). I looked into it a year or > > two > > > ago and found the minimum was 1M of the items for > > > about $1,000. Sounded like a reasonable > > investment > > > for some firm to make to refurbish the little > > devils, > > > but I'm still waiting with a box of the otherwise > > > perfect 12V compressors. > > > > > > > > > John Suter > > > 2000LXi > > > > > > > > > > > > --- p_a_lazar > > > > > > > Anyone have suggestion for best price on > > Microphor > > > > toilet compressor. > > > > > > > > Seems my teflon seals are gone and I understand > > > > there isn't a repair > > > > kit. So gonna bite the bullet and actually buy > > > > another. > > > > > > > > I have a call into Microphor, but so far their > > > > customer service folks > > > > haven't called me back. Other suggestions > > welcomed. > > > > > > > > Paul > > > > 97wb43 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________ > > > Do You Yahoo!? > > > Tired of spam? Yahoo! Mail has the best spam > > protection around > > > http://mail.yahoo.com > > > > > > > > > SPONSORED LINKS > > > Recreational vehicles > > > > > > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehic\ les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\ onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\ c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehic\ les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\ onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\ c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w>> > > > > > Recreational vehicle financing > > > > > > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+financing&w1=Recreatio\ nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\ =Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\ cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+financing&w1=Recreatio\ nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\ =Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\ cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg>> > > > > > Recreational vehicle repair > > > > > > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+repair&w1=Recreational\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+repair&w1=Recreational\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ>> > > > > > > > > Recreational vehicle rental > > > > > > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rental&w1=Recreational\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rental&w1=Recreational\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA>> > > > > > Recreational vehicle camper > > > > > > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+camper&w1=Recreational\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+camper&w1=Recreational\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ>> > > > > > Recreational vehicle rate > > > > > > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rate&w1=Recreational+v\ ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\ eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\ ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rate&w1=Recreational+v\ ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\ eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\ ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw>> > > > > > > > > > > > > > > > > > ------------------------------------------------------------------------ > > > YAHOO! GROUPS LINKS > > > > > > * Visit your group "WanderlodgeForum > > > > > <http://groups.yahoo.com/group/WanderlodgeForum>" on > > the web. > > > > > > * To unsubscribe from this group, send an > > email to: > > > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > > > > > * Your use of Yahoo! Groups is subject to the > > Yahoo! Terms of > > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > > > > > > > ------------------------------------------------------------------------ > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehic\ les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\ onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\ c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> > Recreational vehicle financing > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+financing&w1=Recreatio\ nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\ =Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\ cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> > Recreational vehicle repair > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+repair&w1=Recreational\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> > > Recreational vehicle rental > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rental&w1=Recreational\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> > Recreational vehicle camper > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+camper&w1=Recreational\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> > Recreational vehicle rate > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rate&w1=Recreational+v\ ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\ eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\ ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
