coolant hose to the water heater - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: coolant hose to the water heater (/showthread.php?tid=2729) |
coolant hose to the water heater - guysmalley - 06-04-2006 17:06 I found my leak it is at the connection to the small hose that heats the hot water when traveling. shutting off the 4 gate valves does not shut that part off ( I checked with Benny @ BB. the problem is I van see it but I cannot get to it. the hose is located on the inside of the frame with everything in its way. any suggestions? it only drips 8-9 driops per minute when running but not at all when shut down. guy smalley getting my robe dirty 86 pt 40 |
