"Low air pressure" dash light - where's the sender? 78 FC33 - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: "Low air pressure" dash light - where's the sender? 78 FC33 (/showthread.php?tid=2825) |
"Low air pressure" dash light - where's the sender? 78 FC33 - Dan - 06-20-2006 15:44 Hi all, My "low air pressure" light does not work. Bulb is okay. Does anyone know the location of the pressure switch/sender that drives this light? Thanks, Danny FC33, 1978 San Jose, CA "Low air pressure" dash light - where's the sender? 78 FC33 - rwoodysurplus - 06-21-2006 08:53 Hey,' Mine is right in front of the door under the bus inside frame woody at ft bragg nc with 81-35' fc RB just back from the beach- -- In WanderlodgeForum@yahoogroups.com, "Dan" > > Hi all, > > My "low air pressure" light does not work. Bulb is okay. Does anyone > know the location of the pressure switch/sender that drives this light? > > Thanks, > > Danny > FC33, 1978 > San Jose, CA > "Low air pressure" dash light - where's the sender? 78 FC33 - Tim Hannink - 06-21-2006 09:15 Mine is on the same 4-way junction fitting that the Schrader valve is on - the one that the tow truck driver hooks into when he needs to release the brakes. Its located behind the front wet tank, just inboard of the propane tank. Good luck, Tim Hannink Winter Park, FL 1981 FC-33SB --- In WanderlodgeForum@yahoogroups.com, "Dan" > > Hi all, > > My "low air pressure" light does not work. Bulb is okay. Does anyone > know the location of the pressure switch/sender that drives this light? > > Thanks, > > Danny > FC33, 1978 > San Jose, CA > |
