Dead Levelers Continued - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Dead Levelers Continued (/showthread.php?tid=2642) |
Dead Levelers Continued - Scott Forman - 05-19-2006 05:44 Thanks to everyone for their input on my dead levelers. A little more: 1) Are you folks saying that the leveler pump draws its juice from the gen bat? 2) When I turn the system on and actuate the levers, the leveling indicator lights dim like it's trying to do something, but there is no noise from the pump. ALSO, I just noticed that after fiddling with the levelers for a few seconds, there was a spot of oil on the ground under the pump. These facts add anything to the prognosis? Thanks, Scott Forman 82 FC35RB Memphis Dead Levelers Continued - fwernlein - 05-19-2006 07:30 In my limited experience based on my '85, 1: there are two solonoids located near the pump. One is dedicated for the HWH pump, the other is dedicated for the Gen set battery. This gen set one is not directly used to power the leveler pump, the main cables may be tied together for a common supply, but they do not work "together" for the leveler system. 2: Still sounds like a bad ground, your symptoms are exactly like i had...of course, there may be other causes...cleaning the lever switches is a excellent step also. 3: Your motor may also just be shot. Here is the real test...may i suggest you use jumper cables to bypass everything and just try to power the motor from the solonoid stud, jumping from say the gen battery as a 12vt source; use a second cable to ensure a good motor mount to ground connection...if when direct connected for a second, it runs, then you have a connection/switch problem somewhere. Good luck... Frank 85FC33 --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Thanks to everyone for their input on my dead levelers. A little more: > > 1) Are you folks saying that the leveler pump draws its juice from the > gen bat? > > 2) When I turn the system on and actuate the levers, the leveling > indicator lights dim like it's trying to do something, but there is no > noise from the pump. ALSO, I just noticed that after fiddling with the > levelers for a few seconds, there was a spot of oil on the ground under > the pump. These facts add anything to the prognosis? > > Thanks, > Scott Forman > 82 FC35RB > Memphis > Dead Levelers Continued - Stephen - 05-19-2006 10:04 My 81 levelers are doing the same thing.. My lights on the dash just din when I move the control lever. It WAS working, until one day the levers were STUCK and the pump just kept running, and running.. Until finally I smelled something hot, and a little smoke under there.. Im not sure if it was just hot from running so long, or it burned up. It kept getting slower, and slower until it stopped, now it won't do anything. Maybe I fried the relay.??? There is some oil, gunk over those relays, maybe it was the relay getting hot? Stephen Hare 81 FC-33SB Plant City, FL _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Scott Forman Sent: Friday, May 19, 2006 1:45 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Dead Levelers Continued Thanks to everyone for their input on my dead levelers. A little more: 1) Are you folks saying that the leveler pump draws its juice from the gen bat? 2) When I turn the system on and actuate the levers, the leveling indicator lights dim like it's trying to do something, but there is no noise from the pump. ALSO, I just noticed that after fiddling with the levelers for a few seconds, there was a spot of oil on the ground under the pump. These facts add anything to the prognosis? Thanks, Scott Forman 82 FC35RB Memphis _____ [Non-text portions of this message have been removed] Dead Levelers Continued - Lucas Willemse - 05-20-2006 10:39 I had the same problem with my 1980 FC 35. The motor burned up because it stayed on. There is no fuse or cicuit breaker for this. I added a 150 AMP cicrcuit breaker and now if the switches stick the breaker will trip. I had the motor rewound at an automotive starter repair shop I think it came to about $60.00. The circuit breaker was purchased from West Marine it is a surface mount Blue Sea unit. I mounted the breaker under the step that lifts up to check the oil level in the pump. I just had to cut the cable supplying the power to the solonoid for the pump and routed it through the breaker. Lucas Willemse 1980 FC35 Los Angeles |
