Dump ONLY the front air? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Dump ONLY the front air? (/showthread.php?tid=2715) |
Dump ONLY the front air? - one_dusty_hoot - 05-31-2006 04:21 My driveway inclines from the street. The grade was cut down about 2 feet and repaved for my other coach. This new-to-me 35' has considerable overhang aft of the rear wheels so the rollers (one stuck)roll about two feet lifting the rear. It is half full of diesel and propane now so when more weight is added with water,fuel,belongings it has got to drop lower. I'm thinking two solenoid exhaust valves set to a pre- set pressure reduction might drop the front raising the rear. All comments appreciated.(about the stuck roller too) Bob Janes 87 FC35 Greenville, SC Dump ONLY the front air? - g_man1146 - 05-31-2006 04:34 Hi Bob, I've seen several coaches that have been set up so you can over- inflate the rear bags, front or both for just the situation you have. You use additional solinoid valves to bypass the regulated air to the axle. Caution must be used as the driveshaft angle will be increased drastically on a pusher, not so much on an FC. The setup I saw had both front and rear as he owner had difficulty with ramps for the ferry boat that was used frequently. In talking with a tech at Bleakley, I was told that it is a relatively simple job to add the extra valves and switches. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot" > > My driveway inclines from the street. The grade was > cut down about 2 feet and repaved for my other coach. > > This new-to-me 35' has considerable overhang aft of > the rear wheels so the rollers (one stuck)roll about > two feet lifting the rear. > > It is half full of diesel and propane now so when more > weight is added with water,fuel,belongings it has got > to drop lower. > > I'm thinking two solenoid exhaust valves set to a pre- > set pressure reduction might drop the front raising the > rear. > > All comments appreciated.(about the stuck roller too) > > Bob Janes 87 FC35 Greenville, SC > Dump ONLY the front air? - dru penland - 05-31-2006 06:13 Should it drop lower? I figure the level adjusters should keep it level within the weight limitations of the air springs. I have not measured mine in both extremes, but I installed air springs in place of the leafs on my F350 and the level adjusters adjust for any load I place in the bed. I can even over ride the leveler and put a little more in to get more clearance, if need be. one_dusty_hoot street. The grade was cut down about 2 feet and repaved for my other coach. This new-to-me 35' has considerable overhang aft of the rear wheels so the rollers (one stuck)roll about two feet lifting the rear. It is half full of diesel and propane now so when more weight is added with water,fuel,belongings it has got to drop lower. I'm thinking two solenoid exhaust valves set to a pre- set pressure reduction might drop the front raising the rear. All comments appreciated.(about the stuck roller too) Bob Janes 87 FC35 Greenville, SC SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- Dru and Debora Corpus Christi, TX 1983 FC 35 RB [Non-text portions of this message have been removed] |
