Adjust Ride Height - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Adjust Ride Height (/showthread.php?tid=2804) |
Adjust Ride Height - olson_phil - 06-19-2006 01:07 My 83FC35SB leans a little. The drivers side is a couple of inches lower than the passenger side. Front to back seems even, just side to side is off. Told the wife it is because I weigh more than her. I thought there was a side to side ride height adjustment for the air suspension near the rear axle, but couldn't find it, or at least was not sure what I was looking for. Anyone know where this is, what this looks like and how to adjust it? Does the suspension have to be dumped first to adjust it? Any tips would be helpful. Thanks. Phil Olson 83FC35SB Appleton, WI Adjust Ride Height - Mike Hohnstein - 06-19-2006 01:28 There are 3 leveler valves. One on the front axle and two on the rear. Place a jack stand under the trailer hitch out of fear and get under the coach behind the LR tires. You will see a verticle rod with a slide adjustment on the back of the axle, lengthen it an inch. Dump the suspension and reinflate. This should be done on a level concrete surface. Might take a few tries to get it right, PB blaster will be a good thing to use on the assemblies before trying to adjust them. Mike Hohnstein Germantown, WI 15 miles from the twister 83FC35 ----- Original Message ----- From: olson_phil To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 19, 2006 8:07 AM Subject: [WanderlodgeForum] Adjust Ride Height My 83FC35SB leans a little. The drivers side is a couple of inches lower than the passenger side. Front to back seems even, just side to side is off. Told the wife it is because I weigh more than her. I thought there was a side to side ride height adjustment for the air suspension near the rear axle, but couldn't find it, or at least was not sure what I was looking for. Anyone know where this is, what this looks like and how to adjust it? Does the suspension have to be dumped first to adjust it? Any tips would be helpful. Thanks. Phil Olson 83FC35SB Appleton, WI [Non-text portions of this message have been removed] Adjust Ride Height - dru penland - 06-19-2006 02:46 Mike, What should the ride height be front and back and where do you do your measuring from? Oh, and do you know if excessive bounce is a cause of air spring failure? Thanks, Mike Hohnstein <MHOHNSTEIN@...> wrote: There are 3 leveler valves. One on the front axle and two on the rear. Place a jack stand under the trailer hitch out of fear and get under the coach behind the LR tires. You will see a verticle rod with a slide adjustment on the back of the axle, lengthen it an inch. Dump the suspension and reinflate. This should be done on a level concrete surface. Might take a few tries to get it right, PB blaster will be a good thing to use on the assemblies before trying to adjust them. Mike Hohnstein Germantown, WI 15 miles from the twister 83FC35 ----- Original Message ----- From: olson_phil To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 19, 2006 8:07 AM Subject: [WanderlodgeForum] Adjust Ride Height My 83FC35SB leans a little. The drivers side is a couple of inches lower than the passenger side. Front to back seems even, just side to side is off. Told the wife it is because I weigh more than her. I thought there was a side to side ride height adjustment for the air suspension near the rear axle, but couldn't find it, or at least was not sure what I was looking for. Anyone know where this is, what this looks like and how to adjust it? Does the suspension have to be dumped first to adjust it? Any tips would be helpful. Thanks. Phil Olson 83FC35SB Appleton, WI [Non-text portions of this message have been removed] Dru and Debora Corpus Christi, TX 1983 FC 35 RB [Non-text portions of this message have been removed] Adjust Ride Height - Mike Hohnstein - 06-19-2006 03:43 I measure the fender lip at 12 o'clock. 41" front 42" rear. How's the shocks? MH ----- Original Message ----- From: dru penland To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 19, 2006 9:46 AM Subject: Re: [WanderlodgeForum] Adjust Ride Height Mike, What should the ride height be front and back and where do you do your measuring from? Oh, and do you know if excessive bounce is a cause of air spring failure? Thanks, Mike Hohnstein <MHOHNSTEIN@...> wrote: There are 3 leveler valves. One on the front axle and two on the rear. Place a jack stand under the trailer hitch out of fear and get under the coach behind the LR tires. You will see a verticle rod with a slide adjustment on the back of the axle, lengthen it an inch. Dump the suspension and reinflate. This should be done on a level concrete surface. Might take a few tries to get it right, PB blaster will be a good thing to use on the assemblies before trying to adjust them. Mike Hohnstein Germantown, WI 15 miles from the twister 83FC35 ----- Original Message ----- From: olson_phil To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 19, 2006 8:07 AM Subject: [WanderlodgeForum] Adjust Ride Height My 83FC35SB leans a little. The drivers side is a couple of inches lower than the passenger side. Front to back seems even, just side to side is off. Told the wife it is because I weigh more than her. I thought there was a side to side ride height adjustment for the air suspension near the rear axle, but couldn't find it, or at least was not sure what I was looking for. Anyone know where this is, what this looks like and how to adjust it? Does the suspension have to be dumped first to adjust it? Any tips would be helpful. Thanks. Phil Olson 83FC35SB Appleton, WI [Non-text portions of this message have been removed] Dru and Debora Corpus Christi, TX 1983 FC 35 RB [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Adjust Ride Height - Scott Forman - 06-19-2006 05:31 Mine did that when I first got it, turned out that the left side wasn't low, the right side was high. Problem was a worn out leveling valve on the right side. The valves are very easy to change. Scott Forman 82 FC35RB Memphis --- In WanderlodgeForum@yahoogroups.com, "olson_phil" > > My 83FC35SB leans a little. The drivers side is a couple of inches > lower than the passenger side. Front to back seems even, just side to > side is off. Told the wife it is because I weigh more than her. I > thought there was a side to side ride height adjustment for the air > suspension near the rear axle, but couldn't find it, or at least was > not sure what I was looking for. Anyone know where this is, what this > looks like and how to adjust it? Does the suspension have to be dumped > first to adjust it? Any tips would be helpful. Thanks. > > Phil Olson > 83FC35SB > Appleton, WI > Adjust Ride Height - dru penland - 06-19-2006 06:53 I'm guessing that is my next hot job. I need to take them off and see. I placed an air ride system on my F350 last year, in which I removed all of the existing suspension. The shocks are actually what keep the suspension from going too far and pulling the air springs apart. Mike Hohnstein <MHOHNSTEIN@...> wrote: I measure the fender lip at 12 o'clock. 41" front 42" rear. How's the shocks? MH ----- Original Message ----- From: dru penland To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 19, 2006 9:46 AM Subject: Re: [WanderlodgeForum] Adjust Ride Height Mike, What should the ride height be front and back and where do you do your measuring from? Oh, and do you know if excessive bounce is a cause of air spring failure? Thanks, Mike Hohnstein <MHOHNSTEIN@...> wrote: There are 3 leveler valves. One on the front axle and two on the rear. Place a jack stand under the trailer hitch out of fear and get under the coach behind the LR tires. You will see a verticle rod with a slide adjustment on the back of the axle, lengthen it an inch. Dump the suspension and reinflate. This should be done on a level concrete surface. Might take a few tries to get it right, PB blaster will be a good thing to use on the assemblies before trying to adjust them. Mike Hohnstein Germantown, WI 15 miles from the twister 83FC35 ----- Original Message ----- From: olson_phil To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 19, 2006 8:07 AM Subject: [WanderlodgeForum] Adjust Ride Height My 83FC35SB leans a little. The drivers side is a couple of inches lower than the passenger side. Front to back seems even, just side to side is off. Told the wife it is because I weigh more than her. I thought there was a side to side ride height adjustment for the air suspension near the rear axle, but couldn't find it, or at least was not sure what I was looking for. Anyone know where this is, what this looks like and how to adjust it? Does the suspension have to be dumped first to adjust it? Any tips would be helpful. Thanks. Phil Olson 83FC35SB Appleton, WI [Non-text portions of this message have been removed] Dru and Debora Corpus Christi, TX 1983 FC 35 RB [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Dru and Debora Corpus Christi, TX 1983 FC 35 RB [Non-text portions of this message have been removed] Adjust Ride Height - dru penland - 06-19-2006 07:02 Mike, One clarification on the fender lip. I'm guessing you mean the metal portion of the fender and not the rubber flare, correct? Mike Hohnstein <MHOHNSTEIN@...> wrote: I measure the fender lip at 12 o'clock. 41" front 42" rear. How's the shocks? MH ----- Original Message ----- From: dru penland To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 19, 2006 9:46 AM Subject: Re: [WanderlodgeForum] Adjust Ride Height Mike, What should the ride height be front and back and where do you do your measuring from? Oh, and do you know if excessive bounce is a cause of air spring failure? Thanks, Mike Hohnstein <MHOHNSTEIN@...> wrote: There are 3 leveler valves. One on the front axle and two on the rear. Place a jack stand under the trailer hitch out of fear and get under the coach behind the LR tires. You will see a verticle rod with a slide adjustment on the back of the axle, lengthen it an inch. Dump the suspension and reinflate. This should be done on a level concrete surface. Might take a few tries to get it right, PB blaster will be a good thing to use on the assemblies before trying to adjust them. Mike Hohnstein Germantown, WI 15 miles from the twister 83FC35 ----- Original Message ----- From: olson_phil To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 19, 2006 8:07 AM Subject: [WanderlodgeForum] Adjust Ride Height My 83FC35SB leans a little. The drivers side is a couple of inches lower than the passenger side. Front to back seems even, just side to side is off. Told the wife it is because I weigh more than her. I thought there was a side to side ride height adjustment for the air suspension near the rear axle, but couldn't find it, or at least was not sure what I was looking for. Anyone know where this is, what this looks like and how to adjust it? Does the suspension have to be dumped first to adjust it? Any tips would be helpful. Thanks. Phil Olson 83FC35SB Appleton, WI [Non-text portions of this message have been removed] Dru and Debora Corpus Christi, TX 1983 FC 35 RB [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Dru and Debora Corpus Christi, TX 1983 FC 35 RB [Non-text portions of this message have been removed] Adjust Ride Height - Mike Hohnstein - 06-19-2006 08:35 I use the rubber flare. A half inch is close enough, in fact that's great if you can get it that close. It's just a point of reference, the factory has a spec and it's in the archives some where, on the frame to ground spec, but the fender flare is just fine. I had to mess with mine a few times before it settled down. I got new leveling valves on the shelf just in case. MH ----- Original Message ----- From: dru penland To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 19, 2006 2:02 PM Subject: Re: [WanderlodgeForum] Adjust Ride Height Mike, One clarification on the fender lip. I'm guessing you mean the metal portion of the fender and not the rubber flare, correct? Mike Hohnstein <MHOHNSTEIN@...> wrote: I measure the fender lip at 12 o'clock. 41" front 42" rear. How's the shocks? MH ----- Original Message ----- From: dru penland To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 19, 2006 9:46 AM Subject: Re: [WanderlodgeForum] Adjust Ride Height Mike, What should the ride height be front and back and where do you do your measuring from? Oh, and do you know if excessive bounce is a cause of air spring failure? Thanks, Mike Hohnstein <MHOHNSTEIN@...> wrote: There are 3 leveler valves. One on the front axle and two on the rear. Place a jack stand under the trailer hitch out of fear and get under the coach behind the LR tires. You will see a verticle rod with a slide adjustment on the back of the axle, lengthen it an inch. Dump the suspension and reinflate. This should be done on a level concrete surface. Might take a few tries to get it right, PB blaster will be a good thing to use on the assemblies before trying to adjust them. Mike Hohnstein Germantown, WI 15 miles from the twister 83FC35 ----- Original Message ----- From: olson_phil To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 19, 2006 8:07 AM Subject: [WanderlodgeForum] Adjust Ride Height My 83FC35SB leans a little. The drivers side is a couple of inches lower than the passenger side. Front to back seems even, just side to side is off. Told the wife it is because I weigh more than her. I thought there was a side to side ride height adjustment for the air suspension near the rear axle, but couldn't find it, or at least was not sure what I was looking for. Anyone know where this is, what this looks like and how to adjust it? Does the suspension have to be dumped first to adjust it? Any tips would be helpful. Thanks. Phil Olson 83FC35SB Appleton, WI [Non-text portions of this message have been removed] Dru and Debora Corpus Christi, TX 1983 FC 35 RB [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Dru and Debora Corpus Christi, TX 1983 FC 35 RB [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
