Dometic fridge door gasket - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Dometic fridge door gasket (/showthread.php?tid=2662) |
Dometic fridge door gasket - williamcharrison - 05-23-2006 03:03 Anyone know where to get a new door seal for a Dometic RM 3801 (and how to replace the old one)? Chuck Harrison 90 SP36 Akron, Ohio Dometic fridge door gasket - trautoranch - 05-23-2006 03:42 -Chuck, You can buy a kit from RV Dealer, a division of DTI. The kit cost $100.74. The part # is 3103690008. Their # is 1-800-325-9250. Kindest Regards, Rick Mcintire 86PT38 Patillo,Tx -- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > Anyone know where to get a new door seal for a Dometic RM 3801 (and > how to replace the old one)? > > Chuck Harrison > 90 SP36 > Akron, Ohio > Dometic fridge door gasket - williamcharrison - 05-23-2006 05:08 Thanks Rick, it is on its way. > > -Chuck, You can buy a kit from RV Dealer, a division of DTI. The kit > cost $100.74. The part # is 3103690008. Their # is 1-800-325-9250. > Kindest Regards, > Rick Mcintire > 86PT38 Patillo,Tx > > -- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > > Anyone know where to get a new door seal for a Dometic RM 3801 (and > > how to replace the old one)? > > > > Chuck Harrison > > 90 SP36 > > Akron, Ohio > > > Dometic fridge door gasket - trautoranch - 05-23-2006 08:21 -Chuck, Was to glad to help. Have a good day. Best regards, Rick Mcintire 86PT38 Patillo,Tx -- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > Thanks Rick, it is on its way. > > > > -Chuck, You can buy a kit from RV Dealer, a division of DTI. The > kit > > cost $100.74. The part # is 3103690008. Their # is 1-800-325-9250. > > Kindest Regards, > > Rick Mcintire > > 86PT38 Patillo,Tx > > > > -- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > > > > > Anyone know where to get a new door seal for a Dometic RM 3801 > (and > > > how to replace the old one)? > > > > > > Chuck Harrison > > > 90 SP36 > > > Akron, Ohio > > > > > > Dometic fridge door gasket - Ralph L. Fullenwider - 05-23-2006 09:26 Hi Chuck: After you get the gaskets, lay out a good place where the doors (removed) can be laid down, gasket side up. You need a very sharp knife (utility knife is best), raise the old gasket edge up and make your cuts into the groove, deep. Do not leave any old gasket on the upper flat area at all. Cut the old gasket completely away. Then clean the door flat where the new gasket will stick ( double side tape is used to reattach, with a solvent like paint thinner and let dry. Dry place the new gasket around the edges of the door for fit. Now your going to need 2 people. Start on the lower narrowest part and stick the new gasket, then up on side and on around from there. Then doors need to stay laid down for 24 hours before re attaching back to the fridge and then close the door and let sit UN OPENED for another 12 hours. It also works better if you leave the new gaskets laid out flat for a few hours before installing them. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 03:03 PM 5/23/2006 +0000, you wrote: >Anyone know where to get a new door seal for a Dometic RM 3801 (and >how to replace the old one)? > >Chuck Harrison >90 SP36 >Akron, Ohio > > |
