89sp telescoping steering stuck - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 89sp telescoping steering stuck (/showthread.php?tid=2584) |
89sp telescoping steering stuck - ED GARDELS - 05-11-2006 05:24 When I first bought this rig last year, Itried the telescoping wheel and it worked(dont remember if I moved it up or down). I havent been able to move it since. I removed the two blake covers around the coulmn but still cant get it to budge either up or down. I know about loosening the hub, counterclockwise to adjust, and clockwise to tighten any help will be welcomed Thanks Ed Gardels 89sp Arlington Texas 89sp telescoping steering stuck - Jeff Miller - 05-11-2006 07:27 Pry off the top of the steering wheel center (the part with the horn button in the middle, leaving the indented-black knob surround), you will see the mechanism beneath it. It is possible that the nut came loose and the lock mechanism stop somehow got rotated out of position. The wheel center should turn freely when in the loose/telescope position. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "ED GARDELS" wrote: > > When I first bought this rig last year, Itried the telescoping wheel > and it worked(dont remember if I moved it up or down). I havent been > able to move it since. I removed the two blake covers around the > coulmn but still cant get it to budge either up or down. I know about > loosening the hub, counterclockwise to adjust, and clockwise to tighten > any help will be welcomed > Thanks > Ed Gardels 89sp > Arlington Texas > 89sp telescoping steering stuck - pattypape - 05-11-2006 09:17 Hi ED, In addition to Jeff's suggestion, Be careful with the yellow horn wire, It is very short, the push on wire tab connector is easily bent, Then the horn blows making left/ right turns. We and especially other drivers, did not like this intermittent horn. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "ED GARDELS" wrote: > > When I first bought this rig last year, Itried the telescoping wheel > and it worked(dont remember if I moved it up or down). I havent been > able to move it since. I removed the two blake covers around the > coulmn but still cant get it to budge either up or down. I know about > loosening the hub, counterclockwise to adjust, and clockwise to tighten > any help will be welcomed > Thanks > Ed Gardels 89sp > Arlington Texas > 89sp telescoping steering stuck - ED GARDELS - 05-13-2006 08:45 --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" >Thanks for the response Jeff, I just came in after fixing my steering wheel... your fix was right on.. nut was loose.. Many thanks Ed Gardels 89sp Arlington Texas > Pry off the top of the steering wheel center (the part with the horn > button in the middle, leaving the indented-black knob surround), you > will see the mechanism beneath it. It is possible that the nut came > loose and the lock mechanism stop somehow got rotated out of position. > The wheel center should turn freely when in the loose/telescope > position. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "ED GARDELS" > wrote: > > > > When I first bought this rig last year, Itried the telescoping > wheel > > and it worked(dont remember if I moved it up or down). I havent been > > able to move it since. I removed the two blake covers around the > > coulmn but still cant get it to budge either up or down. I know about > > loosening the hub, counterclockwise to adjust, and clockwise to > tighten > > any help will be welcomed > > Thanks > > Ed Gardels 89sp > > Arlington Texas > > > 89sp telescoping steering stuck - ED GARDELS - 05-13-2006 08:48 --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > Thanks Bill for the help.. I did run across the shorting of the horn wire.. I fixed it by a little liquid electric tape.. Thanks Ed Gardels 89sp Arlington Texas > > Hi ED, > > In addition to Jeff's suggestion, > Be careful with the yellow horn wire, It is very short, the push on > wire tab connector is easily bent, > Then the horn blows making left/ right turns. > We and especially other drivers, did not like this intermittent horn. > > Bill 88 FC > > > > --- In WanderlodgeForum@yahoogroups.com, "ED GARDELS" > wrote: > > > > When I first bought this rig last year, Itried the telescoping > wheel > > and it worked(dont remember if I moved it up or down). I havent been > > able to move it since. I removed the two blake covers around the > > coulmn but still cant get it to budge either up or down. I know > about > > loosening the hub, counterclockwise to adjust, and clockwise to > tighten > > any help will be welcomed > > Thanks > > Ed Gardels 89sp > > Arlington Texas > > > |
