Power steering saga continues - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Power steering saga continues (/showthread.php?tid=2868) |
Power steering saga continues - tommy240842@... - 06-28-2006 20:13 Sometimes I wonder if instances like this are an omen. The got the Pittman arm off eventually, had to heat it with a torch, because after breaking three puller, that was the only foreseeable alternative, and it did come right off. Put the replacement seal back in, put everything back together and power steering fluid just poured right past the shaft when I put it in the reservoir. Not a good sight. So this morning they are going to take everything back out and see why it is leaking. If any of you have any brilliant suggestions, please don't hesitate to call me at 843-475-6304. These guys have collectively replaced hundreds of seals (arf arf) in power steering pumps. Of course I am at a complete baffled loss. One thing noted, in the seal kit I have, it shows more seals going in (in the diagram) than what he took out. Not wanting to spend another night in the garage. Tom Meservey, USN (Ret) '81FC33' E. T. Associates, N. Charleston, SC [Non-text portions of this message have been removed] Power steering saga continues - rwoodysurplus - 06-29-2006 13:30 TOM, I have replaced a few (not 100+) and I have never got the 1 end seal to fix a leak! There is always a outer dust/grime seal a wiper then another seal that is the 1 leaking...... I do not have a blowup of the box but bet they have to get another kit and replace all of the shaft seals to get it fixed..... But IMO.....I would just buy a used box that is not leaking and its tight or a rebuilt 1 after the labor is figured and pc of mind that it is repaired proper.... In conclusion..is that its VERY hard to fix a pitman arm seal that lasts after they start leaking...Impossible on the bus..... Woody at FT BRAGG 81fcRb wrenching all my life...... --- In WanderlodgeForum@yahoogroups.com, tommy240842@... wrote: > > Sometimes I wonder if instances like this are an omen. The got the Pittman > arm off eventually, had to heat it with a torch, because after breaking three > puller, that was the only foreseeable alternative, and it did come right off. > > Put the replacement seal back in, put everything back together and power > steering fluid just poured right past the shaft when I put it in the reservoir. > Not a good sight. So this morning they are going to take everything back out > and see why it is leaking. > > If any of you have any brilliant suggestions, please don't hesitate to call > me at 843-475-6304. These guys have collectively replaced hundreds of seals > (arf arf) in power steering pumps. Of course I am at a complete baffled > loss. One thing noted, in the seal kit I have, it shows more seals going in (in > the diagram) than what he took out. > > Not wanting to spend another night in the garage. > > Tom Meservey, USN (Ret) > '81FC33' E. T. Associates, N. Charleston, SC > > > [Non-text portions of this message have been removed] > |
