1980 Rod to Air Hose on Front Suspension - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 1980 Rod to Air Hose on Front Suspension (/showthread.php?tid=2637) |
1980 Rod to Air Hose on Front Suspension - shawn_fountain - 05-18-2006 14:54 There is a rod going up and down from the center of the front suspension that is causing air to dump when I do not want the air to dump, or at least if I mess with that rod air stops dumping. Anyone know what that rod is for, and if okay for me to just adjust it (up I think) to stop the air from dumping out. I did have the bus on a sloping street lifted high on the sidewalk side to make level, but I have had intermittent large air leaks from the same place for a long time. Also, there is a junction of I think 3 air hoses near this spot. Anyone know where these are going? I appear to only be using 2 of the 3, and the 3rd appears abandoned by a prior owner. Tks, SDF 80FC35 Boulder 1980 Rod to Air Hose on Front Suspension - shawn_fountain - 05-18-2006 14:55 There is a rod going up and down from the center of the front suspension that is causing air to dump when I do not want the air to dump, or at least if I mess with that rod air stops dumping. Anyone know what that rod is for, and if okay for me to just adjust it (up I think) to stop the air from dumping out. I did have the bus on a sloping street lifted high on the sidewalk side to make level, but I have had intermittent large air leaks from the same place for a long time. Also, there is a junction of I think 3 air hoses near this spot. Anyone know where these are going? I appear to only be using 2 of the 3, and the 3rd appears abandoned by a prior owner. Tks, SDF 80FC35 Boulder 1980 Rod to Air Hose on Front Suspension - Mike Hohnstein - 05-18-2006 23:27 Suspension leveling valve, rod connects to the AXLE. There are two on the rear axle. Be careful under there, you could die. MH ----- Original Message ----- From: shawn_fountain To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 18, 2006 9:55 PM Subject: [WanderlodgeForum] 1980 Rod to Air Hose on Front Suspension There is a rod going up and down from the center of the front suspension that is causing air to dump when I do not want the air to dump, or at least if I mess with that rod air stops dumping. Anyone know what that rod is for, and if okay for me to just adjust it (up I think) to stop the air from dumping out. I did have the bus on a sloping street lifted high on the sidewalk side to make level, but I have had intermittent large air leaks from the same place for a long time. Also, there is a junction of I think 3 air hoses near this spot. Anyone know where these are going? I appear to only be using 2 of the 3, and the 3rd appears abandoned by a prior owner. Tks, SDF 80FC35 Boulder SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] 1980 Rod to Air Hose on Front Suspension - Jeff Miller - 05-19-2006 01:07 What Mike said. The three hose deal sounds like the dump valve, one line to supply, one to the leveling valve (top of the aforementioned rod), third is exhaust. Block it up before going under. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Suspension leveling valve, rod connects to the AXLE. There are two on the rear axle. Be careful under there, you could die. > MH > ----- Original Message ----- > From: shawn_fountain > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, May 18, 2006 9:55 PM > Subject: [WanderlodgeForum] 1980 Rod to Air Hose on Front Suspension > > > There is a rod going up and down from the center of the front > suspension that is causing air to dump when I do not want the air to > dump, or at least if I mess with that rod air stops dumping. Anyone > know what that rod is for, and if okay for me to just adjust it (up I > think) to stop the air from dumping out. I did have the bus on a > sloping street lifted high on the sidewalk side to make level, but I > have had intermittent large air leaks from the same place for a long > time. > > Also, there is a junction of I think 3 air hoses near this spot. > Anyone know where these are going? I appear to only be using 2 of the > 3, and the 3rd appears abandoned by a prior owner. > > Tks, > SDF > 80FC35 Boulder > > > > > > > SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair > Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] > |
