Check Valve problem - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Check Valve problem (/showthread.php?tid=2784) |
Check Valve problem - Lee Davis - 06-16-2006 08:09 I had water leaking back into the air line in front of the purge switch. It began leaking into the "basement" next to my Aquahot. Bluebird says there is supposed to be a check valve in there to prevent that but I did not see one. I ordered one from Bluebird (an air check valve it turns out) and it appears water is leaking backward through that valve and continues to leak, now out of the pressure adjustment valve between the switch and the check valve which I installed just in front of where it purges the waterline. Can water leak backeward throiugh an air check valve? Anyone else ever have this problem who can help? Thanks Lee Davis 95 BMC |
