water hook up - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: water hook up (/showthread.php?tid=282) |
water hook up - Bob Benner - 04-17-2005 00:33 When I got my PT40 there was alot of white gunk below the water fill box. Seems the connection leaked often for the previous owner and in fact seemed to leak for me as well. At a rally, I believe it was at the FMCA Quartzsite International Rally a couple of years ago, I picked up a quick connection from a guy who emphatically stated that it would not leak. I bought the 45 degree angled male end connection as it fit into my doored box and allowed it to close and accepted the hose aiming down. The female end quick connect on my hose has a turn off valve built right in. In order to connect and unconnect the hose I simply turn off the female end disconnect, attach the hose to the water supply, turn it on, open the female connect to flush out whatever is in the water, (sometimes the spigots haven't been used for awhile), turn off the female connector, connect via quick connect then turn on the water at the female connector. No mess no fuss. Just the opposite allows me to disconnect without a mess when I'm leaving. Its worked great for our bird. Bob 86PT40 on beautiful Long Island in the spring |
