What is this little beeping thing? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: What is this little beeping thing? (/showthread.php?tid=2870) |
What is this little beeping thing? - krminyl@... - 06-28-2006 23:52 It is most likely the on/off electric valve that shuts off the LP supply to your LP appliances. Kevin McKeown YL CA 86 38 PT [Non-text portions of this message have been removed] What is this little beeping thing? - Scott Forman - 06-29-2006 03:01 Mounted below the refrigerator near the floor in my FC kitchen is some sort of detector/alarm device. It has a small red LED light that is always on, and a 'test' button that emits a high-pitched alarm when pushed. What is this an alarm for? Every once in a while, it will beep once. Usually the beep seems to happen when I am operating on battery power and the water pump is activated. It doesn't do it every time. I wondered if it might be some sort of low battery voltage alarm, but it will sometimes let out the beep even when the batteries are fully charged. It has never gone off any other way. What is this thing? Scott Forman 82 FC35RB Memphis What is this little beeping thing? - John Suter - 06-29-2006 03:59 Hi Scott, Could it be your LP Gas alarm/monitor? Depending upon your model and various LP accessories, often there is an electrical shut off outside near the diesel fill and LP fill, to permit all gas appliances to be shut off during LP filling and diesel filling. That shut off could be called "the Master shut off." Also, there is normally another internal monitor/shut off and reset, which beeps and shuts down all LP flow should a leak in LP be detected at floor level within the coach. Remember, LP is heavier than air so testing/monitoring is completed at low points. Sometimes the LP detector will alarm from odors besides LP. Have any dogs??? John Suter --- Scott Forman <sforman@...> wrote: > Mounted below the refrigerator near the floor in my > FC kitchen is some > sort of detector/alarm device. It has a small red > LED light that is > always on, and a 'test' button that emits a > high-pitched alarm when > pushed. What is this an alarm for? > > Every once in a while, it will beep once. Usually > the beep seems to > happen when I am operating on battery power and the > water pump is > activated. It doesn't do it every time. I wondered > if it might be > some sort of low battery voltage alarm, but it will > sometimes let out > the beep even when the batteries are fully charged. > It has never gone > off any other way. > > What is this thing? > > Scott Forman > 82 FC35RB > Memphis > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com What is this little beeping thing? - Richard Hayden - 06-29-2006 04:23 Propane sniffer/shutoff. It is supposed to activate that big in-line valve behind the refer when there is a leak detected. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 29, 2006 8:01 AM Subject: [WanderlodgeForum] What is this little beeping thing? Mounted below the refrigerator near the floor in my FC kitchen is some sort of detector/alarm device. It has a small red LED light that is always on, and a 'test' button that emits a high-pitched alarm when pushed. What is this an alarm for? Every once in a while, it will beep once. Usually the beep seems to happen when I am operating on battery power and the water pump is activated. It doesn't do it every time. I wondered if it might be some sort of low battery voltage alarm, but it will sometimes let out the beep even when the batteries are fully charged. It has never gone off any other way. What is this thing? Scott Forman 82 FC35RB Memphis [Non-text portions of this message have been removed] What is this little beeping thing? - Scott - 06-29-2006 04:26 Scott, that is a propane detector, the little switch beside it pushes in and the led "should" glow green. This is also a shut-off for the propane, should it detect propane. So push the switch in and it should glow green and the refer will work on propane. If you try this and it continues to glow red and beep shut the main propane off at the tank and further investigate...as a old "hero" once said ..."be vewey. vewey careful. (Elmer Fudd) ScottB 86FC35 "RUBY" Murrells Inlet SC "right next to heaven" --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Mounted below the refrigerator near the floor in my FC kitchen is some > sort of detector/alarm device. It has a small red LED light that is > always on, and a 'test' button that emits a high-pitched alarm when > pushed. What is this an alarm for? > > Every once in a while, it will beep once. Usually the beep seems to > happen when I am operating on battery power and the water pump is > activated. It doesn't do it every time. I wondered if it might be > some sort of low battery voltage alarm, but it will sometimes let out > the beep even when the batteries are fully charged. It has never gone > off any other way. > > What is this thing? > > Scott Forman > 82 FC35RB > Memphis > What is this little beeping thing? - Bruce Morris - 06-29-2006 15:25 Scott, I think you will find that the short beeps are probably caused by low battery voltage to the sensor. Bruce Morris (919)872-7635 Raleigh, NC Webmaster - Wanderlodge Owners Online 1983 WL FC35RB FMCA: 7142s Ham Radio: KI4ME Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv ----- Original Message ----- From: Richard Hayden To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 29, 2006 12:23 PM Subject: Re: [WanderlodgeForum] What is this little beeping thing? Propane sniffer/shutoff. It is supposed to activate that big in-line valve behind the refer when there is a leak detected. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 29, 2006 8:01 AM Subject: [WanderlodgeForum] What is this little beeping thing? Mounted below the refrigerator near the floor in my FC kitchen is some sort of detector/alarm device. It has a small red LED light that is always on, and a 'test' button that emits a high-pitched alarm when pushed. What is this an alarm for? Every once in a while, it will beep once. Usually the beep seems to happen when I am operating on battery power and the water pump is activated. It doesn't do it every time. I wondered if it might be some sort of low battery voltage alarm, but it will sometimes let out the beep even when the batteries are fully charged. It has never gone off any other way. What is this thing? Scott Forman 82 FC35RB Memphis [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
