water pump location and off/on switch no work. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: water pump location and off/on switch no work. (/showthread.php?tid=2740) |
water pump location and off/on switch no work. - Henry Jay Hannigan - 06-07-2006 00:13 Help: Water pump off/on switch above sink does NOT turn off water pump. I can hear it running in the bathroom but cant find it. I had to turn off my 12v supply to stop the water pump...any suggestions besides stop using water?? Thanks. This problem is on my "new" 80FC31...not my cherry 90SP36 still for sale with discounts available.. Thanks, Hank Hannigan in Illinois for now on way to Elkhart, Inindiana to pick up new Slendide washer/dryer for 80FC31. 80FC31 90SP36(for sale in Vegas) water pump location and off/on switch no work. - krminyl@... - 06-07-2006 00:31 Are you sure your "tank fill" switch at the water hose fill inlet is "off"? Kevin Mc YL CA 86 38 PT [Non-text portions of this message have been removed] water pump location and off/on switch no work. - orbitalsolutions - 06-07-2006 00:52 Helo, President Hank! I believe your pump is located under the bed. Let me ask you a few questions... 1) Does the pump shut off when the switch is in the on position, after it has built pressure and there is no demand? 2) Is your bus a rear bath? 3) If you have a side bath, do you have twin beds or one bed on the road side? These answers will help me to understand what might be happening. James 78FC33SB "Old School" Tunica, MS --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > Help: > Water pump off/on switch above sink does NOT turn off water pump. > I can hear it running in the bathroom but cant find it. I had to turn > off my 12v supply to stop the water pump...any suggestions besides > stop using water?? Thanks. This problem is on my "new" 80FC31...not > my cherry 90SP36 still for sale with discounts available.. > Thanks, > Hank Hannigan in Illinois for now on way to Elkhart, Inindiana to > pick up new Slendide washer/dryer for 80FC31. > 80FC31 > 90SP36(for sale in Vegas) > water pump location and off/on switch no work. - Henry Jay Hannigan - 06-07-2006 01:26 --- James: Thanks for responding. Pump shuts off when pressurized. Have TWIN beds. Am plumbig up for washing machine and tried to get water stopped, thus found out no shutoff from on/off switch. flash...just found swich in bathroom, with hat down, both switches turn off water pump....that part solved ...now to find waterpump access. Pump is in bathroom....behind heater???? LOL Hank Hannigan In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > Helo, President Hank! > > I believe your pump is located under the bed. > > Let me ask you a few questions... > > 1) Does the pump shut off when the switch is in the on position, after > it has built pressure and there is no demand? > > 2) Is your bus a rear bath? > > 3) If you have a side bath, do you have twin beds or one bed on the > road side? > > These answers will help me to understand what might be happening. > > > James > 78FC33SB "Old School" > Tunica, MS > > > > > --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > > > Help: > > Water pump off/on switch above sink does NOT turn off water pump. > > I can hear it running in the bathroom but cant find it. I had to > turn > > off my 12v supply to stop the water pump...any suggestions besides > > stop using water?? Thanks. This problem is on my "new" 80FC31...not > > my cherry 90SP36 still for sale with discounts available.. > > Thanks, > > Hank Hannigan in Illinois for now on way to Elkhart, Inindiana to > > pick up new Slendide washer/dryer for 80FC31. > > 80FC31 > > 90SP36(for sale in Vegas) > > > water pump location and off/on switch no work. - orbitalsolutions - 06-07-2006 01:52 Sorry, Mr. President. I don't know where it is on your bus. Assuming that you have a SB, It would have to be on either side of the heater, or in the cabinet under the sink. I'm sure you would have found it if it were in the cabinet. I can't imagine it could be any other place but beside the heater, most likely aft. -- Just a guess. BTW: Where are you going to mount that sporty washer/dryer? James 78FC33SB "Old School" Tunica, MS --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > --- James: > Thanks for responding. Pump shuts off when pressurized. Have TWIN > beds. > Am plumbig up for washing machine and tried to get water stopped, > thus found out no shutoff from on/off switch. > flash...just found swich in bathroom, with hat down, both switches > turn off water pump....that part solved ...now to find waterpump > access. Pump is in bathroom....behind heater???? > LOL > Hank Hannigan > > > > > > > In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > > > > Helo, President Hank! > > > > I believe your pump is located under the bed. > > > > Let me ask you a few questions... > > > > 1) Does the pump shut off when the switch is in the on position, > after > > it has built pressure and there is no demand? > > > > 2) Is your bus a rear bath? > > > > 3) If you have a side bath, do you have twin beds or one bed on > the > > road side? > > > > These answers will help me to understand what might be happening. > > > > > > James > > 78FC33SB "Old School" > > Tunica, MS > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > > > > > > Help: > > > Water pump off/on switch above sink does NOT turn off water pump. > > > I can hear it running in the bathroom but cant find it. I had > to > > turn > > > off my 12v supply to stop the water pump...any suggestions > besides > > > stop using water?? Thanks. This problem is on my "new" > 80FC31...not > > > my cherry 90SP36 still for sale with discounts available.. > > > Thanks, > > > Hank Hannigan in Illinois for now on way to Elkhart, > Inindiana to > > > pick up new Slendide washer/dryer for 80FC31. > > > 80FC31 > > > 90SP36(for sale in Vegas) > > > > > > water pump location and off/on switch no work. - Henry Jay Hannigan - 06-07-2006 03:36 ---Have twin beds.......converted to large double cross bed.......putting washer/dryer on right forward(not Navy) as enter bedroom. only 23 inches wide and 33 inches high....piece of cake.....just dont like laundrymats as who knows what was washed just before u got there!!!!!!plumbing for washer at the moment. regards, Hank Hannigan 80FC31 90SP36 (FOR SALE with DISCOUNTS>>>>#607 on birdconnection.com) In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > Sorry, Mr. President. > > I don't know where it is on your bus. > > Assuming that you have a SB, It would have to be on either side of > the heater, or in the cabinet under the sink. I'm sure you would > have found it if it were in the cabinet. I can't imagine it could > be any other place but beside the heater, most likely aft. -- Just a > guess. > > BTW: Where are you going to mount that sporty washer/dryer? > > > James > 78FC33SB "Old School" > Tunica, MS > > > --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > > > --- James: > > Thanks for responding. Pump shuts off when pressurized. Have > TWIN > > beds. > > Am plumbig up for washing machine and tried to get water stopped, > > thus found out no shutoff from on/off switch. > > flash...just found swich in bathroom, with hat down, both switches > > turn off water pump....that part solved ...now to find waterpump > > access. Pump is in bathroom....behind heater???? > > LOL > > Hank Hannigan > > > > > > > > > > > > > > In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > > > > > > > Helo, President Hank! > > > > > > I believe your pump is located under the bed. > > > > > > Let me ask you a few questions... > > > > > > 1) Does the pump shut off when the switch is in the on > position, > > after > > > it has built pressure and there is no demand? > > > > > > 2) Is your bus a rear bath? > > > > > > 3) If you have a side bath, do you have twin beds or one bed on > > the > > > road side? > > > > > > These answers will help me to understand what might be happening. > > > > > > > > > James > > > 78FC33SB "Old School" > > > Tunica, MS > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > > > > > > > > > Help: > > > > Water pump off/on switch above sink does NOT turn off water > pump. > > > > I can hear it running in the bathroom but cant find it. I had > > to > > > turn > > > > off my 12v supply to stop the water pump...any suggestions > > besides > > > > stop using water?? Thanks. This problem is on my "new" > > 80FC31...not > > > > my cherry 90SP36 still for sale with discounts available.. > > > > Thanks, > > > > Hank Hannigan in Illinois for now on way to Elkhart, > > Inindiana to > > > > pick up new Slendide washer/dryer for 80FC31. > > > > 80FC31 > > > > 90SP36(for sale in Vegas) > > > > > > > > > > |
