Diesel Fuel in the Valley - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Diesel Fuel in the Valley (/showthread.php?tid=2867) |
Diesel Fuel in the Valley - pattypape - 06-28-2006 07:23 Hi All, I gatta a problem......... After some detective work and searching the archieves, I think the throttle control shaft seal on the injection pump is leaking. I have a drawing of this area, It looks simple enough, about seven bolts, a few gasket and a seal. Inside the pump there is a control shaft and a riser shaft. They are aligned and clipped onto the throttle shaft. Not sure, I want to take this apart???????????????? Had anyone replaced the throttle shaft seal on the injection pump? Has anyone removed the rear cover of the injection pump? Does the injection pump need to be removed to access this rear cover? Any help or advice appreiciated. Bill 88 FC, weeping fuel Diesel Fuel in the Valley - dthollis1961 - 06-28-2006 13:47 Bill, My recently acquired 84 FC35 was filling up the valley and running down onto the ground. With lights, mirrors and standing on my head, I couldn't see where the leak was and was ready to pull the pump. I saw some dampness on some of the 8 lines that run from the pump to the injectors and didn't think that was the problem, but tightened them anyway. Problem solved. David Hollis 84 FC35 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > Hi All, > > I gatta a problem......... > > After some detective work and searching the archieves, > I think the throttle control shaft seal on the > injection pump is leaking. > > I have a drawing of this area, It looks simple enough, about seven > bolts, a few gasket and a seal. Inside the pump there is a control > shaft and a riser shaft. They are aligned and clipped onto the > throttle shaft. > Not sure, I want to take this apart???????????????? > > > Had anyone replaced the throttle shaft seal on the injection pump? > Has anyone removed the rear cover of the injection pump? > Does the injection pump need to be removed to access this rear cover? > > > Any help or advice appreiciated. > > Bill 88 FC, weeping fuel > Diesel Fuel in the Valley - davidkerryedwards - 07-01-2006 13:20 If this is the seal I am thinking of, I ran across an account somewhere of this same problem, although the symptom was stalling at low speeds as air was getting sucked into the system. The page had a whole series of pictures showing the owner of the coach replaciing the seal. Perhaps if you google it, you could find it. It's been a number of months since I looked at the site, but my recollection is that the repair was not that complicated, just a little time consuming since it involved removing the intake manifolds. The injection pump was not removed but there was a kind of cover on the top of the pump (?) that was removed to access the shaft. Kerry --- In WanderlodgeForum@yahoogroups.com, "pattypape" > > Hi All, > > I gatta a problem......... > > After some detective work and searching the archieves, > I think the throttle control shaft seal on the > injection pump is leaking. > > I have a drawing of this area, It looks simple enough, about seven > bolts, a few gasket and a seal. Inside the pump there is a control > shaft and a riser shaft. They are aligned and clipped onto the > throttle shaft. > Not sure, I want to take this apart???????????????? > > > Had anyone replaced the throttle shaft seal on the injection pump? > Has anyone removed the rear cover of the injection pump? > Does the injection pump need to be removed to access this rear cover? > > > Any help or advice appreiciated. > > Bill 88 FC, weeping fuel > Diesel Fuel in the Valley - davidkerryedwards - 07-01-2006 13:20 If this is the seal I am thinking of, I ran across an account somewhere of this same problem, although the symptom was stalling at low speeds as air was getting sucked into the system. The page had a whole series of pictures showing the owner of the coach replaciing the seal. Perhaps if you google it, you could find it. It's been a number of months since I looked at the site, but my recollection is that the repair was not that complicated, just a little time consuming since it involved removing the intake manifolds. The injection pump was not removed but there was a kind of cover on the top of the pump (?) that was removed to access the shaft. Kerry --- In WanderlodgeForum@yahoogroups.com, "pattypape" > > Hi All, > > I gatta a problem......... > > After some detective work and searching the archieves, > I think the throttle control shaft seal on the > injection pump is leaking. > > I have a drawing of this area, It looks simple enough, about seven > bolts, a few gasket and a seal. Inside the pump there is a control > shaft and a riser shaft. They are aligned and clipped onto the > throttle shaft. > Not sure, I want to take this apart???????????????? > > > Had anyone replaced the throttle shaft seal on the injection pump? > Has anyone removed the rear cover of the injection pump? > Does the injection pump need to be removed to access this rear cover? > > > Any help or advice appreiciated. > > Bill 88 FC, weeping fuel > Diesel Fuel in the Valley - pattypape - 07-02-2006 01:44 Kerry, Thanks for the response, I Googled and posted on a few sites. I have not gathered enough information to tackle this job myself. I could not find the site, with pictures of how to replace the throttle rod seal. I have a parts blow-up picture of the injection pump. If the rear cover is removed a lot of part can fall out, push rods, springs, governor weights etc, It looks easy enough, seven bolts, but I am hesitant to try this with out experience. I wish I had an old injection pump to disect. Bill 88 FC Michigan -- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > If this is the seal I am thinking of, I ran across an account somewhere of this same > problem, although the symptom was stalling at low speeds as air was getting sucked into > the system. The page had a whole series of pictures showing the owner of the coach > replaciing the seal. Perhaps if you google it, you could find it. It's been a number of > months since I looked at the site, but my recollection is that the repair was not that > complicated, just a little time consuming since it involved removing the intake manifolds. > The injection pump was not removed but there was a kind of cover on the top of the pump > (?) that was removed to access the shaft. > > Kerry > > > --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > > > Hi All, > > > > I gatta a problem......... > > > > After some detective work and searching the archieves, > > I think the throttle control shaft seal on the > > injection pump is leaking. > > > > I have a drawing of this area, It looks simple enough, about seven > > bolts, a few gasket and a seal. Inside the pump there is a control > > shaft and a riser shaft. They are aligned and clipped onto the > > throttle shaft. > > Not sure, I want to take this apart???????????????? > > > > > > Had anyone replaced the throttle shaft seal on the injection pump? > > Has anyone removed the rear cover of the injection pump? > > Does the injection pump need to be removed to access this rear cover? > > > > > > Any help or advice appreiciated. > > > > Bill 88 FC, weeping fuel > > > Diesel Fuel in the Valley - davidkerryedwards - 07-02-2006 02:43 I couldn't find it on a google either. I seem to recall that only a small cover with a couple of bolts had to be removed but I may be wrong. I can't find the procedure in the service manual I have either. Kerry --- In WanderlodgeForum@yahoogroups.com, "pattypape" > > > > Kerry, > > Thanks for the response, > I Googled and posted on a few sites. I have not gathered enough > information to tackle this job myself. I could not find the site, > with pictures of how to replace the throttle rod seal. > > I have a parts blow-up picture of the injection pump. If the rear > cover is removed a lot of part can fall out, push rods, springs, > governor weights etc, It looks easy enough, seven bolts, but I am > hesitant to try this with out experience. > I wish I had an old injection pump to disect. > > Bill 88 FC Michigan > > > -- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > If this is the seal I am thinking of, I ran across an account > somewhere of this same > > problem, although the symptom was stalling at low speeds as air > was getting sucked into > > the system. The page had a whole series of pictures showing the > owner of the coach > > replaciing the seal. Perhaps if you google it, you could find > it. It's been a number of > > months since I looked at the site, but my recollection is that the > repair was not that > > complicated, just a little time consuming since it involved > removing the intake manifolds. > > The injection pump was not removed but there was a kind of cover > on the top of the pump > > (?) that was removed to access the shaft. > > > > Kerry > > > > > > --- In WanderlodgeForum@yahoogroups.com, "pattypape" > wrote: > > > > > > Hi All, > > > > > > I gatta a problem......... > > > > > > After some detective work and searching the archieves, > > > I think the throttle control shaft seal on the > > > injection pump is leaking. > > > > > > I have a drawing of this area, It looks simple enough, about > seven > > > bolts, a few gasket and a seal. Inside the pump there is a > control > > > shaft and a riser shaft. They are aligned and clipped onto the > > > throttle shaft. > > > Not sure, I want to take this apart???????????????? > > > > > > > > > Had anyone replaced the throttle shaft seal on the injection > pump? > > > Has anyone removed the rear cover of the injection pump? > > > Does the injection pump need to be removed to access this rear > cover? > > > > > > > > > Any help or advice appreiciated. > > > > > > Bill 88 FC, weeping fuel > > > > > > Diesel Fuel in the Valley - davidkerryedwards - 07-02-2006 03:05 Did you see this post over at the Cat RV forum. It doesn't sound as if a lot of parts need to be removed: Pat, > > The seal was bad under the top cover, There's not supposed > > to be any > > fuel visible if you take your fuel shut off solenoid off > > and look > > down in the hole.Mine had fuel in it, almost full. What > > happens is > > that either the throttle shaft seal, or the seal under the > > cover > > starts leaking a little air. The injector pump is also the > > fuel pump > > and sucks fuel from the tank. If there's an air leak, its > > easier for > > the air to come in than the fuel, then you start pumping > > air to the > > injectors. I had already changed the throttle shaft seal > > two weeks > > ago, its the one that usually goes bad first. Its also the > > hardest > > to get to. You have to remove the intake and at least one > > injector > > line to get to it. The top cover comes right off without > > removing > > anything. It's an easy enough job to do yourself, You just > > need the > > parts. The mechanic said they usually last about 12-15 > > years. > > When they install a seal on The throttle shaft they also > > install a > > check valve in the governor housing to reduce the pressure > > on the > > seal. > > Lee Kerry --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" wrote: > > I couldn't find it on a google either. I seem to recall that only a small cover with a couple > of bolts had to be removed but I may be wrong. I can't find the procedure in the service > manual I have either. > > Kerry > > --- In WanderlodgeForum@yahoogroups.com, "pattypape" > > > > > > > > Kerry, > > > > Thanks for the response, > > I Googled and posted on a few sites. I have not gathered enough > > information to tackle this job myself. I could not find the site, > > with pictures of how to replace the throttle rod seal. > > > > I have a parts blow-up picture of the injection pump. If the rear > > cover is removed a lot of part can fall out, push rods, springs, > > governor weights etc, It looks easy enough, seven bolts, but I am > > hesitant to try this with out experience. > > I wish I had an old injection pump to disect. > > > > Bill 88 FC Michigan > > > > > > -- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > > > > If this is the seal I am thinking of, I ran across an account > > somewhere of this same > > > problem, although the symptom was stalling at low speeds as air > > was getting sucked into > > > the system. The page had a whole series of pictures showing the > > owner of the coach > > > replaciing the seal. Perhaps if you google it, you could find > > it. It's been a number of > > > months since I looked at the site, but my recollection is that the > > repair was not that > > > complicated, just a little time consuming since it involved > > removing the intake manifolds. > > > The injection pump was not removed but there was a kind of cover > > on the top of the pump > > > (?) that was removed to access the shaft. > > > > > > Kerry > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "pattypape" > > wrote: > > > > > > > > Hi All, > > > > > > > > I gatta a problem......... > > > > > > > > After some detective work and searching the archieves, > > > > I think the throttle control shaft seal on the > > > > injection pump is leaking. > > > > > > > > I have a drawing of this area, It looks simple enough, about > > seven > > > > bolts, a few gasket and a seal. Inside the pump there is a > > control > > > > shaft and a riser shaft. They are aligned and clipped onto the > > > > throttle shaft. > > > > Not sure, I want to take this apart???????????????? > > > > > > > > > > > > Had anyone replaced the throttle shaft seal on the injection > > pump? > > > > Has anyone removed the rear cover of the injection pump? > > > > Does the injection pump need to be removed to access this rear > > cover? > > > > > > > > > > > > Any help or advice appreiciated. > > > > > > > > Bill 88 FC, weeping fuel > > > > > > > > > > Diesel Fuel in the Valley - towanda692006 - 07-03-2006 11:09 --- In WanderlodgeForum@yahoogroups.com, "dthollis1961" wrote: > > Bill, > > My recently acquired 84 FC35 was filling up the valley and running > down onto the ground. With lights, mirrors and standing on my head, > I couldn't see where the leak was and was ready to pull the pump. I > saw some dampness on some of the 8 lines that run from the pump to > the injectors and didn't think that was the problem, but tightened > them anyway. Problem solved. > > David Hollis 84 FC35 Springfield,IL > > > --- In WanderlodgeForum@yahoogroups.com, "pattypape" > wrote: > > > > Hi All, > > > > I gatta a problem......... > > > > After some detective work and searching the archieves, > > I think the throttle control shaft seal on the > > injection pump is leaking. > > > > I have a drawing of this area, It looks simple enough, about seven > > bolts, a few gasket and a seal. Inside the pump there is a control > > shaft and a riser shaft. They are aligned and clipped onto the > > throttle shaft. > > Not sure, I want to take this apart???????????????? > > > > > > Had anyone replaced the throttle shaft seal on the injection pump? > > Has anyone removed the rear cover of the injection pump? > > Does the injection pump need to be removed to access this rear > cover? > > > > > > Any help or advice appreiciated. > > > > Bill 88 FC, weeping fuel > > >To all, I may have an idea what is causing the leakeage you are experiencing. As you will soon be aware the sulfur level of on-road diesel is being lowered in most areas to 15ppm unless marked on the pump "low sulfur 500ppm". By October 31, 2007 most pumps will be at 15ppm, due to the difficulty of pipelines to deliver both 500ppm and 15ppm product. The process of removing the sulfur is causing leakage in some older fuel pumps. From what we are hearing the cost is not excessive, about $200, but it is a nuisance. Thus far we have not heard of any problems relating to injectors, just the seals on the injector pump metering rod. Ken Marsh ToWanda 89WB 40PT Diesel Fuel in the Valley - pattypape - 07-03-2006 15:18 Ken, Thanks for the response, There is some information about low sulfer fuel causing problems on the Cat RV Forum. I am still trying to collect information on changing the throttle rod seal, Cat said this is a common leak. I am trying to decide if this is a repair that I can complete. So, it might be wise for owners of the older 3208's, to have a solution ready, if or when their throttle rod seal begins to leak. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "towanda692006" > > --- In WanderlodgeForum@yahoogroups.com, "dthollis1961" > wrote: > > > > Bill, > > > > My recently acquired 84 FC35 was filling up the valley and running > > down onto the ground. With lights, mirrors and standing on my head, > > I couldn't see where the leak was and was ready to pull the pump. I > > saw some dampness on some of the 8 lines that run from the pump to > > the injectors and didn't think that was the problem, but tightened > > them anyway. Problem solved. > > > > David Hollis 84 FC35 Springfield,IL > > > > > > --- In WanderlodgeForum@yahoogroups.com, "pattypape" > > wrote: > > > > > > Hi All, > > > > > > I gatta a problem......... > > > > > > After some detective work and searching the archieves, > > > I think the throttle control shaft seal on the > > > injection pump is leaking. > > > > > > I have a drawing of this area, It looks simple enough, about seven > > > bolts, a few gasket and a seal. Inside the pump there is a control > > > shaft and a riser shaft. They are aligned and clipped onto the > > > throttle shaft. > > > Not sure, I want to take this apart???????????????? > > > > > > > > > Had anyone replaced the throttle shaft seal on the injection pump? > > > Has anyone removed the rear cover of the injection pump? > > > Does the injection pump need to be removed to access this rear > > cover? > > > > > > > > > Any help or advice appreiciated. > > > > > > Bill 88 FC, weeping fuel > > > > >To all, I may have an idea what is causing the leakeage you are > experiencing. As you will soon be aware the sulfur level of on-road > diesel is being lowered in most areas to 15ppm unless marked on the > pump "low sulfur 500ppm". By October 31, 2007 most pumps will be at > 15ppm, due to the difficulty of pipelines to deliver both 500ppm and > 15ppm product. The process of removing the sulfur is causing leakage > in some older fuel pumps. From what we are hearing the cost is not > excessive, about $200, but it is a nuisance. Thus far we have not > heard of any problems relating to injectors, just the seals on the > injector pump metering rod. > > Ken Marsh > ToWanda > 89WB 40PT > |
