cb and radio antenna**update** - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: cb and radio antenna**update** (/showthread.php?tid=2827) |
cb and radio antenna**update** - Stephen - 06-21-2006 10:13 While on this subject. My left side antenna came off the base. It looks like someone has already 'glued' it back on once already.. There is a little metal pin sticking out the bottom where it plugs back into the other part of the base (mounted to the top of the bus) Is there a replacement on this antenna? Mine are the thin 'twin' ones side by side about 14 inches tall. There is a single one with spring base up front that is broken too.. I think that one is the radio.. not sure Stephen Hare 81FC33 SB Plant City, FL _,_._,___ [Non-text portions of this message have been removed] cb and radio antenna**update** - fwernlein - 06-21-2006 10:51 I snapped my CB antenna off on a recent trip. I found practically nothing as far as CB equipment at Radio Shack, etc....but if you keep your eyes open for a big truck stop along an interstate, they do stock CB stuff in quanity. I replaced my antenna with a single pole about 20" and a spring base to hopefully allow it to tilt back for low branches. Frank 85FC33 Woodbridge, VA...for 2 weeks and then free to roam a month in SD,WY & CO!!! --- In WanderlodgeForum@yahoogroups.com, "Stephen" <share@...> wrote: > > While on this subject. > > > > My left side antenna came off the base. It looks like someone has already > 'glued' it back on once already.. > > There is a little metal pin sticking out the bottom where it plugs back into > the other part of the base (mounted to the top of the bus) > > > > Is there a replacement on this antenna? Mine are the thin 'twin' ones side > by side about 14 inches tall. > > There is a single one with spring base up front that is broken too.. I think > that one is the radio.. not sure > > > > Stephen Hare > > 81FC33 SB > > Plant City, FL > > _,_._,___ > > > > [Non-text portions of this message have been removed] > cb and radio antenna**update** - orbitalsolutions - 06-21-2006 15:06 Everything available in the Twenty Seven Megecycle, Eleven Meter Band radio world can be purchased from these web sites... http://www.premiere-electronics.net/index.shtml http://www.radioactiveradios.com James: handle - "Spooky" Station - WXD4569 78FC33SB "Old School" Orange Lake, FL. --- In WanderlodgeForum@yahoogroups.com, "fwernlein" wrote: > > I snapped my CB antenna off on a recent trip. I found practically > nothing as far as CB equipment at Radio Shack, etc....but if you > keep your eyes open for a big truck stop along an interstate, they > do stock CB stuff in quanity. I replaced my antenna with a single > pole about 20" and a spring base to hopefully allow it to tilt back > for low branches. > > Frank > 85FC33 > Woodbridge, VA...for 2 weeks and then free to roam a month in SD,WY > & CO!!! > > --- In WanderlodgeForum@yahoogroups.com, "Stephen" <share@> wrote: > > > > While on this subject. > > > > > > > > My left side antenna came off the base. It looks like someone has > already > > 'glued' it back on once already.. > > > > There is a little metal pin sticking out the bottom where it plugs > back into > > the other part of the base (mounted to the top of the bus) > > > > > > > > Is there a replacement on this antenna? Mine are the thin 'twin' > ones side > > by side about 14 inches tall. > > > > There is a single one with spring base up front that is broken > too.. I think > > that one is the radio.. not sure > > > > > > > > Stephen Hare > > > > 81FC33 SB > > > > Plant City, FL > > > > _,_._,___ > > > > > > > > [Non-text portions of this message have been removed] > > > |
