Sporlan valve? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Sporlan valve? (/showthread.php?tid=283) |
Sporlan valve? - Kurt Achenbach - 04-17-2005 00:47 Hello, Now that the ice is finally gone from my driveway, I could get the coach to the house. Still having problem with the water system. -Pump keeps running without building pressure to shut off, with Fill switch in either position. -Also water fills tank with Fill switch off. Had Sporlan valve apart, cleaned membrane etc. Found four parts inside. A small spring attached to a plunger, and a stainless steel soucer pressing on the membrane in the lower part of the valve. Seams the plunger does not have enough extension or force onto the soucer and membrane to seal the water flow in the lower portion of the valve. Any suggestions greatly appreciated. Kurt 83FC35SB in New Hampshire Sporlan valve? - Jeff Miller - 04-17-2005 12:40 It sounds like a classic Sporlan valve failure, probably time to buy the rebuild kit. - Jeff Miller http://www.wanderlodge.net --- In WanderlodgeForum@yahoogroups.com, "Kurt Achenbach" wrote: > > Hello, > > Now that the ice is finally gone from my driveway, I could get the > coach to the house. > Still having problem with the water system. > -Pump keeps running without building pressure to shut off, with Fill > switch in either position. > -Also water fills tank with Fill switch off. > Had Sporlan valve apart, cleaned membrane etc. Found four parts inside. > A small spring attached to a plunger, and a stainless steel soucer > pressing on the membrane in the lower part of the valve. Seams the > plunger does not have enough extension or force onto the soucer and > membrane to seal the water flow in the lower portion of the valve. > Any suggestions greatly appreciated. > > Kurt > 83FC35SB in New Hampshire |
