horn wire short - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: horn wire short (/showthread.php?tid=2873) |
horn wire short - dlefty12 - 06-30-2006 01:34 When I turn the wheel to the right or left the horn blows. I took the telescoping ring and wheel off, but the short is not in this area. Must be in the column. If I can locate where the yellow wire comes out of the column maybe I could snake the wire out and pull a new wire in. Has anyone had a similar problem? If so how did you repair the wire. Dan Leftwich FC35 1987. |
