What is a good diesel fuel additive - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: What is a good diesel fuel additive (/showthread.php?tid=2931) |
What is a good diesel fuel additive - Chris - 07-09-2006 15:22 The 83 FC35 I purchased had set for some time with a full 265 of diesel fuel. Should I use any kind of additive to kill any possible algea or other contaminate? I replaced the Racor filter and I am still trying to get the filter on the engine off. I have noticed alot more pick up since the Racor change. I have been driving once a week about 20 miles and all seems ok. Sometimes it is a little hard to start though. My manual says not to hold the starter for more than 30 seconds..Is it common to take up to 30 seconds to crank? The most I have had to hold it is anywhere from right away to maybe 7 seconds... Also, any recomendations for a coolant additive? I am not using the CAT coolant at this time. Thanks Chris Reed 83 FC35 SB Plant City, FL. What is a good diesel fuel additive - John Suter - 07-09-2006 23:42 Hi Chris, Yes, definitely; especially at this time of the year in Florida. You can purchase "Bio-Bor" or others at almost any Detroit engine place and sometimes a local NAPA store will order/have it, or similar product (can't recall name.) Keep the fuel tank as full of fuel as possible during humid/hot months (therefore less percentage of tank space can contain humid air, and the less will condense and drop to bottom of diesel and "feed" algae.) Stay on constant lookout for 1/4" or larger, black, "unknown chunks" that will be visible in Raycor glass sediment bowl, and in Aqua-hot diesel filter bowl, if applicable. > The 83 FC35 I purchased had set for some time with a > full 265 of diesel > fuel. Should I use any kind of additive to kill any > possible algea or > other contaminate? I replaced the Racor filter and I > am still trying to > get the filter on the engine off. I assume you mean the secondary fuel filter. Try spraying an assortment of "liquid wrench" or "PB-blaster" type aides into the mating areas of the filter/body assembly. > I have noticed > alot more pick up > since the Racor change. I have been driving once a > week about 20 miles > and all seems ok. Sometimes it is a little hard to > start though. My > manual says not to hold the starter for more than 30 > seconds..Is it > common to take up to 30 seconds to crank? The most I > have had to hold > it is anywhere from right away to maybe 7 seconds... Probably shouldn't take 30 seconds as 30 is probably a bit hard on the starter and it needs to cool. If the starter doesn't spin "vigorously," it may mean some wiring has decayed, or batteries are a bit down, etc. > Also, any recomendations for a coolant additive? I > am not using the CAT > coolant at this time. You need to consider a Nitrite additive and test strips. Be aware you may have up to two coolant filters and one may be buried within the sump pickup tank. You should drain, flush, and change coolant about 15,000 miles or 2 yrs, whichever comes first. Lots of folks manufacture diesel coolant and some make coolant with the additive included. For example, Detroit Diesel "Power Cool" which contains the additive, Nalcool, or you can add your own additive to the coolant and both to water. Nalcool 2000 is for soft water, Nalcool 3000 is for hard water. Be sure to premix with water, before adding either the additives or the coolant to the engine. For coolant filters, Detroit Diesel makes a nifty approx $70 gadget which will "sense" and add coolant one time, if needed: called a "need release auto coolant additive filter" Detroit part #23516489. Not a necessity, but might be helpful for the forgetful like yours truly. John Suter Jacksonville, FL 2000 LXi and prior PT-40's > Thanks > Chris Reed > 83 FC35 SB > Plant City, FL. > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com What is a good diesel fuel additive - Scott - 07-10-2006 00:32 Chris, John's advice on the money. Use the Bio-Bor. You can add different amounts, one to "shock it" and kill the algae, and then a maintenance amount when you add fuel. WORD TO THE WISE, if you start this program it is good to have several primary Racor filters on hand, the dead algae can/will clog the filter and it can be costly if you do not have the spares to change. Simple fix if you do. The coolant issue is another story as well and once again John is giving you great advice. Many folks simply test their coolant for PH and let it go at that. The REAL motor damage happens when the nitrites and nitrates get out of line and cavitation happens inside the motor (around corners, and in tight spots) around the cooling veins inside the motor. Testing with Nitrite and Nitrate strips will tell you what to do (how much additive). The PH is generally thought as an indicator as when to change coolant, NOT keep the cavitation from happening. I have seen PROP BURN (boat motors) where the cavitation has completely destroyed (eaten through) a stainless steel propeller. It can be very harmful if left go, not to mention expensive. ScottB 86FC35 SC --- In WanderlodgeForum@yahoogroups.com, "Chris" wrote: > > The 83 FC35 I purchased had set for some time with a full 265 of diesel > fuel. Should I use any kind of additive to kill any possible algea or > other contaminate? I replaced the Racor filter and I am still trying to > get the filter on the engine off. I have noticed alot more pick up > since the Racor change. I have been driving once a week about 20 miles > and all seems ok. Sometimes it is a little hard to start though. My > manual says not to hold the starter for more than 30 seconds..Is it > common to take up to 30 seconds to crank? The most I have had to hold > it is anywhere from right away to maybe 7 seconds... > Also, any recomendations for a coolant additive? I am not using the CAT > coolant at this time. > Thanks > Chris Reed > 83 FC35 SB > Plant City, FL. > What is a good diesel fuel additive - Chris Reed - 07-10-2006 02:06 Thanks for the advice Scott and John. When I changed my belts and hoses the old coolant was green and looked clean. I replaced with new coolant. I hope that was a sign that the previous owner took care of it as there were no records.... The mechanic who does some work for me said that I needed to drain the fuel out if there was any algea...I am thinking what will I do with 265 gallons of diesel!!!! Glad I can treat it if there is any.. The old Racor filter was black and slick like grease but there were no large clumps. I do not have a sight glass on mine. While we are talking about that general area, there is a faucet with small drain hose to the left of the Racor mounted on the wall...Any idea what that is for? I have been told that Lucas is a good oil additive. Is it recommended to add anything to the engine oil? Thanks Chris Reed 83 FC35 SB Plant City, FL. Scott Chris, John's advice on the money. Use the Bio-Bor. You can add different amounts, one to "shock it" and kill the algae, and then a maintenance amount when you add fuel. WORD TO THE WISE, if you start this program it is good to have several primary Racor filters on hand, the dead algae can/will clog the filter and it can be costly if you do not have the spares to change. Simple fix if you do. The coolant issue is another story as well and once again John is giving you great advice. Many folks simply test their coolant for PH and let it go at that. The REAL motor damage happens when the nitrites and nitrates get out of line and cavitation happens inside the motor (around corners, and in tight spots) around the cooling veins inside the motor. Testing with Nitrite and Nitrate strips will tell you what to do (how much additive). The PH is generally thought as an indicator as when to change coolant, NOT keep the cavitation from happening. I have seen PROP BURN (boat motors) where the cavitation has completely destroyed (eaten through) a stainless steel propeller. It can be very harmful if left go, not to mention expensive. ScottB 86FC35 SC --- In WanderlodgeForum@yahoogroups.com, "Chris" wrote: > > The 83 FC35 I purchased had set for some time with a full 265 of diesel > fuel. Should I use any kind of additive to kill any possible algea or > other contaminate? I replaced the Racor filter and I am still trying to > get the filter on the engine off. I have noticed alot more pick up > since the Racor change. I have been driving once a week about 20 miles > and all seems ok. Sometimes it is a little hard to start though. My > manual says not to hold the starter for more than 30 seconds..Is it > common to take up to 30 seconds to crank? The most I have had to hold > it is anywhere from right away to maybe 7 seconds... > Also, any recomendations for a coolant additive? I am not using the CAT > coolant at this time. > Thanks > Chris Reed > 83 FC35 SB > Plant City, FL. > [Non-text portions of this message have been removed] What is a good diesel fuel additive - John Suter - 07-10-2006 09:37 Hi Chris, Scott has provided you with good info about the dangers of cavitation, which I omitted for fear of "too much info" that might lead to confusion. However, as the door has been opened, we don't want to leave you and others confused about the following: > The PH is > generally thought > as an indicator as when to change coolant, NOT keep > the cavitation > from happening. What we are saying is, it is an error to consider the pH an indicator to change coolant, and that additives are designed to reduce "cavitation," which, in over-simplified terms, is the action of air bubbles within the coolant mixture, "exploding" against the metallic wet- or dry-sleeve walls, "pitting them" to the eventual point of a break-through between the coolant side and the combustion side of the engine block (sometimes, similarly the transmission). A visual example might be to imagine an open pot boiling on the stove, with the trapped air bubbles rising against a closed lid, and then "popping/exploding" to knock loose tiny pieces of metal with each burst. That action is "cavitation" in the very narrow, diesel-engine-coolant, sense of the term. > The mechanic who does some work for me said that I > needed to drain the fuel out if there was any > algea...I am thinking what will I do with 265 > gallons of diesel!!!! Let's hope complete draining isn't necessary. > Glad I can treat it if there is any.. What Scott pointed out was that heavy treating "precipitates out" the algae so it can be trapped by various filters which then will clog to the point of blockage; therefore, have numerous replacement filters available or you can be stranded on the road. Again, IF you have to heavily treat. Loosely, in small quantities, the Bio-Bor will "dissolve/emulsify" the moisture before it can "feed" the algae bloom to the point of a major problem. > The old > Racor filter was black and slick like grease but > there were no large clumps. I do not have a sight > glass on mine. Not to alarm, but numerous "large clumps" stick together to form a grease-like, black consistency. I'd check the latest Racor filter after a few hundred miles and see what it looks like, then form a conclusion. > While we are talking about that > general area, there is a faucet with small drain > hose to the left of the Racor mounted on the > wall...Any idea what that is for? If it is at a gravitational low point compared to the Raycor, I'd have to bet it is to tap-off loose particles. Typically, the drain is at the bottom of the glass bowl we previously mentioned, but you may not have one. > I have been told that Lucas is a good oil > additive. Is it recommended to add anything to the > engine oil? Someone else will have to advise on that issue. Good luck, John Suter > Thanks > Chris Reed > 83 FC35 SB > Plant City, FL. __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
