Changing cameras - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Changing cameras (/showthread.php?tid=2646) |
Changing cameras - Scott Forman - 05-20-2006 12:09 I would like to upgrade my rear view camera in an effort to get better picture quality...just the camera, not the monitor or cables. I bought a modern night vision color camera off eBay, but at night the picture is drowned out completely by glare from the infra-red lights reflecting off the small window the camera looks out of on the back of the coach. Has anyone had luck changing out their camera? What model did you use? Thanks Scott Forman 82 FC35RB Memphis Changing cameras - Rob Robinson - 05-20-2006 12:20 Scott I also bought a camera with infrared lights and had to remove the small window to eliminate the back glare. I replaced the window with plexi-glass. I cut a hole in the plexi the shape of the camera and pushed it through the hole. I sealed up the small gaps between the plexi and the camera with buytal. Of course this all depends on you camera being an all weather outdoor camera. If it is an indoor camera then I think you are looking at getting a different one. I recommend you check out these folks http://www.rvcams.com If you'd like me to send you some photos of my install let me know. On 20/05/06, Scott Forman <sforman@...> wrote: > > I would like to upgrade my rear view camera in an effort to get better > picture quality...just the camera, not the monitor or cables. I bought > a modern night vision color camera off eBay, but at night the picture > is drowned out completely by glare from the infra-red lights reflecting > off the small window the camera looks out of on the back of the coach. > > Has anyone had luck changing out their camera? What model did you > use? > > Thanks > > Scott Forman > 82 FC35RB > Memphis > > > > > > > > > Yahoo! Groups Links > > > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] Changing cameras - Scott Forman - 05-20-2006 12:25 Man, that sounds like a lot of work...I'll just try to find a camera that won't glare... Thanks --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Scott I also bought a camera with infrared lights and had to remove the > small window to eliminate the back glare. I replaced the window with > plexi-glass. I cut a hole in the plexi the shape of the camera and pushed it > through the hole. I sealed up the small gaps between the plexi and the > camera with buytal. Of course this all depends on you camera being an all > weather outdoor camera. If it is an indoor camera then I think you are > looking at getting a different one. I recommend you check out these folks > > http://www.rvcams.com > > If you'd like me to send you some photos of my install let me know. > > On 20/05/06, Scott Forman <sforman@...> wrote: > > > > I would like to upgrade my rear view camera in an effort to get better > > picture quality...just the camera, not the monitor or cables. I bought > > a modern night vision color camera off eBay, but at night the picture > > is drowned out completely by glare from the infra-red lights reflecting > > off the small window the camera looks out of on the back of the coach. > > > > Has anyone had luck changing out their camera? What model did you > > use? > > > > Thanks > > > > Scott Forman > > 82 FC35RB > > Memphis > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > Changing cameras - krminyl@... - 05-20-2006 12:46 Scott, I bought a cheap "board camera" (black and white), and using velcro, mounted it on the face of the old RCA camera, after unscrewing and removing the lens. I had the same problem with the glare from the IR illuminators...I took black electrical tape and covered the IR's with the tape. The modern cameras already have such low light specs, they are much better than the old RCA's that came with the BB when new. even without the IR's, the new board camera still works better than the old RCA. I think I paid about $39 for the camera, with all the necessary 12V power cord and RCA style video plug...hooked right up using the original BB wires. For around $300 or so, you can redo the entire B&W system, with a color camera and little LCD color monitor..a little more labor...maybe someday for me, but for now, the B&W system works good, even during the darkest night. The light given off from the tail lights of the BB is sufficient to illuminate my box trailer when I'm towing it. Good luck, Kevin McKeown Yorba Linda, CA 86 38PT [Non-text portions of this message have been removed] Changing cameras - Michael Day - 05-21-2006 05:45 Scott, when my backup camera went out, I also checked with rvcams.com and was told that with no camera with infrared sensors would work properly with a plexiglass or glass cover over them. I ended up replacing my black & white Sony camera with the matching (but newer) model since I didn't think it would look right to eliminate the cover on the back. Typically black & white cameras have a lower lux rating (the minimum light they can resolve) than color cameras. Sounds like you may have to go with a non infrared camera or use an approach such as that suggested by Rob. The folks at rvcams.com are great to deal with and will bend over backwards to help you out. Michael Day 1992 Newell 43.5' 8v92 --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Man, that sounds like a lot of work...I'll just try to find a camera > that won't glare... > > Thanks > > --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > > > > Scott I also bought a camera with infrared lights and had to remove > the > > small window to eliminate the back glare. I recommend you check out these folks > > > > http://www.rvcams.com > > > > > > On 20/05/06, Scott Forman <sforman@> wrote: > > > > > > I bought > > > a modern night vision color camera off eBay, but at night the > picture > > > is drowned out completely by glare from the infra-red lights > reflecting > > > off the small window the camera looks out of on the back of the > coach. > > > > > > Has anyone had luck changing out their camera? What model did you > > > use? > > > > > > Thanks > > > > > > Scott Forman > > > 82 FC35RB > > > Memphis Changing cameras - krminyl@... - 05-21-2006 06:36 Hey, I forgot to mention in my original reply....my image is reversed in the monitor...try to find a camera that has a "reverse image" switch, or perform the mod in the files section reversing the image at the monitor. Personally, I use the camera merely to check that my "toad" is still there, and to help a little when backing up...I just have to remember that left is right, and right is left (seeing cars passing you on the opposite side is a little unnerving, but I've gotten used to it). I've even thought about directing the lens into a mirror which would reverse the image, but I think I'll improve the entire system before that. Kevin Mc YL CA 86 38PT [Non-text portions of this message have been removed] Changing cameras - Jeff Miller - 05-21-2006 15:22 I've used the PC-164C (I believe) from http://www.supercircuits.com. They have a couple of ultra-low-light/.0003lux cameras, the one mentioned above is a C-mount type, takes the lense from your old camera. Another I've used I am holding but can't make out the model#, it is another ultra-low-light B&W camera from Supercircuits but a lipstick-type, 600lines resolution and .0003lux which is basically full-resolution in 1/4 moon, or enough to see clearly from the clearance lights on your coach. This lipstick camera is weatherproof, perfect for mounting to the top of the spotlight for remote-control looking around at night. Don't buy an IR illuminated type. They will glare off of the glass, and the IR illumination is short-range. A good low-light camera is worth the money IMO. For your '82 you can also use a color camera, the downside is that the color cameras are not nearly as sensitive in low-light. You could mount an IR illuminator on the outside of the coach if you wish. To reverse the image in the monitor, you simply open the "silver box" and reverse the red and blue wires on the four pin connector. If you want image reversed only with the key on for correct orientation using the TV portion of this system (I would wonder why, too small to see and no cable channels, but I digress, ...) you will need to install a DPDT relay to switch these wires with ignition power on. Instructions available if necessary. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > I would like to upgrade my rear view camera in an effort to get better > picture quality...just the camera, not the monitor or cables. I bought > a modern night vision color camera off eBay, but at night the picture > is drowned out completely by glare from the infra-red lights reflecting > off the small window the camera looks out of on the back of the coach. > > Has anyone had luck changing out their camera? What model did you > use? > > Thanks > > Scott Forman > 82 FC35RB > Memphis > Changing cameras - Henry Jay Hannigan - 05-21-2006 16:35 --- Jeff: How did you get so smart??? Hope is well with you in Michigan. Regards, Hank Hannigan 90SP36 80FC31 In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > I've used the PC-164C (I believe) from http://www.supercircuits.com. > They have a couple of ultra-low-light/.0003lux cameras, the one > mentioned above is a C-mount type, takes the lense from your old > camera. Another I've used I am holding but can't make out the > model#, it is another ultra-low-light B&W camera from Supercircuits > but a lipstick-type, 600lines resolution and .0003lux which is > basically full-resolution in 1/4 moon, or enough to see clearly from > the clearance lights on your coach. This lipstick camera is > weatherproof, perfect for mounting to the top of the spotlight for > remote-control looking around at night. > > Don't buy an IR illuminated type. They will glare off of the glass, > and the IR illumination is short-range. A good low-light camera is > worth the money IMO. For your '82 you can also use a color camera, > the downside is that the color cameras are not nearly as sensitive > in low-light. You could mount an IR illuminator on the outside of > the coach if you wish. > > To reverse the image in the monitor, you simply open the "silver > box" and reverse the red and blue wires on the four pin connector. > If you want image reversed only with the key on for correct > orientation using the TV portion of this system (I would wonder why, > too small to see and no cable channels, but I digress, ...) you will > need to install a DPDT relay to switch these wires with ignition > power on. Instructions available if necessary. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" > <sforman@> wrote: > > > > I would like to upgrade my rear view camera in an effort to get > better > > picture quality...just the camera, not the monitor or cables. I > bought > > a modern night vision color camera off eBay, but at night the > picture > > is drowned out completely by glare from the infra-red lights > reflecting > > off the small window the camera looks out of on the back of the > coach. > > > > Has anyone had luck changing out their camera? What model did you > > use? > > > > Thanks > > > > Scott Forman > > 82 FC35RB > > Memphis > > > Changing cameras - Stephen - 05-22-2006 13:00 I just installed my color LCD and camera I bought off of e-bay.. works great. Awesome color picture. Good investment IMO.. Brought it up to the 21st century. I do agree the night vision LED's do make a glare at night on the glass, I will be addressing that next. However during the day, it is a beautiful picture.. The nice clear LCD Monitor has a remote control too! To reverse the angle, all I have to do is click a button. It will flip the image upside down or left to right, any direction. Plus I have it wired for constant on (to monitor behind me while driving) or auto for automatic operation in reverse for camera power, and LCD power. Its just as easy as putting 'tape' over it as one person said, but I will probably take it out, and paint it- careful to mask off everything including the small circle that is the camera's eye. this way, everything will match, and look good., I don't want it to look like a mess up there.. I have had a couple of requests to post pictures of my set-up so they are now there on my 81 wanderlodge restoration pics in the wanderlodge forum photo's section; click link below: http://autos.ph.groups.yahoo.com/group/WanderlodgeForum/photos/browse/4c94 Stephen Hare 81 FC33-SB Plant City, FL _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Henry Jay Hannigan Sent: Monday, May 22, 2006 12:36 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Changing cameras --- Jeff: How did you get so smart??? Hope is well with you in Michigan. Regards, Hank Hannigan 90SP36 80FC31 In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > I've used the PC-164C (I believe) from http://www.supercircuits.com. > They have a couple of ultra-low-light/.0003lux cameras, the one > mentioned above is a C-mount type, takes the lense from your old > camera. Another I've used I am holding but can't make out the > model#, it is another ultra-low-light B&W camera from Supercircuits > but a lipstick-type, 600lines resolution and .0003lux which is > basically full-resolution in 1/4 moon, or enough to see clearly from > the clearance lights on your coach. This lipstick camera is > weatherproof, perfect for mounting to the top of the spotlight for > remote-control looking around at night. > > Don't buy an IR illuminated type. They will glare off of the glass, > and the IR illumination is short-range. A good low-light camera is > worth the money IMO. For your '82 you can also use a color camera, > the downside is that the color cameras are not nearly as sensitive > in low-light. You could mount an IR illuminator on the outside of > the coach if you wish. > > To reverse the image in the monitor, you simply open the "silver > box" and reverse the red and blue wires on the four pin connector. > If you want image reversed only with the key on for correct > orientation using the TV portion of this system (I would wonder why, > too small to see and no cable channels, but I digress, ...) you will > need to install a DPDT relay to switch these wires with ignition > power on. Instructions available if necessary. > > - Jeff Miller > in Holland, MI > _____ [Non-text portions of this message have been removed] |
