12R22.5 load range H tires for a PT40 - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 12R22.5 load range H tires for a PT40 (/showthread.php?tid=2895) |
12R22.5 load range H tires for a PT40 - Howard O. Truitt - 07-04-2006 07:32 Fellow Birds, I'm running Michelin 12R22.5 XZ2 load range H tires on my 86 8V92 PT40. I would be interested in the tire pressures anyone with a semilar unit and tires are running. As always thanks for your help. I have enjoyed this site so very much. Howard Truitt Camilla, Ga. 86 PT40 [Non-text portions of this message have been removed] 12R22.5 load range H tires for a PT40 - Leroy Eckert - 07-04-2006 14:37 Howard: I run 100PSI cold in my tires in summer. I run 110PSI cold in winter. I was advised to do so by an over the road trucker. The pressures have worked for me. I presume it has a lot to do with friction and air pressure increasing when heat is introduced. Great site, Happy 4th Leroy Eckert 1990 WB-40 Nicevile, FL ----- Original Message ----- From: Howard O. Truitt To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, July 04, 2006 2:32 PM Subject: [WanderlodgeForum] 12R22.5 load range H tires for a PT40 Fellow Birds, I'm running Michelin 12R22.5 XZ2 load range H tires on my 86 8V92 PT40. I would be interested in the tire pressures anyone with a semilar unit and tires are running. As always thanks for your help. I have enjoyed this site so very much. Howard Truitt Camilla, Ga. 86 PT40 [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
