Normal engine water temperature for a D-60, 2000 lxi??? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Normal engine water temperature for a D-60, 2000 lxi??? (/showthread.php?tid=2909) |
Normal engine water temperature for a D-60, 2000 lxi??? - luckyron1 - 07-06-2006 07:02 After noting wet hoses beneath the engine block, I had Detroit Diesel chase down several leaks. They found several rusty, loose hose clamps, also some leaky gaskets/seals on the oil cooler. It took 3 short trips, 2 of them free, but they finally got it right. No more budgeting for coolant. When the engine is idling, the water temp is around 180F. Under load, at 80F temps, it can run up to 235F. When cruising it stays in the area of 200F----210F. It seems high to me. Is this the normal temp range for the D-60? Thanks. Ron & Ruth in MN Normal engine water temperature for a D-60, 2000 lxi??? - Pete Masterson - 07-06-2006 07:46 That's about what I'm getting with my '95 Series 60. It seems high to me too. I'm going to pull the thermostat and check it ... and probably replace it with a new one rated at 180 degrees. While going west on I-70 in western Kansas (gradual grades climbing into Colorado), temps were running 200-210 and a bit higher. Had to keep one eye on the road and the other on the temp gauge. Ambient temperature was in the 80s at the time. I had overheating problems in eastern Nevada on the grades climbing out of Salt Lake City on I-80. Ambient temperatures were in the high 80s or low 90s at the time. I had to pull off repeatedly to let the engine cool down... (I got one 'overheated engine' light, but mostly it was simply high readings that caused me to pull over.) In cooler weather, I get 190-200 while running down the road. That seems more reasonable. On Jul 6, 2006, at 12:02 PM, luckyron1 wrote: > After noting wet hoses beneath the engine block, I had Detroit Diesel > chase down several leaks. They found several rusty, loose hose > clamps, also some leaky gaskets/seals on the oil cooler. It took 3 > short trips, 2 of them free, but they finally got it right. No more > budgeting for coolant. When the engine is idling, the water temp is > around 180F. Under load, at 80F temps, it can run up to 235F. When > cruising it stays in the area of 200F----210F. It seems high to me. > Is this the normal temp range for the D-60? Thanks. > > Ron & Ruth in MN > > . > > Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 4203 El Sobrante, CA [Non-text portions of this message have been removed] Normal engine water temperature for a D-60, 2000 lxi??? - Mike Hohnstein - 07-06-2006 07:58 It would be advisable to verify the accuracy of the dash indicator, if it proves to be correct, a fresh radiator might be a timely investment. I wonder if there is illumination here on the reason George left Hmmmm. MH ----- Original Message ----- From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Thursday, July 06, 2006 2:46 PM Subject: Re: [WanderlodgeForum] Normal engine water temperature for a D-60, 2000 lxi??? That's about what I'm getting with my '95 Series 60. It seems high to me too. I'm going to pull the thermostat and check it ... and probably replace it with a new one rated at 180 degrees. While going west on I-70 in western Kansas (gradual grades climbing into Colorado), temps were running 200-210 and a bit higher. Had to keep one eye on the road and the other on the temp gauge. Ambient temperature was in the 80s at the time. I had overheating problems in eastern Nevada on the grades climbing out of Salt Lake City on I-80. Ambient temperatures were in the high 80s or low 90s at the time. I had to pull off repeatedly to let the engine cool down... (I got one 'overheated engine' light, but mostly it was simply high readings that caused me to pull over.) In cooler weather, I get 190-200 while running down the road. That seems more reasonable. On Jul 6, 2006, at 12:02 PM, luckyron1 wrote: > After noting wet hoses beneath the engine block, I had Detroit Diesel > chase down several leaks. They found several rusty, loose hose > clamps, also some leaky gaskets/seals on the oil cooler. It took 3 > short trips, 2 of them free, but they finally got it right. No more > budgeting for coolant. When the engine is idling, the water temp is > around 180F. Under load, at 80F temps, it can run up to 235F. When > cruising it stays in the area of 200F----210F. It seems high to me. > Is this the normal temp range for the D-60? Thanks. > > Ron & Ruth in MN > > . > > Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 4203 El Sobrante, CA [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Normal engine water temperature for a D-60, 2000 lxi??? - David Brady - 07-06-2006 08:08 If the ambient temp is below 90deg F, mine runs at 190 or below, whether cruising flat level ground or climbing mountain grades; i.e, turbo pyrometer reading 950deg F for an extended period of time. When ambient is above 90 deg, she reads 190 on flat and level and 200 to 205 when climbing grades. In Arizona on a 110 deg day, and while climbing, she may get to 208 deg F, at which point I back off, downshift, and keep the revs up. Never goes above 208, probably mostly due to my driving style. In hot weather, she does need to be managed a bit. This is why many of the coach operators run water misters on their radiators. When I was at the Detroit Diesel dealer they said the motor will shutdown if temps go above 220. But that's with the DDEC II electronic engine control/software. I also learned that my dash gauges reads 5deg high. David Brady '02 LXi, Smokey Va luckyron1 wrote: > > After noting wet hoses beneath the engine block, I had Detroit Diesel > chase down several leaks. They found several rusty, loose hose > clamps, also some leaky gaskets/seals on the oil cooler. It took 3 > short trips, 2 of them free, but they finally got it right. No more > budgeting for coolant. When the engine is idling, the water temp is > around 180F. Under load, at 80F temps, it can run up to 235F. When > cruising it stays in the area of 200F----210F. It seems high to me. > Is this the normal temp range for the D-60? Thanks. > > Ron & Ruth in MN > > [Non-text portions of this message have been removed] Normal engine water temperature for a D-60, 2000 lxi??? - Pete Masterson - 07-06-2006 12:02 I have located a heavy equipment radiator shop reasonably close by and will take the coach in for a thorough going over of the cooling system. There are no signs that the engine has been seriously overheated (e.g. no coolant in oil) but it's hard to believe that this is totally new behavior -- it may simply have run on the warm side for George, but he didn't think, or know, that it was not normal. It is possible that it may simply be a new 'glitch' in a system -- perhaps the thermostats have degraded as they tend to do. While it ran warm on some days, it behaved as one might hope in crossing Donner Summit west of Reno -- showing temp of 190-200 all the way. Outside temps were in the 70s (before noon). On a subsequent, relatively short trip, up Hwy 101 to the redwoods, with temps in high 70s, the engine also ran 190-200. In George's defense, he was very open about the condition of the coach and even provided me with nearly all of the receipts for service and repairs made during his two years with the vehicle -- along with Excel spreadsheets of his WL related expenses. I didn't ask --- and he didn't volunteer --- anything about the cooling system. We discussed several other issues with the coach -- things for me to watch... and I appreciate his openness. Since by the time I was buying the coach, George had no financial interest in the matter, so he had no incentive to "hype" the condition -- and I don't believe he did. Now that I've become aware that the engine does tend to run hot, I've become rather more aggressive in switching on the fan override -- which may have been a factor to my uncomfortably warm afternoon crossing Kansas -- as it hadn't occurred to me to 'override' during that part of the trip (it was my second day on the road, so I was mostly just trying to figure out all the gauges and switches). In buying an 11 year old vehicle, I expect to find items that I feel need attention. The 'to do' list of items is relatively short (so far) and not unreasonable considering normal wear and tear --- plus the fact that the coach sat unused for about 6 months. Most of the to do list items are things I planned for any coach I might have purchased and are related to modifying it to meet our lifestyle needs, convenience, and comfort. The other issues: front AC unit whacked by a branch and the rear AC unit with excessive vibration, house water pump 'weeping', and cooling system needing attention are not unexpected nor exceedingly expensive problems to contend with. For me, this coach has mostly positive attributes and I can deal with those things that need attention. The reality is that I paid much less than I expected to spend on a "newer" coach, so my budget for refurbishing, repair, and upgrades is correspondingly a bit more. My worst problem is that I don't (yet) have a good place to work on the coach, so it's rather inconvenient to attend to some of the issues. For now, we're concentrating on cleaning up 25 years of accumulation in our home so we can get it on the market. Once that is done, then I will concentrate on the coach so it will be ready for us to move into when the house sells. On Jul 6, 2006, at 12:58 PM, Mike Hohnstein wrote: > It would be advisable to verify the accuracy of the dash indicator, > if it proves to be correct, a fresh radiator might be a timely > investment. I wonder if there is illumination here on the reason > George left Hmmmm. > MH > ----- Original Message ----- > From: Pete Masterson > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, July 06, 2006 2:46 PM > Subject: Re: [WanderlodgeForum] Normal engine water temperature for > a D-60, 2000 lxi??? > > That's about what I'm getting with my '95 Series 60. It seems high to > me too. I'm going to pull the thermostat and check it ... and > probably replace it with a new one rated at 180 degrees. > > While going west on I-70 in western Kansas (gradual grades climbing > into Colorado), temps were running 200-210 and a bit higher. Had to > keep one eye on the road and the other on the temp gauge. Ambient > temperature was in the 80s at the time. > > I had overheating problems in eastern Nevada on the grades climbing > out of Salt Lake City on I-80. Ambient temperatures were in the high > 80s or low 90s at the time. I had to pull off repeatedly to let the > engine cool down... (I got one 'overheated engine' light, but mostly > it was simply high readings that caused me to pull over.) > > In cooler weather, I get 190-200 while running down the road. That > seems more reasonable. > > On Jul 6, 2006, at 12:02 PM, luckyron1 wrote: > > > After noting wet hoses beneath the engine block, I had Detroit > Diesel > > chase down several leaks. They found several rusty, loose hose > > clamps, also some leaky gaskets/seals on the oil cooler. It took 3 > > short trips, 2 of them free, but they finally got it right. No more > > budgeting for coolant. When the engine is idling, the water temp is > > around 180F. Under load, at 80F temps, it can run up to 235F. When > > cruising it stays in the area of 200F----210F. It seems high to me. > > Is this the normal temp range for the D-60? Thanks. > > > > Ron & Ruth in MN > > > > . > > > > > > Pete Masterson > aeonix1@... > '95 Bluebird Wanderlodge WBDA 4203 > El Sobrante, CA > > > >> . > [Non-text portions of this message have been removed] Normal engine water temperature for a D-60, 2000 lxi??? - luckyron1 - 07-07-2006 02:19 Thanks for the replies guys. Doesn't sound very serious but I will continue to keep a very close eye on it. Will utilize the fan as well. |
