Possible Coach Water Pump Problem - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Possible Coach Water Pump Problem (/showthread.php?tid=2959) |
Possible Coach Water Pump Problem - jwasnewski - 07-14-2006 10:09 I may have created myself a problem. After our last trip I drained the remaining fresh water from the pure water tank and left the water pump on. Not a good thing. Certainly not paying attention. I'm amazed that it was still running this afternoon, 10 days later. My gut tells me to remove the pump and bench test it. If the impeller fell apart I could get black junk in my water system. Anyone out there done this. Please tell me the result. If you do not want the whole world to know you may email me at jwasnewski@.... Leroy Eckert 1990 WB-40 Niceville, FL Possible Coach Water Pump Problem - ronmarabito2002 - 07-14-2006 16:04 If it's running, it may be O.K.. The first question I want an answer to is: Why did you drain the water? Unless I suspect a problem with my water, mine never gets drained. Never have had a problem with the water. R.E. (Ron) Marabito, dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "jwasnewski" wrote: > > I may have created myself a problem. After our last trip I drained the > remaining fresh water from the pure water tank and left the water pump > on. Not a good thing. Certainly not paying attention. I'm amazed that > it was still running this afternoon, 10 days later. My gut tells me to > remove the pump and bench test it. If the impeller fell apart I could > get black junk in my water system. Anyone out there done this. Please > tell me the result. If you do not want the whole world to know you may > email me at jwasnewski@... > > Leroy Eckert > 1990 WB-40 > Niceville, FL > Possible Coach Water Pump Problem - Leroy Eckert - 07-15-2006 00:55 Ron: The pump was running. I don't know why I drain the tank. Always have to prevent stagnant water. Maybe it isn't necessary. We use the coach water while in transit so the wife and grandkids can use the bathroom. I have established procedures to include a "do not turn on tag" on the switch when the tank is empty. I failed to follow my own procedures when I put the bus away. I'm just happy I put the wheels down before landing. Do you leave water in your fresh water tank for extended periods? We use our coach quite often but are not full time. Thanks; Leroy Eckert 1990WB-40 Niceville, FL ----- Original Message ----- From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Friday, July 14, 2006 11:04 PM Subject: [WanderlodgeForum] Re: Possible Coach Water Pump Problem If it's running, it may be O.K.. The first question I want an answer to is: Why did you drain the water? Unless I suspect a problem with my water, mine never gets drained. Never have had a problem with the water. R.E. (Ron) Marabito, dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "jwasnewski" wrote: > > I may have created myself a problem. After our last trip I drained the > remaining fresh water from the pure water tank and left the water pump > on. Not a good thing. Certainly not paying attention. I'm amazed that > it was still running this afternoon, 10 days later. My gut tells me to > remove the pump and bench test it. If the impeller fell apart I could > get black junk in my water system. Anyone out there done this. Please > tell me the result. If you do not want the whole world to know you may > email me at jwasnewski@... > > Leroy Eckert > 1990 WB-40 > Niceville, FL > [Non-text portions of this message have been removed] Possible Coach Water Pump Problem - Gregory OConnor - 07-15-2006 01:06 Leroy, I drain the fresh water if it was filled with well water. I feel better with city water in the tank, I think it is conditioned for longer storage Gregory O'Connor 94pt Romoland Ca --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Ron: > The pump was running. I don't know why I drain the tank. Always have to prevent stagnant water. Maybe it isn't necessary. We use the coach water while in transit so the wife and grandkids can use the bathroom. I have established procedures to include a "do not turn on tag" on the switch when the tank is empty. I failed to follow my own procedures when I put the bus away. I'm just happy I put the wheels down before landing. > > Do you leave water in your fresh water tank for extended periods? We use our coach quite often but are not full time. > > Thanks; > > Leroy Eckert > 1990WB-40 > Niceville, FL > > > > > > ----- Original Message ----- > From: ronmarabito2002 > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, July 14, 2006 11:04 PM > Subject: [WanderlodgeForum] Re: Possible Coach Water Pump Problem > > > If it's running, it may be O.K.. The first question I want an answer > to is: Why did you drain the water? Unless I suspect a problem with > my water, mine never gets drained. Never have had a problem with the > water. > > R.E. (Ron) Marabito, dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com, "jwasnewski" > wrote: > > > > I may have created myself a problem. After our last trip I drained the > > remaining fresh water from the pure water tank and left the water pump > > on. Not a good thing. Certainly not paying attention. I'm amazed that > > it was still running this afternoon, 10 days later. My gut tells me to > > remove the pump and bench test it. If the impeller fell apart I could > > get black junk in my water system. Anyone out there done this. Please > > tell me the result. If you do not want the whole world to know you may > > email me at jwasnewski@ > > > > Leroy Eckert > > 1990 WB-40 > > Niceville, FL > > > > > > > > [Non-text portions of this message have been removed] > Possible Coach Water Pump Problem - ronmarabito2002 - 07-16-2006 01:29 I have had my current coach now for 5 years and have never completely drained the fresh water tank. The coach rarely sits longer than a couple months between outings. If you suspect the water is getting bad, you will probably have an odor and you can treat the tank at that time. Sure saves a lot of work. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Ron: > The pump was running. I don't know why I drain the tank. Always have to prevent stagnant water. Maybe it isn't necessary. We use the coach water while in transit so the wife and grandkids can use the bathroom. I have established procedures to include a "do not turn on tag" on the switch when the tank is empty. I failed to follow my own procedures when I put the bus away. I'm just happy I put the wheels down before landing. > > Do you leave water in your fresh water tank for extended periods? We use our coach quite often but are not full time. > > Thanks; > > Leroy Eckert > 1990WB-40 > Niceville, FL > > > > > > ----- Original Message ----- > From: ronmarabito2002 > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, July 14, 2006 11:04 PM > Subject: [WanderlodgeForum] Re: Possible Coach Water Pump Problem > > > If it's running, it may be O.K.. The first question I want an answer > to is: Why did you drain the water? Unless I suspect a problem with > my water, mine never gets drained. Never have had a problem with the > water. > > R.E. (Ron) Marabito, dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com, "jwasnewski" > wrote: > > > > I may have created myself a problem. After our last trip I drained the > > remaining fresh water from the pure water tank and left the water pump > > on. Not a good thing. Certainly not paying attention. I'm amazed that > > it was still running this afternoon, 10 days later. My gut tells me to > > remove the pump and bench test it. If the impeller fell apart I could > > get black junk in my water system. Anyone out there done this. Please > > tell me the result. If you do not want the whole world to know you may > > email me at jwasnewski@ > > > > Leroy Eckert > > 1990 WB-40 > > Niceville, FL > > > > > > > > [Non-text portions of this message have been removed] > |
