Leaking pump - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Leaking pump (/showthread.php?tid=2725) |
Leaking pump - Pete Masterson - 06-03-2006 04:13 My education starts to get going... I have a pump that's leaking a small bit of water. It's labeled Shurflow Diaphragm Pump and has the number 2088-422-8055 on it. (It's positioned just below a very similar pump with 2088-423-8055.) The pump is located in the curb-side "toolbox" compartment near the clean water drain valve. Does anyone know what this pump is and if it can be rebuilt or if it must it be replaced? (And where can I get parts?) BTW, the coach has been sitting for about a week (with external power) and the water pump is off. I'm surprised that there's enough pressure for a leak ... but I expect to be surprised by many Wanderlodge things as the learning process proceeds. Thanks. Pete Masterson aeonix1@... '95 WBDA 4203 Formerly "George's coach" El Sobrante CA Leaking pump - Ralph L. Fullenwider - 06-03-2006 05:51 Pete: That is one of your fresh water pumps replacement is cheaper than putting a new pump head on it. In your bath cabinet you should have an A B Both switch you can run both pumps or each separately. That pump is a low GPM unit and I have been replacing them with the higher pressure 65psi @ 4.5 GPM pumps. Ralph >My education starts to get going... > >I have a pump that's leaking a small bit of water. > >It's labeled Shurflow Diaphragm Pump and has the number 2088-422-8055 >on it. (It's positioned just below a very similar pump with >2088-423-8055.) The pump is located in the curb-side "toolbox" >compartment near the clean water drain valve. > >Does anyone know what this pump is and if it can be rebuilt or if it >must it be replaced? (And where can I get parts?) > >BTW, the coach has been sitting for about a week (with external >power) and the water pump is off. I'm surprised that there's enough >pressure for a leak ... but I expect to be surprised by many >Wanderlodge things as the learning process proceeds. > >Thanks. > >Pete Masterson >aeonix1@... >'95 WBDA 4203 >Formerly "George's coach" >El Sobrante CA > > > > > > >Yahoo! Groups Links > > > > Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm |
