Facet Fan Info - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Facet Fan Info (/showthread.php?tid=2869) |
Facet Fan Info - Rick A. - 06-29-2006 02:31 Bill, On my 84 FC the Facet Fan was not working properly and I would throw the belts occassionally? I ended up replacing the bearings because they were all dry, and discovered it was not assembled correctly by someone before me? Also while the fan was off and seeing it's dry bearings I discovered the same situation with the idler pulleys. Dry bearings. After repairing all this no more fan or belt problems. Call me at 817-737-6614 and I can fax you a parts breakdown of the facet fan. Rick Archie 85PT40 "Fort R" Fort Worth |
