Toyota Toad - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Toyota Toad (/showthread.php?tid=2853) |
Toyota Toad - Wallace Craig - 06-26-2006 08:10 Has anyone used a Toyato pickup as a towed vehicle? If so would appreciate your views? Wallace Craig 95 WLWB 42 Azle, Texas [Non-text portions of this message have been removed] Toyota Toad - Pete Masterson - 06-26-2006 08:30 On Jun 26, 2006, at 1:10 PM, Wallace Craig wrote: > Has anyone used a Toyato pickup as a towed vehicle? If so would > appreciate your views? > > Wallace Craig > 95 WLWB 42 > Azle, Texas I have a '93 Camry and a '03 Echo (both automatics) ... after reviewing all the possibilities, I'm getting a dolly. If your pickup is a stick and/or 4WD, there may be some flat-towing options. Remco <http://www.remcotowing.com> has lubrication pumps or other add ons for auto-trans Toyotas (depending on model and year). Don't forget to add some sort of supplemental braking as well, if you flat-tow. Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 4203 El Sobrante, CA Toyota Toad - birdshill123 - 06-26-2006 12:00 WE tow an 05 Tacoma 4wd auto. Had a Remco Driveshaft disconnect installed. Great vehicle and tows well. Any of the newer Toys cannot be towed without the disconnect due to the electronic transfer case. Bruce |
