plumbing question - davidkerryedwards - 07-02-2006 03:26
I posted about my plumbing breaks a few weeks ago. I've got water enough to
work with at
the moment but I am confused about how the system works and since it hasn't
worked since
I owned the coach I have no experience with it working properly. I had two
breaks, one in a
line going from under the vanity to the right side of the shower valve and one
behind the
tank--top line of the three. I replaced both with reinforced flexible hose.
But something is
not right. I have very little hot water flowing when the pump is on--a burst
for a second or
two, then a drizzle at the vanity. I have no hot water at all with city
pressure and very little
water either hot or coldl to the shower with city pressure but a good flow to
the shower with
the pump. Any ideas on what I'm missing conceptually about the system and what
is wrong
with it? Not in a big hurry to fix it at the moment since I'm on the road, but
I'm trying to
understand what is happening.
Kerry
plumbing question - Jana Ewart - 09-12-2010 13:17
How would you go about finding someone to replace the kitchen faucet
and instant hot? Mike could do it except his shoulders won't fit
under the cabinet and his hands are too large to fit up behind it to
do the work. We have the new units, but haven't figured out how to
get up in there. Right now we are outside of Charlotte, North
Carolina. Thanks for your advice.
Mike and Jana Ewart
89 PT40WB
Blessed are the people whose God is the Lord. (Psalm 144:15)
plumbing question - Fred Hulse - 09-12-2010 13:25
Hi Mike & Jana
In my experience,I have found for that sort of work that an independent plumber would suit you fine.
Fred & Jeanne Hulse
Morristown,Arizona
97 WLWB41
plumbing question - Ernie Ekberg - 09-12-2010 22:45
Jana, are you going to the RATS rally? If so, I could do that next month.
Ernie- Cinci, Ohio
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Sun, 9/12/10, Jana Ewart wrote:
Subject: [WanderlodgeForum] plumbing question
Date: Sunday, September 12, 2010, 8:17 PM
Mike and Jana Ewart
89 PT40WB
plumbing question - Jana Ewart - 09-13-2010 02:07
Ernie,No -- we can't make it to RATS -- I had already committed for that weekend not knowing that was when RATS was.  How far away will you be?  Jana --SD Mike--NC
On Mon, Sep 13, 2010 at 6:45 AM, Ernie Ekberg <"ernietex@yahoo.com"> wrote:
Â
Ernie- Cinci, Ohio
83PT40
Wanderlodge
Â
Mike and Jana Ewart
89 PT40WB
plumbing question - Ernie Ekberg - 09-13-2010 07:49
I'm going to be in Ohio probably till Oct 10th. Then work my way to Ga.
83PT40
Wanderlodge
--- On Mon, 9/13/10, Jana Ewart wrote:
Subject: Re: [WanderlodgeForum] plumbing question
Date: Monday, September 13, 2010, 9:07 AM
Ernie,
No -- we can't make it to RATS -- I had alreadycommittedfor that weekend not knowing that was when RATS was. How far away will you be?
Jana --SD
Mike--NC
Ernie- Cinci, Ohio
83PT40
Wanderlodge
Mike and Jana Ewart
89 PT40WB
plumbing question - Jana Ewart - 09-13-2010 12:35
so does that mean you are passing through close to where we are?
On Mon, Sep 13, 2010 at 3:49 PM, Ernie Ekberg <"ernietex@yahoo.com"> wrote:
Â
83PT40
Wanderlodge
Â
Ernie,
No -- we can't make it to RATS -- I had already committed for that weekend not knowing that was when RATS was.  How far away will you be? Â
Jana --SD
Mike--NC
Â
Ernie- Cinci, Ohio
83PT40
Wanderlodge
Â
Mike and Jana Ewart
89 PT40WB
plumbing question - Ernie Ekberg - 09-13-2010 22:49
It doesn't look like I'll be close to you on this trip. Sorry.
83PT40
Wanderlodge
Date: Monday, September 13, 2010, 7:35 PM
83PT40
Wanderlodge
Ernie, No -- we can't make it to RATS -- I had alreadycommittedfor that weekend not knowing that was when RATS was. How far away will you be? Jana --SD
Mike--NC
Ernie- Cinci, Ohio
83PT40
Wanderlodge
Mike and Jana Ewart
89 PT40WB
