ZF tranny 90SP36 - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: ZF tranny 90SP36 (/showthread.php?tid=2874) |
ZF tranny 90SP36 - williamcharrison - 06-30-2006 02:31 The transmission fluid in my sp measures the same level hot or cold. It also occurred to me that the filter may need changed (I have owned the coach for 1 year) and it had an engine oil change just before I took delivery. There are 3 filters located close together under the engine, can someone tell me what the function of each one is and possibly a replacement part number? Chuck Harrison 90 SP36 Akron, Ohio ZF tranny 90SP36 - pattypape - 06-30-2006 05:54 Yep, Chuck, The fluid on the ZF is kinda strange. Cold is cold, hot is 200 degrees, I take several readings over a period of time, when hot or cold, It seems the fluid level changes a bit or hides someplace. Careful not to overfill. I think, we have the same 300 HP 3208 Cat & ZF trans, your engine in the rear, FC in the front. Two Cat oil filters #1R-0714 one fuel filter #1R-0750 ZF Transmission filter #4139298038 I used almost 5 gallons of Transynd synthethic to change, because of the heat generated by the retarder. I use Manufacturers' recommended filters, only a Dollar more in cost. Do not forget the Racor filter. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > The transmission fluid in my sp measures the same level hot or cold. > It also occurred to me that the filter may need changed (I have > owned the coach for 1 year) and it had an engine oil change just before > I took delivery. There are 3 filters located close together under the > engine, can someone tell me what the function of each one is and > possibly a replacement part number? > > Chuck Harrison > 90 SP36 > Akron, Ohio > ZF tranny 90SP36 - williamcharrison - 06-30-2006 06:35 Thanks Bill, where do you order the filters? > Chuck, > > The fluid on the ZF is kinda strange. > Cold is cold, hot is 200 degrees, I take several readings > over a period of time, when hot or cold, It seems the fluid > level changes a bit or hides someplace. Careful not to overfill. > > > I think, we have the same 300 HP 3208 Cat & ZF trans, your engine > in the rear, FC in the front. > > Two Cat oil filters #1R-0714 one fuel filter #1R-0750 > > ZF Transmission filter #4139298038 > I used almost 5 gallons of Transynd synthethic to change, > because of the heat generated by the retarder. > > I use Manufacturers' recommended filters, only a Dollar more in > cost. Do not forget the Racor filter. > > Bill 88 FC Michigan > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > > The transmission fluid in my sp measures the same level hot or > cold. > > It also occurred to me that the filter may need changed (I have > > owned the coach for 1 year) and it had an engine oil change just > before > > I took delivery. There are 3 filters located close together under > the > > engine, can someone tell me what the function of each one is and > > possibly a replacement part number? > > > > Chuck Harrison > > 90 SP36 > > Akron, Ohio > > > ZF tranny 90SP36 - pattypape - 06-30-2006 08:11 3208 oil & fuel filters available from your local Caterpillar Dealer Racor fuel filters from West Marine boating stores. All of these filters are available from NAPA stores, they will fit and work just fine, I prefer Caterpillar parts. I like the bright yellow Paint ![]() ZF is a little more difficult try their web sites http://www.zf.com/defaultz.asp?id=813&lang=1 http://www.zf.com/na/defaultz.asp These web sites are not user friendly , so keep searching for a nearby, US dealer or any ZF dealer will ship a filter. Dextron trans fluid available at any auto parts store or, Transynd available at Allison trans dealers. Last year the filter and each gallon was about $35/40 each. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > Thanks Bill, where do you order the filters? > > > Chuck, > > > > The fluid on the ZF is kinda strange. > > Cold is cold, hot is 200 degrees, I take several readings > > over a period of time, when hot or cold, It seems the fluid > > level changes a bit or hides someplace. Careful not to overfill. > > > > > > I think, we have the same 300 HP 3208 Cat & ZF trans, your engine > > in the rear, FC in the front. > > > > Two Cat oil filters #1R-0714 one fuel filter #1R-0750 > > > > ZF Transmission filter #4139298038 > > I used almost 5 gallons of Transynd synthethic to change, > > because of the heat generated by the retarder. > > > > I use Manufacturers' recommended filters, only a Dollar more in > > cost. Do not forget the Racor filter. > > > > Bill 88 FC Michigan > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > > > > > > > The transmission fluid in my sp measures the same level hot or > > cold. > > > It also occurred to me that the filter may need changed (I have > > > owned the coach for 1 year) and it had an engine oil change just > > before > > > I took delivery. There are 3 filters located close together > under > > the > > > engine, can someone tell me what the function of each one is and > > > possibly a replacement part number? > > > > > > Chuck Harrison > > > 90 SP36 > > > Akron, Ohio > > > > > > |
