| step repairs - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: step repairs (/showthread.php?tid=2913) |
| step repairs - thomas_sorrentino - 07-06-2006 12:56 My step has decided not to work properly this summer. It pulls in, but does not extend automatically. With Jay Darsts help we determined it needs a new air valve. From old post I was able to get the grainger part numbers and have all the new parts. The air side hook up of it, I think I'm ok on. The electrical I'm a little confused on. The original (I think) setup has four wires coming out of the valve. two go to ground and two to a relay, that I can hear clicking when the door open and shuts. The coils on the new valve have 3 wires each. So I've got six wires. I'm sure two go to ground, but I'm still left with to many wires. Any ideas? Tom Sorrentino Bedford Hills, NY 1978 fc 33' step repairs - gcyeaw - 07-06-2006 14:02 What is the Granger part number? Gardner step repairs - thomas_sorrentino - 07-07-2006 00:28 Gardner, Grainger part numbers 2F975 1/4" air valve-1 2G503 connector coil-2 4ZJ85 1/4" flow control valve-2 4HN40 solenoid coil-2 Don't forget, I haven't gotten this to work yet!! Tom Sorrentino Bedford Hills, NY 1978 fc 33' --- In WanderlodgeForum@yahoogroups.com, "gcyeaw" > > What is the Granger part number? > > Gardner > step repairs - fl_bluebird_1983 - 07-07-2006 01:29 I used those exact same parts on my step, works like a charm. If you have any problems or questions drop me a line. Thanks Bruce Campbell '83FCSB "Blue Skies" --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > Gardner, > > Grainger part numbers > > 2F975 1/4" air valve-1 > 2G503 connector coil-2 > 4ZJ85 1/4" flow control valve-2 > 4HN40 solenoid coil-2 > > Don't forget, I haven't gotten this to work yet!! > > Tom Sorrentino > Bedford Hills, NY > 1978 fc 33' > > --- In WanderlodgeForum@yahoogroups.com, "gcyeaw" > > > > What is the Granger part number? > > > > Gardner > > > step repairs - erniecarpet@... - 07-07-2006 05:38 Will these parts work on a PT40? Ernie-step broke in Montana [Non-text portions of this message have been removed] step repairs - ronmarabito2002 - 07-07-2006 13:21 Ernie: Have you looked to see if the mercury stitches are properly in place. They are held in position with plastic pipe clamps. I had to do them once because one of the switches was out of position. That could be your whole problem. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Will these parts work on a PT40? Ernie-step broke in Montana > > > [Non-text portions of this message have been removed] > step repairs - antique405@... - 07-08-2006 07:47 Ernie. I replaced my step valve a couple of years ago with Grainger parts. A2125D-012-D valve 2- 2G503 Valves 4ZJ85-1 Flow valve You have to fudge a little on the valve mounting but it works fine. Paul in Ky 83PT35 Our Rolling Home [Non-text portions of this message have been removed] step repairs - erniecarpet@... - 07-09-2006 01:23 I'll check that out, Thanks ron ernie in montana [Non-text portions of this message have been removed] step repairs - erniecarpet@... - 07-09-2006 01:31 thanks, will give it a look see.ernie-83pt40 in montana [Non-text portions of this message have been removed] |
