Gen Coolant Status...& The Next Project... - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Gen Coolant Status...& The Next Project... (/showthread.php?tid=2863) |
Gen Coolant Status...& The Next Project... - Curt Sprenger - 06-27-2006 13:36 Generator Coolant system is upgraded with all new parts. Ran the unit today for 30 minutes and all is fine, except the oil and temperature readings. The oil gauge is bad. I'll call Bluebird tomorrow morning and attempt to find out if I received a non-matching temperature sender from them. The next project, of many... Coach & Generator Battery Isolation. The large solenoid/diode that separates the two battery systems...anyone know where I can buy the large solenoid? That is Large as in amp capacity. Bluebird tells me they want over $300.00 for one. Ouch! -- Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Gen Coolant Status...& The Next Project... - Leroy Eckert - 07-02-2006 11:56 Hey Curt, Good to here that your genset is up and going. Did that oil pressure guage work before you did all of the work? If so, did you keep the old sender? If it worked before you could install the old sender and see whats happens. My oil pressure guage works but will need to be replaced sometime in the near future. Leroy Eckert 1990 WB-40 Niceville, FL. ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com ; wanderlodge@yahoogroups.com Sent: Tuesday, June 27, 2006 8:36 PM Subject: [WanderlodgeForum] Gen Coolant Status...& The Next Project... Generator Coolant system is upgraded with all new parts. Ran the unit today for 30 minutes and all is fine, except the oil and temperature readings. The oil gauge is bad. I'll call Bluebird tomorrow morning and attempt to find out if I received a non-matching temperature sender from them. The next project, of many... Coach & Generator Battery Isolation. The large solenoid/diode that separates the two battery systems...anyone know where I can buy the large solenoid? That is Large as in amp capacity. Bluebird tells me they want over $300.00 for one. Ouch! -- Curt Sprenger 1987 PT38, Anaheim Hills, Calif. [Non-text portions of this message have been removed] Gen Coolant Status...& The Next Project... - Curt Sprenger - 07-02-2006 17:24 Hi Leroy, The oil pressure gauge did not work before all the latest coolant work. Last year it was diagnosed by the shop that the gauge was bad. I tested the oil pressure with a mechanical gauge and the pressure is at 80 pounds cold, 60 pounds warmed up. I did reinstall the old coolant temperature sending unit. The temperature gauge reads high...I'm guessing, by about 15 degrees. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Leroy Eckert wrote: > Hey Curt, > > Good to here that your genset is up and going. Did that oil pressure > guage work before you did all of the work? If so, did you keep the old > sender? If it worked before you could install the old sender and see > whats happens. My oil pressure guage works but will need to be > replaced sometime in the near future. > > Leroy Eckert > 1990 WB-40 > Niceville, FL. > > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > > wanderlodge@yahoogroups.com > Sent: Tuesday, June 27, 2006 8:36 PM > Subject: [WanderlodgeForum] Gen Coolant Status...& The Next Project... > > Generator Coolant system is upgraded with all new parts. Ran the unit > today for 30 minutes and all is fine, except the oil and temperature > readings. The oil gauge is bad. I'll call Bluebird tomorrow morning and > attempt to find out if I received a non-matching temperature sender from > them. > > The next project, of many... > > Coach & Generator Battery Isolation. The large solenoid/diode that > separates the two battery systems...anyone know where I can buy the > large solenoid? That is Large as in amp capacity. Bluebird tells me they > want over $300.00 for one. Ouch! > > -- > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > [Non-text portions of this message have been removed] > > |
