FC 3208 Fan Bracket Plate - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: FC 3208 Fan Bracket Plate (/showthread.php?tid=2829) |
FC 3208 Fan Bracket Plate - dthollis1961 - 06-22-2006 01:46 My recently acquired 84 FC35 has had 2 Horton Air Fans and 2 radiators in as many years (not on my dime). There are no plates (spacers) between the bolt heads and the fan bracket where the fan bolts to the front of the engine and I would like to get some of these plates and install them. Can anyone recall if these plates are simply flat stock with 2 holes in them or is there more to them? Thanks David Hollis 84 FC35 Springfield,IL FC 3208 Fan Bracket Plate - Mike Hohnstein - 06-22-2006 01:50 3/16" flat stock will work well. MH ----- Original Message ----- From: dthollis1961 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 22, 2006 8:46 AM Subject: [WanderlodgeForum] FC 3208 Fan Bracket Plate My recently acquired 84 FC35 has had 2 Horton Air Fans and 2 radiators in as many years (not on my dime). There are no plates (spacers) between the bolt heads and the fan bracket where the fan bolts to the front of the engine and I would like to get some of these plates and install them. Can anyone recall if these plates are simply flat stock with 2 holes in them or is there more to them? Thanks David Hollis 84 FC35 Springfield,IL [Non-text portions of this message have been removed] FC 3208 Fan Bracket Plate - randydupree2000 - 06-22-2006 10:58 --- In WanderlodgeForum@yahoogroups.com, "dthollis1961" wrote: > > My recently acquired 84 FC35 has had 2 Horton Air Fans and 2 radiators > in as many years (not on my dime). There are no plates (spacers) > between the bolt heads and the fan bracket where the fan bolts to the > front of the engine and I would like to get some of these plates and > install them. Can anyone recall if these plates are simply flat stock > with 2 holes in them or is there more to them? > > Thanks > > David Hollis 84 FC35 Springfield,IL > as mike said,3/16 steel flatbar will work well,but when you drill the holes they need to be offset just a bit to the side,or you may have to grind a bevel on one side,the side that goes toward the bearing casting,you have to make damn sure the flatbar is flat against the casting when the bolts are tight. randy FC 3208 Fan Bracket Plate - dthollis1961 - 06-22-2006 11:25 Thanks, Randy and Mike. David Hollis --- In WanderlodgeForum@yahoogroups.com, "randydupree2000" > > --- In WanderlodgeForum@yahoogroups.com, "dthollis1961" > wrote: > > > > My recently acquired 84 FC35 has had 2 Horton Air Fans and 2 > radiators > > in as many years (not on my dime). There are no plates (spacers) > > between the bolt heads and the fan bracket where the fan bolts to > the > > front of the engine and I would like to get some of these plates and > > install them. Can anyone recall if these plates are simply flat > stock > > with 2 holes in them or is there more to them? > > > > Thanks > > > > David Hollis 84 FC35 Springfield,IL > > > as mike said,3/16 steel flatbar will work well,but when you drill the > holes they need to be offset just a bit to the side,or you may have to > grind a bevel on one side,the side that goes toward the bearing > casting,you have to make damn sure the flatbar is flat against the > casting when the bolts are tight. > randy > FC 3208 Fan Bracket Plate - putneyflash@... - 06-29-2006 14:09 They carry a cat part number, but like emike says they are just flat stock re brake 1983 fc-35 sb " sagecoach" -------------- Original message from "Mike Hohnstein" <MHOHNSTEIN@...>: -------------- 3/16" flat stock will work well. MH ----- Original Message ----- From: dthollis1961 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 22, 2006 8:46 AM Subject: [WanderlodgeForum] FC 3208 Fan Bracket Plate My recently acquired 84 FC35 has had 2 Horton Air Fans and 2 radiators in as many years (not on my dime). There are no plates (spacers) between the bolt heads and the fan bracket where the fan bolts to the front of the engine and I would like to get some of these plates and install them. Can anyone recall if these plates are simply flat stock with 2 holes in them or is there more to them? Thanks David Hollis 84 FC35 Springfield,IL [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] FC 3208 Fan Bracket Plate - dthollis1961 - 06-29-2006 23:15 Thanks. Got them made and put on. Not sure if I got the wrong Horton fan or if they are made in "one size fits all." The slots where you bolt the fan to the front of the engine are about 1/2" wide but the bolts are 3/8". I made some bushings. David Hollis 84 FC35 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, putneyflash@... wrote: > > They carry a cat part number, but like emike says they are just flat stock > > re brake 1983 fc-35 sb " sagecoach" > -------------- Original message from "Mike Hohnstein" <MHOHNSTEIN@...>: -------------- > > > 3/16" flat stock will work well. > MH > ----- Original Message ----- > From: dthollis1961 > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, June 22, 2006 8:46 AM > Subject: [WanderlodgeForum] FC 3208 Fan Bracket Plate > > My recently acquired 84 FC35 has had 2 Horton Air Fans and 2 radiators > in as many years (not on my dime). There are no plates (spacers) > between the bolt heads and the fan bracket where the fan bolts to the > front of the engine and I would like to get some of these plates and > install them. Can anyone recall if these plates are simply flat stock > with 2 holes in them or is there more to them? > > Thanks > > David Hollis 84 FC35 Springfield,IL > > [Non-text portions of this message have been removed] > > > > > [Non-text portions of this message have been removed] > |
