80FC33 sending unit at oil filters. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 80FC33 sending unit at oil filters. (/showthread.php?tid=291) |
80FC33 sending unit at oil filters. - ernesttumbleston - 04-18-2005 06:20 On my 80 3208 cat, there is a sending unit of some sort at the two filters next to the oil pan. Looks like an epoxy glob repair was done in the past and it's leaking. Can anyone tell me what it is and maybe a part number so I can get one for the next time I let the Bird out of the cage? Muchly appreciated, Todd Tumbleston, 80FC33, Key Largo, FL "For Now" 80FC33 sending unit at oil filters. - Jeff Miller - 04-18-2005 09:05 Oil pressure sender, call BB and they should be able to set you up. I don't know the correct part number, but it has to match the teleflex gauge, I believe that the '80 has the 1-100psi gauge, best of luck. - Jeff Miller http://www.wanderlodge.net --- In WanderlodgeForum@yahoogroups.com, "ernesttumbleston" > > On my 80 3208 cat, there is a sending unit of some sort at the two > filters next to the oil pan. Looks like an epoxy glob repair was done > in the past and it's leaking. Can anyone tell me what it is and maybe > a part number so I can get one for the next time I let the Bird out of > the cage? > Muchly appreciated, > > Todd Tumbleston, 80FC33, Key Largo, FL "For Now" 80FC33 sending unit at oil filters. - John - 04-18-2005 11:02 Todd, I had to replace one of those on a 'Bird that I delivered to Mark Loran in BC, Canada last year. The part number went with the bill to Mark, but it was purchased from NAPA by the repair facility. If you look at the hexigon base of the filter where you put your wrench on to remove it, the pressure shoud be stamped on there, or somewhere on the sending unit, then take it to NAPA and they should be able to match it for you. You will have to know what pressure your gage is also. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" SEE THE OLD COACH AT: http://www.pbase.com/image/26052733 HOPKINS, SOUTH CAROLINA /////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > Oil pressure sender, call BB and they should be able to set you up. > > I don't know the correct part number, but it has to match the > teleflex gauge, I believe that the '80 has the 1-100psi gauge, best > of luck. > > - Jeff Miller > http://www.wanderlodge.net > > > --- In WanderlodgeForum@yahoogroups.com, "ernesttumbleston" > > > > > On my 80 3208 cat, there is a sending unit of some sort at the two > > filters next to the oil pan. Looks like an epoxy glob repair was > done > > in the past and it's leaking. Can anyone tell me what it is and > maybe > > a part number so I can get one for the next time I let the Bird out > of > > the cage? > > Muchly appreciated, > > > > Todd Tumbleston, 80FC33, Key Largo, FL "For Now" |
