voltage and amp meter - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: voltage and amp meter (/showthread.php?tid=2761) |
voltage and amp meter - putneyflash - 06-11-2006 14:32 when the engine is running neither my engine volmeter or amp meter show a charge or movement. I know the system works because my battries stay charged up.I would like to have them working. Any thoughts?? re brake 1983 FC-35 SB voltage and amp meter - Curt Sprenger - 06-11-2006 15:38 BE SURE there is good ground at meters. Is voltage/amps present at the guages (wires at the guages)? If so, I'd think the guages are bad. If no voltage/amps then go back to the source, the alternator/regulator and check there, maybe the wires are loose. Hope this helps. Others will join in and add to this. Good luck. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. putneyflash wrote: > when the engine is running neither my engine volmeter or amp meter > show a charge or movement. I know the system works because my battries > stay charged up.I would like to have them working. Any thoughts?? > re brake 1983 FC-35 SB > > voltage and amp meter - putneyflash@... - 06-12-2006 14:02 Thanks for the response that gives me a place to start re -------------- Original message from Curt Sprenger -------------- BE SURE there is good ground at meters. Is voltage/amps present at the guages (wires at the guages)? If so, I'd think the guages are bad. If no voltage/amps then go back to the source, the alternator/regulator and check there, maybe the wires are loose. Hope this helps. Others will join in and add to this. Good luck. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. putneyflash wrote: > when the engine is running neither my engine volmeter or amp meter > show a charge or movement. I know the system works because my battries > stay charged up.I would like to have them working. Any thoughts?? > re brake 1983 FC-35 SB > > [Non-text portions of this message have been removed] |
